Blunttech / Classic Daily S85 V10 E30 M3 Swap
  • JCarp90
    • Feb 2011
    • 1759
    #106
    Woot.
    • Todd Black 88
      • Oct 2007
      • 3449
      #107
      Jake has been reading up on rotors for hours. This may be the ticket ..
      Corvette Gran Sport rear rotor 340mm diam 49mm overall height
      26mm thickness Just need to mill the hub opening. Looks promising and should fit in a 17 in wheel
      With a rotor of that diameter, do you need to make a caliper bracket to bring the caliper out farther from the hub centerline, to get 340mm in there?
      Originally posted by codyep3
      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
      2001 silver/Blk 325 cabby. SOLD
      2002 325xit Sil/blk. SOLD
      2010 F650gs twin
      • blunttech
        • 12850
        #108
        Yes We havent gotten that far yet. We are just trying to find the correct rotor that will fit.. Then build the bracket for that rotor
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
          • 34839
          #109
          Nice. this is the rare case when "hai guize, I want to do an S85 E30 M3 with bugg braeks" isn't just a troll post. :p
          still planning on using MS3? I'd love to help you with the stock DME but they don't exactly fall out of trees. :p
          • blunttech
            • 12850
            #110
            We arent sold on MS3 for sure... Ive bought it but Id also like the idea of using the stock DME.. I have the stock DME
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
            • Eric
              • 5142
              #111
              Originally posted by jakeb
              Yes we are finding we need a lower offset rotor than the e46 stuff. The tie rod hits the rotor.
              Those saab rotors look good but the bolt pattern is not 5x120... Looks like 5x110
              any other ideas?
              Instead of trying and hoping on a bunch of different rotors, it honestly might be easier to run an AP or will wood rotor with a custom hat. Design the hat once and just buy replacement disc (cheap from willwood) instead of boring hubs or re drilling lug patterns at every brake maintenance interval.
              I guess trying a few different rotors doesn't have the same constraints ($$$) when your a parts distribution kingpin...
              • blunttech
                • 12850
                #112
                You may be right Eric ... we were just hoping for an off the shelf solution.. But its looking more and more like that may be more feasible
                sales@blunttech.com
                www.blunttech.com
                Like us on Facebook
                • jakeb
                  • 1909
                  #113
                  We have been doing lots of research looking for off the shelf rotors that will work with the 135 6 piston calipers on the E30 M3. The biggest issue with the M3 is there is VERY little clearance between the rotor and the tie rod. When you go with a really big rotor. The stock M3 rotor is very shallow, right around 40mm.
                  So after digging through lots and lots of different rotor specs for all different cars we think we have found something that will work. This rotor is 330mm by 28mm and NOT off a BMW. Once we know everything will work we will say what it is off of. We don't want misinformation out there. It is only 39mm deep so there is around 7mm of clearance at the tie rod.
                  Now this rotor will need some machining but it is close. The center bore will have to be opened up a little bit and the wheel studs will need to be ob-longed inward.
                  Ultra flat rotor.
                  Bolt holes are close...
                  Ground down the rub of the m3 bearing (will be replaced anyway) to be able to set the rotor flat against the hub.
                  Tie rod clearance
                  Need to make a bracket...
                  Mocking up in a 17" wheel
                  Now this wheel will not clear the caliper. If you look there is some wood stacked to get it to clear. So we will need a different wheel setup. There is around 22mm of "spacer" right now.
                  www.classicdaily.net
                  1970 m42 swapped 2002
                  1985 LS1/T56 Swapped e28 (557e)
                  www.blunttech.com - For all your parts needs
                  Follow me on Instagram for constant build updates @classicdaily
                  https://www.facebook.com/ClassicDailyLLC
                  • golde30
                    • 11464
                    #114
                    The mounting holes on that 135 caliper are in a strange orientation....
                    But seem to be cool for adapter brackets. Can't wait to see final specs.
                    IG: @Baye30
                    • kronus
                      • Apr 2008
                      • 13032
                      #115
                      that's pretty tight caliper clearance. This is with no spacer and new pads, right?
                      cars beep boop
                      • jakeb
                        • 1909
                        #116
                        The other stock bracket is removed already.
                        Yes it is very close... Those are just mock up pics. Won't know clearance until we find a different wheel. 2mm is enough between the spoke and caliper.These calipers don't move anywhere once mounted. Not a sliding caliper.
                        • kronus
                          • Apr 2008
                          • 13032
                          #117
                          derp, that's obvious when looking at it. curious to see what they're off..
                          cars beep boop
                          • klodkrawler05
                            • Apr 2012
                            • 253
                            #118
                            Judging how close the bolt holes are maybe its something 'merican that came in a 5x4.75" bolt pattern, aka 5x120.65?
                            can't wait to see how this plays out for you guys it looks like your onto something!
                            -Brad
                            My E30: http://www.r3vlimited.com/board/show...50#post3916850
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              #119
                              Don't all American cars have drum brakes though?
                                • 34839
                                #120
                                my '67 Dart had manual drums on all for corners. talk about stopping power! it was like having an early version of ABS, since you couldn't possibly lock them up. :p
