88' Zinno M3 (Progress Thread)
  • Nats88M3
    • Sep 2013
    • 209
    #181
    I hadn't even notice that it was your car until today I noticed your name! Shit dude you've done a hell of a job!!
    • jhaurimn
      • Nov 2012
      • 2224
      #182
      Look what we got here
      Everything was good with them, except for one clip to hold the bulb was missing. And I didnt have a spare.
      So I made one from a paperclip.
      The driver side lenses are in great shape, as with the pass low beam. The pass high beam has only a little pitting, but since the others are in such good shape, its noticeable. So ill either be cleaning that up or finding a new high beam. I made a wtb ad, so if anyone has a bosch high beam let me know.
      Current:
      1989 325i
      1988 M3
      1987 325ic
      Past:
      2001 330ci
      2001 M3
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        #183
        Je t'aime smileys :)
        • M-technik-3
          • 18946
          #184
          Might have one. I'll look when I get home from work.
          • jhaurimn
            • Nov 2012
            • 2224
            #185
            Appreciate it!
            Current:
            1989 325i
            1988 M3
            1987 325ic
            Past:
            2001 330ci
            2001 M3
            • SteadyAim.
              • Jan 2013
              • 249
              #186
              Car looks awesome! So minty fresh compared to mine :(
              '90 Alpine White M3
              OEM Hella Smoked Euro Smileys | OEM Headlamp Washers | Startec Tail Lights |
              EVO III Undertray | EVO III Front Lip | '92 DTM CF Gurney Flap | Recaro N'Joys |
              Ground Control Coilovers | OZ Futuras
              DD: '97 Alpine White M3/4/5
              • jhaurimn
                • Nov 2012
                • 2224
                #187
                Not much of an update, but it seems like I was able to fix the foggy high beam. Ive been messing around with ways to pour windex into the lense and getting it out without fogging up again. Seems like I got it to stay clear, at least for now. I also took apart the projectors for the low beams and cleaned them up. That alone increased light output significantly.
                And I wasnt able to wire the city lights initially because of some crappy quick splices not working. So I got some t splices, and got them working.
                Current:
                1989 325i
                1988 M3
                1987 325ic
                Past:
                2001 330ci
                2001 M3
                • The Dark Side of Will
                  • Jun 2010
                  • 2796
                  #188
                  Originally posted by jhaurimn
                  t splices
                  Don't do a nice job on the rest of the car and then cheap out on wiring...
                  • jhaurimn
                    • Nov 2012
                    • 2224
                    #189
                    Dude, they are splices. Soldering wires together will involve more cutting, and is overkill. Not to mention going back to stock is harder that way.
                    :loco:
                    Current:
                    1989 325i
                    1988 M3
                    1987 325ic
                    Past:
                    2001 330ci
                    2001 M3
                    • rcsoundn1
                      • Nov 2012
                      • 3361
                      #190
                      t-splices allow for a lot of moisture to enter the splice, and over time corrode the wire, which could eventually break. These splices as well often cut through some of the wire, causing them to fail prematurely. With that all said, I to have used them for things, for the reason, "well I may go back to stock," or because its less work than solder.
                      • jhaurimn
                        • Nov 2012
                        • 2224
                        #191
                        Which is why I wrapped them in electrical tape ;)
                        Also worth mentioning, I do not have a soldering iron, nor the skills to solder.
                        Current:
                        1989 325i
                        1988 M3
                        1987 325ic
                        Past:
                        2001 330ci
                        2001 M3
                          • Jun 2010
                          • 2796
                          #192
                          :loco:
                          Solder on a car is generally bad news because of the vibration.
                          Were these lights not installed in any cars at the factory, or just not wired that way from the factory?
                          Assuming they were tapped into the headlight wires, you could pull the pins on the headlight wires at either end, cut the old pins off and crimp on new pins with both wires in them. That way you end up with sealed connectors and the wiring looks stock.
                          So with everything you've done to this car, "I don't have the skills" is your fallback? You can do better than that. ;)
                          • bradnic
                            • Jul 2012
                            • 3552
                            #193
                            That is complete BS. What are you basing this on? You can argue that a circuit board solder pad could separate from mechanical vibration. But not a soldered wire.
                            HOWTOs:
                            DB vert plastic bumpers
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                              • Jun 2010
                              • 2796
                              #194
                              Here's what solder and electrical tape looks like in a couple of years:
                              The copper had basically corroded out from the solder splice.
                              I replaced with this:
                              Uninsulated butt crimp splices and shrink tube (not yet shrunk in the photo)... much neater, much longer lasting, much more professional and no chance of burning myself with solder.
                                • Jun 2010
                                • 2796
                                #195
                                Solder wicks into the strands of a wire and makes it brittle, susceptible to cracking from fatigue related to vibration. This is a well-documented phenomenon, part of the reason why OEM's just don't use solder on their harnesses and why soldering for aviation and aerospace applications is very very tightly controlled.
