My turbo 24v alpine coupe
  • TeXJ
    • 1914
    #211
    looking good!
    1990 325is
    m52b28
    3.73lsd
    g260 (1987 325is 5spd tranny)
    • mitchlevy7
      • Aug 2011
      • 672
      #212
      Thanks!
      Not much done in the last week. Removed the grills, sanded down the kidneys and repainted everything.
      IMG_0580 by mitchlevy7, on Flickr
      IMG_0582 by mitchlevy7, on Flickr
      IMG_0581 by mitchlevy7, on Flickr
      On friday I made a little video of a pull and the exhaust note
      IMG_0572 by mitchlevy7, on Flickr
      and gave her a bath
      IMG_0576 by mitchlevy7, on Flickr
      IMG_0573 by mitchlevy7, on Flickr
      I tried out this stuff Optimum No Rinse Wash and Wax. Its really good and really easy and quick to use. This was the first wash it has gotten in like 2 years and it took all of 20 minutes.
      www.cp-e.com
      1989 Zinno 325i m52 turbo coupe
      2015 Ford Fiesta ST, Daily Driver.
      • mitchlevy7
        • Aug 2011
        • 672
        #213
        just drove to lunch and it looks like i fixed the stalling issue! TBH i forget what I did but I changed something in the tune a few days ago and it worked. oh well
        www.cp-e.com
        • TeXJ
          • 1914
          #214
          what grit sandpaper did you use for the grill?
          Where are the videos?
          1990 325is
          m52b28
          3.73lsd
          • mitchlevy7
            • Aug 2011
            • 672
            #215
            if you click the blue "photo" itll take you to the video.
            60 and 80 grit but only on the kidneys. Just wanted to rough up the chrome enough for paint to stick to it.
            www.cp-e.com
            • TeXJ
              • 1914
              #216
              ^Thanks!
              Sounds great!
              1990 325is
              m52b28
              3.73lsd
              • Melon
                • Mar 2018
                • 1311
                #217
                I've used the Optimum cleaner before, it's good stuff.
                I do things.
                • mitchlevy7
                  • Aug 2011
                  • 672
                  #218
                  im thinking of trying their opti eraser and their spray on compounds and polishes. so much overspray on the car. Want to get it looking decent while i save up for paint.
                  Read your whole thread by the way. Awesome stuff. Almost convincing me I can paint the car myself.
                  www.cp-e.com
                  • mitchlevy7
                    • Aug 2011
                    • 672
                    #219
                    put the new wilwood rotors on saturday, didnt test drive it but hoping it fixes my warped rotor issue. Nice having rotors for $35each on amazon prime.
                    Looking to fix my rubbing issue. Ive gone back and forth on flares or odp overfenders on this car for such a long time. I have a set of KA motors flares but i don't really like how they look on these cars. Right now im looking at some clinched universal flares because they are ABS and they have a nice variation of shapes to choose from.
                    Other options:
                    -Rebuild the rears- take a half inch off the lip and put a half inch back on the barrel. That should put me around et 26. Parts are like $1k and then powdercoating.
                    -Roll and pull some more
                    -Go down a tire size all around. Switch the 225 to the rear and go 215 or 205 in the front, which will be a stretch.
                    Most likely going to mess around with the fender roller some more before I buy anything. Also trying to decide on tire size on my racing dynamics. They are 16x7.5 et 20. I am thinking 215/45/16 or maybe 225/50/16.
                    www.cp-e.com
                    • mitchlevy7
                      • Aug 2011
                      • 672
                      #220
                      took a week off to go back to MD so ive been slacking
                      finally had a nice day to take it out last weekend
                      here it is next to the daily
                      IMG_0628 by mitchlevy7, on Flickr
                      and a quick video
                      .recorded-1932726699515 by mitchlevy7, on Flickr
                      click it and it starts. screamer pipe is a little much
                      without a lift or dyno not much is happening. its been too cold to drive.
                      I have my VEMS bluetooth adapter on the way so i can log using my tablet.
                      Most likely going to order:
                      -secondary driff mount
                      -rear trailing arm reinforcement
                      -secondary caliper mount
                      -fire extinguisher mount
                      -steering coupler upgrade
                      -longer wheel studs (running 52mm wheel studs on 12mm spacer, not cool)
                      New rotors fixed the pulsing pedal. New record, only like 25 miles on a pair of rotors (they warped because of the brake sticking issue i had earlier)
                      www.cp-e.com
                      • mitchlevy7
                        • Aug 2011
                        • 672
                        #221
                        hell yea black friday!
                        IMG_0661 by mitchlevy7, on Flickr
                        Got a headlight duct for my missing headlight, as well as a OBC phone mount. All 3D printed. Pretty nifty.
