6/83 grey market 323i.. mtech I S50 5-lug
  • kronus
    • Apr 2008
    • 13032
    #106
    Nope... But we put a torsen 3.25 medium case diff in it last night!
    I also now have a spare dme and a second set of l-jet injectors... Going to send them out for a rebuild and pop them in.
    cars beep boop
    • LJ851
      • 7919
      #107
      Tell me more about this.
      Lorin
      The M30 is God's engine.
      • kronus
        • Apr 2008
        • 13032
        #108
        Wanganstyle built it. E30 medium case, 188mm 3.25 gearset from an e28, Torsen unit from an auto z3. Since the car is slower than most RVs now I haven't had a chance to actually try it out, but will do soon.
        cars beep boop
        • Iain
          • Oct 2005
          • 2815
          #109
          Awesome build, Kronus. I love those wheels!
          It has made me determined to tick "Alpine S1 323i" off my bucketlist.
          Pork Hunt Motorsport
          eBay is like the summit racing catalog for today's special Olympics crowd
          • kronus
            • Apr 2008
            • 13032
            #110
            thanks!
            and where the hell have you been?!?
            cars beep boop
            • Iain
              • Oct 2005
              • 2815
              #111
              thanks!
              I got a new job as Editor of one of Australia's biggest car mags so I've been busy driving new Porsches, Ferraris, RS4s, M6s, etc in between buying an old American early-1960s cruiser :) Tough gig, I know.
              PS: sick of new cars. Need another E30!
              • Wh33lhop
                • 11705
                #112
                Cool a built diff. Is it faster than a lawnmower yet :p
                paint sucks
                • kronus
                  • Apr 2008
                  • 13032
                  #113
                  sounds like a drag. need an intern?
                  no :(
                  cars beep boop
                  • kronus
                    • Apr 2008
                    • 13032
                    #114
                    update, motor sadness is probably related to it generating almost 0 vacuum at idle. I'm suspecting vac leaks or a plugged exhaust.
                    cars beep boop
                    • kronus
                      • Apr 2008
                      • 13032
                      #115
                      went over the whole vacuum system, found no leaks. checked exhaust flow out the tail pipe, and it actually decreases as you rev the car... almost definitely sure it's a plugged cat, now.
                      I've ordered a Magnaflow dual in/dual out cat.. hopefully I'll have time to install it (and register the car) by Friday...
                      cars beep boop
                      • Wanganstyle
                        • 2828
                        #116
                        Special diff to handle the special M106 later....from special donor 745i.. :P
                        euro car gets euro swap i suppose!
                        fitting a torsen was much cheaper than building up a clutch type unit to take the abuse as a Torsen can take 1Krwhp without much care. Also much more streetable than a most high power clutch unit;
                        • kronus
                          • Apr 2008
                          • 13032
                          #117
                          [crossposted from m20 subforum troubleshooting thread...]
                          I built a smoke tester out of two vw hubcaps, some hose, an air sprayer, a zip tie and a rag:
                          you have to keep the air intake closed:
                          using that, I found that the distributor retard line was completely severed at the distributor. fixed, but didn't solve vacuum issue.
                          then, I read a lot about timing m20 engines with distributors and figured out that I did it drastically wrong the first time - I'd set it to sit at the O|T mark at 3k RPM, because I mistook it for the 19 deg advance line (Z mark), since both had convenient yellow lines drawn over them, and the distributor was maxing out its travel before getting to the correct advance setting.
                          I pulled the distributor out, advanced the rotor manually to give it enough travel, reset the timing to the correct 19 degree BTDC at 3k RPM, verified no more vacuum leaks, and went out for a test drive. Power felt better than before, but not great, and now it is backfiring a lot on power, idles at ~1200 and smells fairly rich. Ideas? Could this be just because I have the exhaust off pre-cat?
                          [after some reading]
                          Apparently, backfiring could be due to running overly rich OR overly lean. It also could be due to too much advance, OR not enough advance. lol.
                          I'm going to see if putting the exhaust on will make the backfiring go away, and also check AFRs, although I'm not sure what can be done to fix AFR problems on an L-Jet engine.
                          Annoyingly, the idle vacuum has only slightly increased, from 5 in hg to 8 in hg. Running out of ideas, although the high idle continues to point to a vacuum leak despite the smoke test's inability to locate any after I fixed the distributor line.
                          cars beep boop
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            #118
                            What ~PSI was your smoke at?
                            • kronus
                              • Apr 2008
                              • 13032
                              #119
                              didn't have a gauge on it, but 5psi or so.
                              cars beep boop
                              • z6ne
                                • Dec 2012
                                • 758
                                #120
                                awesome, keep it up.
