76 2002 M20 Turbo
  • Dylanhat
    • May 2013
    • 557
    76 2002 M20 Turbo
    Everything here is getting pulled from Stanceworks. Felt I should put the build up here as well. The plan at the start was to run a NA M20 with a different cam and other odds and ends. Then I decided a turbo would be more fun and have been throwing money at that since.
    Hello all,
    I have a 1976 BMW 2002 Sahara. Plans for the year are to lower the car, new engine and transmission and all new suspension. The interior of the car is already in really good shape so that is going to stay the same. Hopefully will be able to finish everything this summer while school is out.
    Already done:
    BMW 14" Basketweaves
    Air dam and euro bumper
    Recaros / new interior
    Wilwood Brakes
    Steel Brake Lines
    Sway bars
    Plans:
    Engine: M20B27I, 36b injectors
    Turbo: Garrett GT3071R, Tial 38mm Wastegate
    Transmission: Getrag 260
    Suspension: Groundcontrol coilovers, urethane bushings, ST anti-sway bars
    Exhaust: Magnaflow exhaust
    Lights: New headlights and euro turn signals
    Brakes: Wilwood 4 piston rear brakes
    Chip: W.A.R Chip and MAF conversion
    Few photos from a BMW meet:
    Update:
    Struts sent out to be converted
    Picked up M20B27i
    Upgrading rear brakes to 4 piston Wilwood discs
    Some photos of progress from my instagram : username: Dylanhat
    <iframe src="//instagram.com/p/bxFD_cqcFt/embed/" width="612" height="710" frameborder="0" scrolling="no" allowtransparency="true"></iframe>
    <iframe src="//instagram.com/p/bfHEq8KcDL/embed/" width="612" height="710" frameborder="0" scrolling="no" allowtransparency="true"></iframe>
    Other photos of engine:
    Update:
    Tearing down the engine and getting stuff sent out to be powder coated, car is getting closer to receiving the engine
    Myster-e 274 Cam
    Everything other than the reservoir looks like hell
    Started removing the oil and debris from the engine today:
    Random photo:
    Update: Received my shorty headers from IE, motor mounts are in from Sin City BMW. Block is nearing completion and getting painted. Going to be sending out my engine cover and intake to Renewed Finishes to be powder coated in silver with BMW in black. Some photos:
    So I am not rev limited at 4500
    Will be using urethane bushings from Ireland Engineering
    Stripping down:
    Headers Mocked up
    Getting the head and intake manifold ready to be shipped to Renewed Finishes. Both are going to be painted silver
    Some photos
    Scrap except for flywheel which I am selling
    Looks like hell
    Sent out my valve cover and intake manifold out for powder coating and just got finished by Renewed Finishes. Look great, can't wait to get them back.
    Received powder coated valve cover and intake manifold from Renewed Finishes today (https://www.facebook.com/pages/Renew...60775133986357) Came out great, here are some photos I took when I opened. More will be up soon.
    So I received my coilovers from Ground Control. Going to get them mounted up later today.
    Koni Shocks and Eibach Springs
    Camber plate
    Valve cover on
    Old Bushing
    Engine is finally done with paint and is ready for reassembly
    Coilovers are on
    Tore open the ecu to upgrade to the WAR Chip
    So the plan for the car has changed, going to be running a Garret GT3076 turbo. Finally have the car back on the ground after adding coilovers and replacing all bushings with new urethane ones. Here are some photos on the ground for the first time in months.
    New suspension
    Teaser of what is to come:
    Got my turbo, MLS head gasket, ARP Studs and urethane motor mounts today.
    Some random photos.
    Pulling engine
    Aftermarket exhaust on the m10 hung to low so had to cut it off
    Without the m10
    Engine out
    Neue Motorsports: http://www.neuemotorsports.com/
    Instagram: https://instagram.com/neuemotorsports/
  • Dylanhat
    • May 2013
    • 557
    Update today.
    Haven't done much the past 2 months really due to school and busyness. The plan is to move the car this Saturday to my buddies place who is helping me build the car and is helping with the fab work. Engine has been rebuilt with new head gasket and ARP studs. Should be running around 10-13lbs so no real need for the MLS gasket at this point. Been slowly piecing everything together, hopefully will be done in January if I spend enough time on it. Below are some photos.
    S54 in the background for his e30
    Back together
    If I don't move the car this weekend I may just have to push the car there.
    • LJ851
      • 7919
      Neat project, i suggest you stock up on differentials, half shafts, stub axles, etc !
      Lorin
      The M30 is God's engine.
      • moe30
        • Jun 2010
        • 721
        Still jealous of that suspension haha (it's Josh from MO)
        • TheTacoMan
          • Nov 2011
          • 2308
          Awesome, megasquirt is so much better for boost versus war chip. Its a great upgrade!
          • Dylanhat
            • May 2013
            • 557
            Yeah currently figuring out the differential and all that. Might run a e30 rear subframe but we will see.
            Thanks Josh!
            Yeah, I plan on running MS in the future but don't have the cash right now. Had boughten the war chip so decide to just keep it instead of trying to sell and losing my ass.
            • Dozyproductions
              • Jan 2007
              • 4682
              I remember Rob from 2002 Haus in San Luis Obispo was working with e30 sub frame conversions for the bigger diff. Looks fun! Do m20's in 02's make them pretty nose heavy?
              • Dylanhat
                • May 2013
                • 557
                From what I have heard from the FAQ is that at the max it can add 100 pounds. This weight can be trimmed down though, the added weight overall doesn't change the driveability, now if you put an M30 in, yes it does make it nose heavy. I plan on this only adding around 80 pounds to my car.
                • SkiFree
                  • Jun 2011
                  • 2766
                  Hi Dylan looks good so far.
                  For those who ask, the M20 swap (sans AC) doesn't weigh any more than the M10 running AC and smog equipment.
                  ADAMS Autosport
                  • Dylanhat
                    • May 2013
                    • 557
                    Awesome! Thanks for the info!
                    • kronus
                      • Apr 2008
                      • 13032
                      that's surprising to hear.
                      op, neat project! I think my plans may have rotated to an m20 dogleg swap into my 2002, so this thread will be interesting.
                      anyone know if hartge long-tubes will clear the steering setup on a 2002?
                      cars beep boop
                      • 318isbmw
                        • Nov 2005
                        • 2842
                        Can't wait to see this car and get turning wrenches on it. It'll be incredible once it's running.
                        • downforce22
                          • Aug 2009
                          • 3192
                          very nice project. I noticed you have an early m20 with the stamped metal cam gear and oil pump drive gear. I suggest you upgrade to the sinter gears. There is history of people whose gears failed. Especially with a turbo you don't want that to go.
                          See: http://www.mye28.com/viewtopic.php?p=921204
                          • JJe30
                            • 2044
                            Nice build
                            • deutschman
                              • May 2008
                              • 5958
                              Very cool project. Will subscribe
