I'm about to drop $300 on a clean 2-gauge VDO setup for the ashtray, granted that includes senders and wire harness I would think that you can look at what people pay for gauges and consider that as the point to beat/match. I'm sure you can get a lot of good information in that space.
Check panel renovation
This would be sweet. Do you think you could still cycle the display with the turn signal stalk?- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plate
Originally posted by Cletonius View PostThis would be sweet. Do you think you could still cycle the display with the turn signal stalk?
Originally posted by ninjaotter View PostIf somebody wanted to donate an appropriate stalk and cabling, I'm sure I can get it to work. Otherwise I was just going to leave it up the installer on where to put the button.- Josh
1990 325is
Need a shift boot?
I've made a LOT of progress. I'll take some pictures when I get back into my workshop.
I am afraid that this will be ABSURDLY expensive in a small batch. It would also require a sizable down payment prior to production. So basically, there are huge obstacles to these finding their way into anyone elses hands.
Sadly, this may well be a one off. Short of someone wanting to go into business with me and deciding to invest a few thousand dollars in production equipment.
Would a Group Buy doing a small run make it more feasible? In other words, if you sell 10 of these at once, would that lower the cost per unit in any meaningful way?Originally posted by LJ851kingston is the play by play announcer for this thread.
Originally posted by unloadedak#teamross
Definitely in! If its under $500 a piece then ill take two if that helps!The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
