6/83 grey market 323i.. mtech I S50 5-lug
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #256
    Mine 320i is the same way no abs, ac, and manual windows and sun roof. I only got power steering.
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • kronus
      • Apr 2008
      • 13032
      #257
      the 323i was the flagship e30 of the time, so a lot of them were pretty highly optioned. (hence doglegs and special unicorn LSDs)
      I am unfortunately cursed with a sunroof, but I won't complain about the AC. We're having a bit of a summer here.
      cars beep boop
      • dahows
        • Nov 2009
        • 583
        #258
        Crank windows, no PS, no A/C but powered sunroof on mine...kind of a weird combo.
        84 323i
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #259
          That's the one thing I wish I had was the dog leg, But it'd be useless now after the m30 swap.
          • kronus
            • Apr 2008
            • 13032
            #260
            not if you have an m30 dogleg :p
            cars beep boop
            • LJ851
              • 7919
              #261
              This is the answer for your problems. Grab an m20 bellhousing and drop that clutch sideways smokin.
              Lorin
              The M30 is God's engine.
              • kronus
                • Apr 2008
                • 13032
                #262
                oh shit that's also a good idea
                what do i need the bellhousing out of? 528td?
                cars beep boop
                • LJ851
                  • 7919
                  #263
                  1982 528e.
                  You can fit your big 240 clutch in there too, i bet.
                  Lorin
                  • kronus
                    • Apr 2008
                    • 13032
                    #264
                    Ok yeah, this is the best idea so far. Finding one of those should be reeeeeally easy, right? :D
                    cars beep boop
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      #265
                      Is this for a regular dogleg or a m30 dogleg cause a m30 dogleg would be so cool.
                      • kronus
                        • Apr 2008
                        • 13032
                        #266
                        m30
                        the m20 one already bolts to m20s and m20-flanged things
                        cars beep boop
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #267
                          m30
                          Sweet! So you take the m20 dogleg and change the bell housing and clutch?
                          • kronus
                            • Apr 2008
                            • 13032
                            #268
                            nope, you take an M30 dogleg and put the 528e bellhousing on
                            m20 and s52 have the same bellhousing pattern
                            I should clarify that I have both a 245/11 dogleg and a 265CR dogleg...
                            cars beep boop
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              #269
                              So you take a m30 dogleg put the 528e housing on it and it will fit the m30? I wonder how hard the m30 dogleg is to find an I bet it cost a chunk of change.
                              • kronus
                                • Apr 2008
                                • 13032
                                #270
                                I have an M30 dogleg, I can put a 528e bellhousing on it and then it will fit on a S52, which will avoid concerns of overpowering the relatively fragile getrag 245/11.
                                cars beep boop