                        Also got everything on my list in the last post plus:
                        -Chase bays hydro e-brake with e30 specific lines for second caliper.
                        I dont think im really going to be drifting this thing, but having a separate brake system, even if its just for the rear, makes me feel a little safer.
                        Now I need:
                        -Second set of rear calipers and pads, most likely going to do new rotors and pads for the primary rears too.
                        I had a little epiphany, maybe before I spend the money on a new blower motor, I should at least open it up and see what is making the noise. Could just be something simple like a broken bracket. Going to order a new resistor pack for it and do that.
                        VEMS bluetooth works now too. Pretty nice having gauges on my tablet and it automatically logs. The cold weather was causing some overboost issues when I drove it and my boost fuel cut was set at 21 psi. I think the motor can handle it, but the fuel system cant. Fueling was on target and I was at 82% duty cycle at like 4300 rpm at 18psi... thats 550hp of fuel.... huh?
                        www.cp-e.com
                        • 2mAn
                          SeƱior Mod
                          • 20791
                          #222
                          whens it hitting the dyno? or did I miss that?
                          Simon
                          Current Cars:
                          -1966 Lotus Elan
                          -1986 German Car
                          -2006 Volkswagen Jetta TDI
                          Make R3V Great Again -2020
                          • mitchlevy7
                            • Aug 2011
                            • 672
                            #223
                            Things are moving pretty slowly in our new shop and im waiting to dyno it until our dyno is up and running. Hard justifying paying for dyno time when I can do it for free. Right now looking like Feb or March.
                            www.cp-e.com
                            • mitchlevy7
                              • Aug 2011
                              • 672
                              #224
                              instead of eating lunch today I played around with my buffer. There is so much overspray on the car and I wanted to figure out a way to salvage it until I can do something with it.
                              what the hood looked like
                              IMG_0668 by mitchlevy7, on Flickr
                              a few passes of 105 and then 1 pass of 205
                              IMG_0667 by mitchlevy7, on Flickr
                              then i went to the other side of the hood and tried wet sanding with 2000 grit and it did a pretty good job of getting overspray off
                              after 2000 wet
                              IMG_0669 by mitchlevy7, on Flickr
                              you can tell where I wetsanded by the change in color
                              and then 1 pass of 105 and 1 pass of 205, its actually swirl free.
                              IMG_0670 by mitchlevy7, on Flickr
                              now to do the whole car....
                              so far all my condor and racegerman stuff has come in. Waiting on garagistic and chase bays. Makes me feel alot better having proper length studs with the spacers in the front. there were about 10 turns to tight on the fronts with the spacers on the 54mm studs, its enough but not enough for me to feel great about it. I think the new ones are 67mm bulletnose. I went a little big so that I can run up to 20mm all around if I ever put my RD wheels on.
                              www.cp-e.com
                              • mitchlevy7
                                • Aug 2011
                                • 672
                                #225
                                Been a while since I've posted updates. Been pretty busy at work.
                                Got a few things done.
                                Buffed out the trunk. Tried out optimum polish which worked pretty well. You spray it on the pad instead of a polish you put on the panel, makes it alot cleaner with a rotary im using (Dewalt 949)
                                IMG_0813 by mitchlevy7, on Flickr
                                Installed the fire extinguisher with the garagistic mount. I wish I could have stepped up to one that won't destroy the car if it gets used, maybe one day. This one was like 40 bucks vs 200 for the good kind. If my life is in danger from fire id rather have this than nothing.
                                IMG_0788 by mitchlevy7, on Flickr
                                I also found 2 nearly new roundels in my toolbox that I snagged off the white coupe before I got rid of it. That got me really excited. The ones on there were trash.
                                A bunch of parts came in:
                                -blower motor resistor
                                -rear wheel bearings
                                -trailing arm reinforcements
                                -cover for the fuel tank vent line that goes in the wheel well (little piece of stamped metal was $100!)
                                -hydro e-brake and line kit from chase bays
                                -aluminum coolant res from RS Engineering (in black but shown below)
                                -2 sets of rear caliper guide bushing upgrades from FCP euro (the brass kind)
                                -Used rear calipers (already disassembled and cleaned)
                                -2 sets of caliper rebuild kits for the rear
                                This is the late model coolant res
                                IMG_0824 by mitchlevy7, on Flickr
                                I found myself a sucker for buying parts from small US made companies. Between companies like garagistic, Condor, RS Engineering, Chase bays and many others all stepping up and making great e30 parts, its a great time to be building an e30.
                                Next:
                                More Fender rolling/pulling
                                Drop the rear end for secondary calipers, reinforcements ect
                                more tuning(dyno is almost operational)
                                www.cp-e.com
