Jntar's 318is budget Turbo build...no longer on a budget :(
  • jntar
    • 459
    So I was going to wait until I had more to post, but oh well...
    I've been collecting parts and pieces for a budget turbo build for almost a year now. I have been back and forth on turbo vs 24v swap. I finally decided to turbo it and be happy.
    This will be a budget build. Thus far I have spent roughly $1400 for everything.
    1. Greddy TD04-15g w/FMIC
    2. Bosch 42lbs gen III injectors
    3. Jake's turbo tune (didnt feel like building a stand alone quite yet)
    4. M50 manifold cut down, welded and extended to fit the m42 as a top mount
    5. 2.5" downpipe and exhaust with high flow cat + magnaflow muffler
    6. 3 gauge ashtray area cluster pod (parker performance vinyl covered 3 hole bracket, VDO 15 psi boost, VDO oil pressure, Innovate G5 AFR
    7. Kinugawa wastegate actuator with several springs from 0.5 to 1.5 bar
    Previous owner's pic of install
    Today was supposed to be the day I mount the intercooler, move the coilpacks and get started on removing the exhaust manifold. However, as I started to work on the coilpack I noticed that the car was very low on oil. Found that the valve cover gasket had failed and the spark plug for cyl 3 was filled with oil.
    Fixed that, pulled the oil pan to tap into for a return line.
    220k miles I was happy to see the condition it was in. Cam lobes show zero wear. Timing gears/equip are very healthy.
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
  • jntar
    • 459
    Today I got the bumper and valance off, mounted the intercooler, and began working on figuring out pipe routing. The more I look at this intercooler the more I think I should upgrade. Anyone else running around 9psi on this small of a cooler?
    M42 turbo build.
    • Vivek
      attention whore/retard/bitch
      • 6167
      Why are you running a cat on a turbo?
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • jntar
        • 459
        I wont be. It is on there from the previous owner of the exhaust.
        M42 turbo build.
        • jntar
          • 459
          Two more pics before I head off to go flying.
          M42 turbo build.
          • ccsdo5
            • Mar 2013
            • 708
            sub'd
            Good luck with this build! I'm actually turbocharging my 318is at the moment now too! Although my progress isn't moving very fast and I'm fully building my motor :D
            This gives me a lot of motivation to work on mine more than I am!!
            -Dee
            5-lugged turbo 318is Barn car
            IG: @deebelmont
            • bradnic
              • Jul 2012
              • 3554
              what's the issue with running a free flow cat and a turbo?
              HOWTOs:
              DB vert plastic bumpers
              OEM Keys
              MTech1 docs
              88 ix Lach/Card
              91 ic Calypso 3.1
              86 Cosmo 2.7
              OEM+ or bust!
              • bradnic
                • Jul 2012
                • 3554
                you absolutely need a wideband.. and enjoy that exhaust bro. cost a bloody fortune to have built. the guy was an absolute artist but man my wallet hurt.
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • jntar
                  • 459
                  I bought an LC-1 a couple of weeks ago :) It's funny the hardest thing to track down was a pressure sending unit. No one sells the m12 thread units anymore for VDO. I ended up buying an m10 and adapter from Parker performance.
                  M42 turbo build.
                  • jntar
                    • 459
                    I got the manifold and exhaust off and got the turbo manifold bolted up. Unfortunately, my uncle passed away today and I will not be working on the car much this week.
                    M42 turbo build.
                    • capn
                      • Jan 2013
                      • 480
                      135i in your sig? Pics?
                      • jntar
                        • 459
                        It's a 325i
                        M42 turbo build.
                        • Dj Buttchug
                          • Jun 2010
                          • 7688
                          you might have heat soak issues with that baby IC
                          Turbo M42 Build Thread :Here
                          Ig:ryno_pzk
                          I like the tuna here.
                          Originally posted by lambo
                          • jntar
                            • 459
                            Thinking the same thing. Going to wire in an intake temp sensor to get some readings. Make my decision to upgrade after that.
                            So change of plans on that BOV. After talking to Jake it had to go. I'm still running the stock AFM and didn't want to deal with rich off throttle and shifts. I went ahead and bought a bypass valve and re-circulation couplers. If it doesn't rain tomorrow I will get the turbo bolted up. Monday I need to take the exhaust and downpipe to my local shop to get another o2 bung welded on.
                            M42 turbo build.
                            • jntar
                              • 459
                              Update:
                              Raining non-stop so no work has been able to be done. :(
                              A few things ordered or arrived this week
                              1)Ordered Bosch bypass valve
                              2)Ordered Two 2.5" with 1" T shape silicone couplers for the bypass valve
                              3)Arrived VDO 150psi Oil pressure sending unit with adapter from Parker performance
                              4)Arrived Jake's turbo chip
                              5)Ordered NXS Signature Manual boost controller
                              6)New intercooler
                              Local friend was selling a 12x24x3 3" inlet intercooler/piping and a couple extra BOVs I wont need. Figured I would go ahead and just upgrade now and just be worry free.
                              M42 turbo build.
