6/83 grey market 323i.. mtech I S50 5-lug
  • kronus
    • Apr 2008
    • 13032
    #121
    there i fixed it
    cars beep boop
    • SC750IL
      • Apr 2012
      • 34
      #122
      looks very good
      • litu
        • 846
        #123
        Looks awesome
        https://www.facebook.com/Cry_77_IX-110483784967661
        https://www.instagram.com/cry_77_ix/
        • canakami
          • 743
          #124
          Errmaahgeerrd.
          Freakin' sex, dude.
          Always chasin'
          • Pantless Spency
            It's McRib time!!!
            • Feb 2011
            • 7283
            #125
            no idea how i havent seen this thread, but that last pic.
            damn.
            i love this car!
            • kronus
              • Apr 2008
              • 13032
              #126
              thanks guys!
              today I razor-bladed the 10 years of sap off the windows and wired up a head unit. sadly, the car got back to the garage with a very nasty-sounding intermittent metallic grinding from somewhere in the front section of the engine...
              if it's anything I have to dig into the engine for, screw it, I'll just put in the m106.
              cars beep boop
              • kronus
                • Apr 2008
                • 13032
                #127
                welp, found the problem. the cam gear retaining nut backed off and clobbered the threads on the nose of the cam. GG L-Jet.
                I guess I'll see if I can fix the threads tonight.. don't have a die big enough to recut them.
                cars beep boop
                • kronus
                  • Apr 2008
                  • 13032
                  #128
                  fixed it this morning in about 25 minutes on the street in front of my house.
                  Turns out it's not a retaining nut, it's a plate held on with a retaining bolt (which had backed out), and there's another plate bolted to this plate with a 1/2" socket recess that pokes out the front of the timing cover. Weird design, but whatever.
                  Current known problems (mostly for my own reference):
                  - clanking noise from both front struts when going over bumps. Unclear whether the struts or the girling calipers are loose, but pretty easy to check next time I have it up
                  - excessive shaking at idle RPM - might be a misfire once again
                  - trans noise at idle, probably bad trans input shaft bearing, sadly
                  - all 4 corners rub a bit on compression. The rears are already rolled flat, I might need to actually pull them. The fronts need to be rolled and pulled...
                  - terrible, embarrassing, ear-drum shattering squealing from the HP+ pads. I might need something less aggressive for street driving.
                  cars beep boop
                  • LJ851
                    • 7919
                    #129
                    These may be related. 323 uses the lightest M20 flywheel and the trans can rattle some at idle even if the trans is good. Input bearing will make a more constant rumbling sound, the trans noise is more random and rattle-y especially with an unstable idle.
                    Lorin
                    The M30 is God's engine.
                    • kronus
                      • Apr 2008
                      • 13032
                      #130
                      Interesting, that could be it. I've actually got an aftermarket 14.5# S50 flywheel on it, so it's even lighter than the stock one.
                      cars beep boop
                      • LJ851
                        • 7919
                        #131
                        323 fly is lighter, i think mine was 12.5 - 13 when i installed it.
                        Lorin
                        • animal
                          • Jan 2010
                          • 804
                          #132
                          o man those wheels are amazing!
                          91 DS S52 Slicktop, 91 Calypso M42, 89 Royalblau M20, 84 Bahama Beige 323i, M535, Euro e24, ap1
                          www.RenownUSA.com
                          ig @RenownUSA / @rude.scott
                          • ScHpAnKy
                            • 1573
                            #133
                            everything about this car is proper. Good job.
                            91 318i | 87 535iS
                            • kronus
                              • Apr 2008
                              • 13032
                              #134
                              thanks guys!
                              oh, well, dang. I guess I downgraded, then.
                              cars beep boop
                              • kronus
                                • Apr 2008
                                • 13032
                                #135
                                Hello, some updates.
                                - messed with the timing, TPS and AFM adjustments until I was sick of it. Runs better!
                                - went outside and took some photos.
                                - In preparation for an upcoming track day, took off the Weds.. and three of the four adapters. Two of the small hex bolts in the last one I went to take off were completely seized up and stripped out easily. I'm not sure if I overtorqued them on installation, or overdid it with loctite, but I'll be contacting 8380 Labs about what actual, reasonable torque specs are for the smaller bolts.
                                - One of the camber plates' spherical bearings shat itself. This is a first for me after running several different camber plates on several different cars. Taking it apart tonight to find out WTF.
                                - Played mix and match with three different MotoMeter clusters, and I still cannot come up with one I trust. RPM varies wildly between them (and I don't have an external tach I can verify against), speedo is inconsistent, gas gauge fluctuates, and one temp gauge reads 3/4 while another reads 1/2. It's kinda concerning..
                                so, mix of good and bad, mostly bad.
                                cars beep boop
