Svetlana gets M power. My 91 318is s52 swap (Engine Out) )
    Svetlana my bae
    Giving her M power.
    my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
    OK SO FAR I HAVE OBTAINED
    98 M3 s52 with 158,xxx w/ wiring harness and comps
    zf transmission
    3.23 lsd with no flanges
    mz3 diff cover
    e34 oil pan stuff
    Flywheel clutch
    Condor mounts
    Send DME to have EWS removed
    AND I NEED
    driveshaft (would any m3 drive shaft work?)
    16" spal fan
    Rewire harness for e30.
    make engine bay nice nice.
    MORE MONEY
    other stuff
    5-13-14 M42 Is OUT
    This is svetlana waiting for m power
    this was before i put the other m42 in it and still had my hub caps.. >:(
      1/7/14 Engine Got Delivered Today!!! came with the exhaust and wiring harness
        Sub'd! Planning on converting to OBD1?
          Sub'd also. I am doing the same swap into my vert. S52. Still collecting parts also.
          Jay
            Na im gonna keep it ODBII gonna try to remove EWS myself
              got my oil pan and motor mounts
                Svetlana gets M power. My 91 318is s52 swap (NO PROGRESS YET)
                My pile of parts
                Took my wiring harness off to remove the auto transmission wires
                Was left with these 4 abs related wires
                Cut off my x20
                Labeled the wires with the corresponding pins and crimped new connectors on them so i can put them in the c101 connector i bought from bmw with the pins
                Apparently these wires dont have much use
                  Some photos of the engine
                  Lil dirty
                  Is there supposed to be a sensor here on the s52?
                    Got my oil nut and e60 shifter woot
                      Nice!
                        My pile is growing
                          Been slowly preping the engine takin bits and pieces off cleaning the block and whatever else i can. Turns out the right engine mount arm was cracked so i gotta get a new one of those.
                          You think the water pump is still good?
                            Get rid of that water pump, put a CAST metal impeller in there
                            Check Us out on Facebook
                            Full Product Line Tuning
                              ^That's what Dave is doin for mine!
