6/83 grey market 323i.. mtech I S50 5-lug
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    #226
    Color change intended?
    • kronus
      • Apr 2008
      • 13020
      #227
      nope, staying white
      cars beep boop
      • Wh33lhop
        • 11705
        #228
        Originally posted by LJ851
        It's a 245 (E21 4 cyl) based trans so it is noticeably weaker than a 260. That being said, one in good condition behind a S52 would probably last fairly long if it wasn't driven by an asshat.
        Alpina used the 245 gearbox bolted to a M30 in their E21 B6 and they did ok.
        Iirc Pete McHenry had a g245 behind a built 3 liter m50 and it lasted for awhile but not for very long of awhile
        paint sucks
        • kronus
          • Apr 2008
          • 13020
          #229
          who's that guy
          is he harder on transmissions than i am
          cars beep boop
          • Wh33lhop
            • 11705
            #230
            A really well known BMW engine builder and probably yes
            paint sucks
            • kronus
              • Apr 2008
              • 13020
              #231
              I think I'll be ok, then. Are the 228mm and 240mm pressure plate any different in external size? I wonder if there's any issue fitting the bigger one in the g245 bellhousing..
              cars beep boop
              • LJ851
                • 7918
                #232
                240 clutch will not fit in a 245 bellhousing.
                A friend with an Alpina B6 e21 replaced the Alpina 2.8 M30 with a 3.6 liter built M30 and the 245 did fine behind it.
                Lorin
                The M30 is God's engine.
                • golde30
                  • 11464
                  #233
                  rebuttholed.
                  Fixed.
                  IG: @Baye30
                  • kronus
                    • Apr 2008
                    • 13020
                    #234
                    argh that's annoying. I'm assuming a 228 disc and pressure plate won't bolt up to a 240 flywheel? So I can't use the aluminum one I have?
                    cars beep boop
                      • 37828
                      #235
                      nope, staying white
                      :giggle:
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • 2mAn
                        Señior Mod
                        • 20215
                        #236
                        I dunno guys. We'll see, I guess. I wonder if getting an aluminum M52TU block bored out to S52 specs is practical-ish. Lightness is something I'd like to pursue with this car if I go the S52 route.
                        I can give you a ride in my car once its done. Alum M52 w/ S52 cams, & 540i MAF. Car should weigh around 2400# because its a no options early model. Weighed 2400# with M20 and it was a riot. Full interior with no power accesories. Kept up with my friends S50 car with the M20.
                        Simon
                        Current Cars:
                        -1966 Lotus Elan
                        -1986 German Car
                        -2006 Volkswagen Jetta TDI
                        Make R3V Great Again -2020
                        • kronus
                          • Apr 2008
                          • 13020
                          #237
                          that sounds fun!
                          I want to get this car weighed, it's on the light side for sure.
                          I read about boring out the aluminum blocks and it looks like it sucks - they're steel sleeves so you need the sleeves pressed out, the thing bored, new sleeves made and installed. A lot of work for 52 lbs. It would probably be cheaper to get custom forged pistons made that'll let me run the s52 crank, rods and head in an aluminum block.
                          cars beep boop
                          • 2mAn
                            Señior Mod
                            • 20215
                            #238
                            that sounds fun!
                            Do that. TMS accidently sent me S52 pistons instead of the M52 and my machine shop guy said no way. I had a S52 crank at the time and the only way it wouldve worked was with custom pistons. Might want to look into M54 internals also
                            Simon
                            Current Cars:
                            -1966 Lotus Elan
                            -1986 German Car
                            • golde30
                              • 11464
                              #239
                              52lbs...you can lose half that weight with a CF or FG hood...
                              IG: @Baye30
                              • Farbin Kaiber
                                Lil' Puppet
                                • 29502
                                #240
                                I know for a fact you can lose closer to 75% of that. Just sayin'.
