S38 turbo e30 Hartge H35-24 H bomb
- Likes 2
This weekend I replaced the steering tie rods and got the motor to run steady. I have a small oil leak on pan. It is where it meets the block and timing cover. I will pull the Hartge H35-24 oil pan down to add rtv on top of gasket where timing cover. I hope it works. That was advised by my friend Brandon that works for BMW dealer.
- Likes 2
I pulled the timing cover off because one the bolts punched a small hole in it. I had my friend repair it. It looked ugly. I ordered a new one. The leak was above the turbo return line to pan. It was leaking between gaskets and Hartge wind tray.2 PhotosProjects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
- Likes 3
Originally posted by 2mAn View PostKeep it up Raul!
I like your new toy you have.
I put the Hartge pan back on. Ran it for a while to check for any leaks. I was lucky with no leaks. My 16” spal grenaded on after ten minutes of running. I had to small bolt holding the fan in place. I thought there was enough room for blades not to interfere with blades. The plastic moves more under temperature of radiator and engine running. This time I used out side tabs secure it.
I will be putting everything back on motor. I’m going to do smoke test on turbo manifold and intake. I just want to make sure everything is good.
- Likes 1
On Saturday I ran a smoke test on intake and turbo manifold.
On intake I had a very small amount leak out of linkage in two areas. At this time I’m not going to worry about it. On turbo manifold and exhaust I had leak on down pipe V band and one of rear tips. The turbo manifold didn’t show smoke leak. My friend and I could hear a very small leak. I decided to pull modified off to weld up the leak. I noticed I was not getting a complete seal on exhaust port in front of motor. I took to my friends shop to see if he can save it or scrape it. Meanwhile I’m going to order an other PPF s38 turbo manifold with Precision V band. That means a new turbo Precision V band turbo.
- Likes 1
