COKGBLR goes under the knife
  • LJ851
    • 7919
    #31
    Originally posted by Cletonius
    I picked up this iso flare tool and made 8 flares and this happened. Going into town tomorrow to see if I can warranty it. :(
    The same thing happened to me when i bought mine. I bought 2 extras when i replaced it so i wouldn't get stuck again next time. Of course i have i never broke another since then. Greasing that piece seems to take some of the load off it.
    Lorin
    The M30 is God's engine.
    • Cletonius
      • 2809
      #32
      I'm in a small town and they haven't had anything in stock I've needed so far. It's hard to deal with being from Chicago where I can go get this tool cash and carry from several places. I left my receipt at home so I'm hoping they'll swap me for store credit and give me some unbent hard line and fluid so I can finish the job tomorrow. I really don't want to have to take Tuesday off as well and I won't have time to come back for another 3 weeks. Total rock and hard place.
      I wish I'd known about greasing the pin, I only need 2 more flares to complete my job and then the back half of the car can go in. Sucks.
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
      • Cletonius
        • 2809
        #33
        Brake lines are done, fuel tank is in, subframe is in. Tomorrow we bolt up calipers, bleed brakes, install the driveshaft and set the car down.
        Beyond excited.
        - Josh
        1990 325is
        Need a shift boot?
        • Cletonius
          • 2809
          #34
          After a 5 mile drive. YAY!
          - Josh
          1990 325is
          Need a shift boot?
          • Cletonius
            • 2809
            #35
            I took the car for a longer drive after I gave it a good washing. Overall I'm very pleased with how it came out, the ride is nice and firm but not too bouncy.
            I have noticed that above 4k rpm through redline I'm getting a shudder. It doesn't seem to be velocity relayed, but more to engine rpm. The car cruises fine at 80+ mph on the highway but after the revs come up the shudder happens. Could this be motor mounts? My transmission mount cross member was hanging by a few threads when I got under the car, maybe replacing all the bolts and finally getting everything as it should have caused some of the other issues to show up?
            Here are a few pics I took today after the wash.
            - Josh
            1990 325is
            Need a shift boot?
            • MattAvino
              • Jan 2011
              • 2147
              #36
              Originally posted by F34R
              That is the brass T divider in the rear that goes to the lines. It is a cheap 'while you're in there' thing to replace with the subframe removed. The hardlines rot out, I did not take a good look but they are only 10 bucks a side prefromed. I did it on my Mother's e30 a year ago, new line from the MC to the rear with a new T and pre made lines with new rubber lines.
              Pre bent e30 lines? Where can I find this?
              E30 buildy things
              http://www.r3vlimited.com/board/showthread.php?t=195286
              • Cletonius
                • 2809
                #37
                The dealer has them for the trailing arms
                Edit: guten parts sells a kit for $60 that has everything, found this out after buying all the bits and a flare tool.
                - Josh
                1990 325is
                Need a shift boot?
                • MattAvino
                  • Jan 2011
                  • 2147
                  #38
                  I didn't find it on their website. Link?
                  E30 buildy things
                  • Cletonius
                    • 2809
                    #39
                    No clue, send Levent an email.
                    - Josh
                    1990 325is
                    Need a shift boot?
                    • MattAvino
                      • Jan 2011
                      • 2147
                      #40
                      I will, thanks
                      E30 buildy things
                      • Cletonius
                        • 2809
                        #41
                        Time for an update!
                        A few months ago the fuzz started peeling from around my sunroof gasket so I figured it was time to get going on my moonroof repair. I acquired a new BMW gasket from a forum member and added a can of trim black to my order at the upholstery supply shop.
                        My moonroof came from a real gem of a parts car so it was in less than fabulous condition when I found it; one of the mounts was halfway peeled off the glass. I used a nice urethane adhesive to glue the metal back down. I took pictures of this process but for the life of me cannot find them anywhere.
                        Now that the brackets were all glued up I could mask off the glass and paint.
                        Paint at the ready
                        I did 4 "med-wet" coats with 3 minutes flash time as directed.
                        After the masking was removed it looked like this
                        Now I've just got to wait 48 hours for the paint to fully cure before I can install it. Longest 48 hours ever.
                        - Josh
                        1990 325is
                        Need a shift boot?
                        • cmcgrogan
                          • May 2013
                          • 240
                          #42
                          its going to look so nice. i wish i had one. nice build
                          Originally Posted by scaraveos
                          Are saying about welding the head to the block? and if yes how is it seperated if required?
                          (possibly a stupid post)
                          • Cletonius
                            • 2809
                            #43
                            Thanks!
                            I wanted one from the getgo but was resigned to never having one. This one fell into my lap so I couldn't resist. I'm going to be redoing the shade as a trial before I attempt a full headliner.
                            - Josh
                            1990 325is
                            Need a shift boot?
                            • Zreberlcoe
                              • 1555
                              #44
                              I want a glass sunroof sssssoooooo bbbbbbaaaaaadddddd. but I don't want to redo the cables lol.
                              1991 325i Calypso Coupe
                              Like Grandfather, Like Father, Like Son
                              BMW
                              • Cletonius
                                • 2809
                                #45
                                Everything is the same. I greased up my roof last year and compared everything to the mechanism I pulled from the parts car. There's just a little nub you have to cut off of the sliding pieces so the shade slides right. I have the installation guide from BMW so I'm hoping it'll go smoothly for me.
                                - Josh
                                1990 325is
                                Need a shift boot?
