Jntar's 318is budget Turbo build...no longer on a budget :(
  • jntar
    • 459
    #76
    Originally posted by Schnitzer318is
    Why did you got with an m20 vs m42 starter out of curiosity?
    Why not? Bolts right up. I felt it was the easier option with the m20 flywheel conversion.
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
    • Schnitzer318is
      • Jan 2008
      • 2057
      #77
      Ah, forgot flywheel conversion. Don't mind me I'm getting old...
      "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
      91 318is Turbo Sold
      87 325 Daily driver Sold
      06 4.8is X5
      06 Mtec X3
      05 4.4i X5 Sold
      92 325ic Sold & Re-purchased
      90 325i Sold
      97 328is Sold
      01 323ci Sold
      92 325i Sold
      83 528e Totaled
      98 328i Sold
      93 325i Sold
      • jntar
        • 459
        #78
        Me too. Turning 32 next Saturday :(
        Any way you could post up or message me your current ignition and fuel maps? I'd like to compare them to mine.
        M42 turbo build.
        • Schnitzer318is
          • Jan 2008
          • 2057
          #79
          I turned 32 in January... yikes.
          Sure, did some work to the turbo car this week. Will post the new .msq up there when I update. Link to the build thread is in my sig.
          91 318is Turbo Sold
          06 4.8is X5
          06 Mtec X3
          05 4.4i X5 Sold
          90 325i Sold
          97 328is Sold
          01 323ci Sold
          92 325i Sold
          83 528e Totaled
          98 328i Sold
          93 325i Sold
          • jntar
            • 459
            #80
            Started to attempt to track down my engine rattle issue. Unfortunatly the water pump housing broke off while using the two screw holes to remove it. Not sure how Im going to get it out. Will probaby have to pull the motor and remove the inter timing case and press the pump out.
            M42 turbo build.
            • jntar
              • 459
              #81
              Well after inspection of the timing equipment Im not seeing anything broken. Next thing is to tear down the pan and check the bearings.
              M42 turbo build.
              • jntar
                • 459
                #82
                Car has been back together for a few weeks. Unfortunatly it had a misfire issue. I have tracked it down to a sticking injector. Every other day I have to pull the intake manifold and run 12v through it to force it to operate correctly. So, on Monday I ordered some genuine Bosch injectors to replace the ZZ Performance injectors. I would have returned them for warranty, but I was 3 days past the 1 year mark and didnt want the hassle. New injectors arrive tomorrow.
                M42 turbo build.
                • Schnitzer318is
                  • Jan 2008
                  • 2057
                  #83
                  What size injector are you running?
                  I've been running some TRM or TWM injectors or something like that and they've been holding up nicely. Though those Bosch you purchased are probably the way to go for the best reliability.
                  91 318is Turbo Sold
                  06 4.8is X5
                  06 Mtec X3
                  05 4.4i X5 Sold
                  90 325i Sold
                  97 328is Sold
                  01 323ci Sold
                  92 325i Sold
                  83 528e Totaled
                  98 328i Sold
                  93 325i Sold
                  • jntar
                    • 459
                    #84
                    42lbs
                    Since I'm already tuned for them(or the junk Chinese version) I figured getting the real Bosch units would be the easiest to get in and fine tune.
                    The car pulls so well when they aren't messing up. My only problem now has to do with my choice of Megasquirt units. The K-data unit has a bad issue with noise susceptibility making it near impossible to road tune. Their customer service is non-existent and it's what I get for not reserching the unit, figuring out later I bought a knock off.
                    M42 turbo build.
                    • bradnic
                      • Jul 2012
                      • 3554
                      #85
                      Amazing work. You got way further down the road than I did. Love the boost gauge.
                      How'd you end up getting the water pump out?
                      HOWTOs:
                      DB vert plastic bumpers
                      OEM Keys
                      MTech1 docs
                      88 ix Lach/Card
                      91 ic Calypso 3.1
                      86 Cosmo 2.7
                      OEM+ or bust!
                      • jntar
                        • 459
                        #86
                        Thanks! I ended up using a mini sledge and blow torch haha!
                        M42 turbo build.
                        • jntar
                          • 459
                          #87
                          New injectors arrived an hour ago. Already installed them.
                          M42 turbo build.
                          • jntar
                            • 459
                            #88
                            And finally, the s54 has been installed into the e36 m3 chassis for a couple days. Finishing up the wiring. My friend in the pic is the owner and is super excited.
                            M42 turbo build.
                            • jntar
                              • 459
                              #89
                              Took the car to autocross yesterday. Blowing off IC pipe and hitting overboost protection constantly from boost spike lol! Was fun :)
                              Dunno whats up with the green bars on the videos.
                              M42 turbo build.
                              • jntar
                                • 459
                                #90
                                New Mishimoto Baffled catch can came in.
                                Local shop had a dyno day. Threw my car on there knowing that it needs much more tuning. Pleasantly surprised I was already in the 180whp range with the conservative tuning I've been able to do so far.
                                M42 turbo build.
