Alpine track rat
  • obrian
    • Sep 2011
    • 232
    Alpine track rat
    Since my car keeps blowing up, I figured the project forum might be better than members rides , lol. This is my alpine track rat that hasn't made it to the track yet, and summer is gona be over soon!
    I melted a piston and killed my turbinetics t3/4, wasted the block when that happened. So I thought I'd post some pics of the current state and progress. The turbinetics was to much to fix so I picked up a new HX35. It's the turbo I wanted in the first place anyways. Also bought a m20 from a guy close to me with 91,000 miles, wich is about 100,000 miles less than my last one had. So I cleaned it up and am about to stick it in the bay. Just gota drill and tap my block for the return. This is the last m20 ill be using. They are just to hard to find, and to much money. I thought m20's would be like disposable, and easy to replace every time I blow one up, not really the case anymore. Dang.
  • CrisMac
    • Feb 2013
    • 329
    looks awesome, its time for a 24v.
    Out of curiosity, what power do you make with that setup on your m20?
    DESTROY GARAGE
    S T R E E T S T Y L E
    @CRISMACSTUDIO
    FREE SHELL, COME GET IT!
    • robgoesvroom
      • 821
      wheel, tire, suspension specs?
      just went thru your threads for the past 30 min. Nice E30!
      • Brezzi
        • Jan 2010
        • 1630
        damn thats some carnage. Interested in numbers too, how much boost were you running when that happened?
        • obrian
          • Sep 2011
          • 232
          Well the car never made it to the Dyno. That's probably the problem, me trying to get the tune just right on the road instead of settling for some extra richness. At 20lbs I would loose traction on the hwy with 235 r comps on it.
          As soon as its running again ill be having it tuned by somebody that does that for a living. Maybee a little less boost. It was already a beast to drive, traction definately a problem.
          • TheTacoMan
            • Nov 2011
            • 2308
            I like where this is going.
            Please continue
            • obrian
              • Sep 2011
              • 232
              Got the new block ready with a couple small details before I put it back in the car tonight. Drilled and tapped it for my oil return, also changing the crank case vent set up and getting rid of the bitch tube. Bolted my clutch masters fx300 up. Ex mani back on with all new hardware.
              • Massimo
                • Jan 2008
                • 3207
                God dam. That will be a beast.
                Also love the wheels what are those ones called I would love to source a set for my self.
                • Lof8
                  • Oct 2006
                  • 2827
                  Wheels are awesome! In for updates.
                  S50'd
                  Originally posted by TDE30
                  What is this faggy shit I have happened upon?
                  I can always live in a M3. Can't M3 a house.
                  • Northern
                    • 5076
                    Originally posted by obrian
                    I've been thinking about doing a similar oil return on my iX since there isn't much oilpan up front to drill into. Have you used this location before? how thick is the block in that location? I'm thinking about tapping it for an AN fitting, then JB welding or sealing it in place.
                    Originally posted by priapism
                    Originally posted by shameson
                    • obrian
                      • Sep 2011
                      • 232
                      Second block that I've drilled for the return. It's very thin and easy to tap and drill in that location. No room for ac though, lol. I like that spot because its so much over the oil level in the pan.
                      • obrian
                        • Sep 2011
                        • 232
                        Wheels are O.Z. Monte Carlo competition race wheel all magnesium, group A WRC Tarmac wheel. 17x8.5 235/40, found them in a back yard. Long story.
                        • obrian
                          • Sep 2011
                          • 232
                          Thanks for the compliments guys. Hope to have it going real soon.
                          • obrian
                            • Sep 2011
                            • 232
                            Motor back in the car, yee ha!
                            • IronFreak
                              • Dec 2012
                              • 3702
                              Did you have to roll your fenders pretty hard to fit 245's squared?
                              Instagram @rebellionforge
