The pedal feels good now. Reverse bleeding seemed to work but it still wasn't perfect. I got mad and kicked the pedal like a jack rabbit for 30 seconds and now she is good!
E30 S52 Build + Turbo Install
Instagram: @DrLeadFoot
Build Thread for the Turbo S52:
http://www.wibimmers.com/board/index...turbo-install/
Running log of the daily E46 M3:
http://www.wibimmers.com/board/index...46-m3-journal/
Flickr
https://www.flickr.com/photos/70254549@N06/
The diff is on it's way! Some pics.
Flickr
That yoke ??? what kind of diff is this ,, or do you have some special driveshaftSveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
E34 550 V12 JML
Finnish wisdom : If you want to Win,, hire a Finn
http://alpina.123.is/pictures/
2.79lsd with an extra clutch for 60% lock up from Wanganstyle.sigpic
Flickr
Originally posted by Alpina View PostThat yoke ??? what kind of diff is this ,, or do you have some special driveshaftsigpic
Flickr
From Wangmanstyle:
I started with a circa 2001 z3m unit as its the newest for cosmetics; z3m just happens to use a round 4 bolt instead of square.
Bmw uses both 4 bolt in round and square; 0 difference really; round is just newer like 1997+sigpic
Flickr
Well this was a huge PITA.
Broke off two pins of the TRM turbo chip thingy.
Kudos to Snap for helping me out!!!
I had an extra ECU that I grabbed from a junk yard back when Kummrow thought my harmonic damper problem was an ECU problem... But that $90 for the ECU came in handy because we used the wire holding the tag on to solder up the TRM chip!
Now all is right in the world and she is running like champ! A little break up still but not as bad as before. I'm scheduled the 18th for some dyno pulls at Late Model Throttle in Waukesha, WI to get a better look at what is going on then I'll have TRM send me a better tune.sigpic
Flickr
Some pics from the WCEC meet.
My buddy @xkyletimex (on instagram)'s E21 Monster build.
Flickr
My buddy made this video on my 472/501 dyno run.
With the zf trans the 1:1 ratio is 5th gear. Top speed is 165mph on the dyno. Hahasigpic
Flickr
so i hid behind a truck
Flickr
Serious numbers...... very impressiveSveinbjörn Hrafnsson
E34 550 V12 JML
Those afr's are way to rich, sub 10's are really bad. I wouldn't keep running it like that, you can lift the head with that much unburnt fuel.
With a proper re-tune you will be over 500to the wheels.
What size is your exhaust..?
[QUOTE=DrLeadFoot;4392457]
Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
