76 2002 M20 Turbo
  • kid325e
    • Sep 2007
    • 6421
    #31
    Update? Anything new?
    Sent from my Nexus 4 using Tapatalk
    clutchCTRL!
    Move with a purpose.
    - 1991 325iX 4dr/5spd
    - 2000 323i AT
    2016 Mazda CX3 Sport AWD
    • Dylanhat
      • May 2013
      • 557
      #32
      Nope, just getting parts in. Updates will happen once a week as that is when I have time to work on it. Thanks for the interest!
      Neue Motorsports: http://www.neuemotorsports.com/
      Instagram: https://instagram.com/neuemotorsports/
      • Dylanhat
        • May 2013
        • 557
        #33
        Parts update on what is being run:
        Spec Stage 3+ clutch
        Tial 38mm wastegate
        A custom oil cooler
        BOSCH 36lb Injectors
        UUC EVO 3 Ultimate Short Shifter
        • kid325e
          • Sep 2007
          • 6421
          #34
          What internals in the block are you running to get to 300-350hp??
          Just stock fully rebuilt? Just curious.
          clutchCTRL!
          - 2000 323i AT
          • Dylanhat
            • May 2013
            • 557
            #35
            So the engine is a super eta and will be running the stock internals. Boost should be around 10-13 pounds. If it hits 300 I will be satisfied, but who knows what it will end up making until I get it dyno'ed.
            • kid325e
              • Sep 2007
              • 6421
              #36
              Hell yeah!! Keep us posted.
              Sounds like this thing is going to be a monster man!
              clutchCTRL!
              - 2000 323i AT
              • kid325e
                • Sep 2007
                • 6421
                #37
                Anything new?
                clutchCTRL!
                - 2000 323i AT
                • 88SuperETABD
                  • Apr 2009
                  • 911
                  #38
                  Update Please...I may be picking up a 73 '02 tomorrow. its a rolling chassis with no rust...and im buildin a 2.9L m20 as we speak for my e30, but things may change now.
                  You making your own motor mounts? Getrag 260? 325i e30 driveshaft? what diff?
                  My only worry is can a 2002 take 350+whp. cuz thats what I want my motor to make on boost.
                  Especially since e30 CV's break.
                  (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
                  1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
                  • LJ851
                    • 7918
                    #39
                    The 2002 rear end remains durable up to about 200 hp, it is much weaker than E30 components.
                    Lorin
                    The M30 is God's engine.
                    • deutschman
                      • May 2008
                      • 5958
                      #40
                      Yeah the OP should consider ether building a hybrid LSD using a 2002/e21 case and e30 small case internals (I did this, not to hard), or installing a e28 rear sub frame which needs moving of the control arms and some welding. If you go with the e28 sub frame you will have a few choices of diffs, thicker CV axles, bigger brakes, and the sub frame bolts right in. Down side is you will have 5 lug in the back, and the control arm mounting points need to be cut off and moved inboard by I think 3mm to match the original track width. I saw a guy in northern Europe do this. Ill try and find the thread.
                      EDIT: The sub frame gets 7cm taken out of it. Not sure if thats over all or each side. Id ask the guy.
                      • deutschman
                        • May 2008
                        • 5958
                        #41
                        Here you go.
                        http://www.bmw2002faq.com/topic/1101...hl=m20%20turbo
                        • 318isbmw
                          • Nov 2005
                          • 2841
                          #42
                          I just let Dylan know about this thread and the questions posted. I do know the car has an e21 diff already swapped in by the previous owner. Dylan verified it last time he was over working on the car. For now we're going to be doing just an NA m20 due to money and time. We installed a Bimmerhead's cam in it last weekend, and dylan worked on knocking out the transmission tunnel to fit the getrag 260. It sucks we won't have a speedo for a while, but it'll be worth the wait when we swap in something stronger. In the future, when we do the turbo it will have some sort of a stronger diff, not sure which direction Dylan is going to go, but I've got several e30 diffs, so we'll probably go that route. Last on our list is to find a single mass flywheel. We've been having one hell of a time with that, but it's the last thing on the list before we can get the motor mounted.
                          • Not_the_stig
                            • Feb 2014
                            • 14
                            #43
                            Looking good man!
                            Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!
                            • E30NJ
                              • Aug 2013
                              • 921
                              #44
                              Nice to see a clean 2002!
                              • Dylanhat
                                • May 2013
                                • 557
                                #45
                                Thanks guys. Sorry for no update. From my Stanceworks thread:
                                So an update. Sadly I will be unable to turbo the car until I can put together another $2000 to $2500 so I can have custom halfshafts made and figure out the rear subframe situation. Because the 2002 diff blows up at 200hp it will not suffice so have to either go with an e30 subframe or mod the 2002 subframe. Not sure which way I will go, the e30 makes the car wider in the rear. So what I have decided to do is getting the car running and driving naturally aspirated for now sadly. Once I can put together the funds I will just use the parts I have already collected, no reason to lose my ass on the parts. The engine is going in this weekend with the NA setup which includes a Bimmerheads cam. Some photos.
                                Picked up a JB Racing Flywheel today
                                Recent photo
                                Been delayed due to flywheel and flywheel bolts
                                Because wing
                                Gift from one of my brothers
                                325i oil cooler to be used
                                Catuned clutch line. Great quality.
                                Frontal
                                Great combo, GXSR and E30 M3
                                Beneath the battery tray
                                Before and after
                                Good backyard fire. Must have been 18-20ft tall
                                Some more photos to come this weekend
