Going with a B35 or a B34 trans?
My 335i Project(Guy who drove with a M30 in his trunk)
This is the only Manual Car I could find in an AZ Junkyard. Was a PITA to get the transmission out.
Finally got the Transmission out but one bolt was shipped, had to get one of the yard workers to grind it off since I couldnt use the grinder.
Pretty sure it is a 260/6, has the fins on the bottom.
This week I am going to be grabbing the last things to finish this swap and start dropping this bad boy in.
#AZE30
1991 318i
1989 325i
1989 335i
Today got my Condor Speed Shop E30 M30 Swap Motor Mounts and E30 Transmission Mounts, new Sachs Clutch, E28 Manual Transmission Radiator, Down pipes and the rest of the little things to finish the swap. Got a E34 M30 C101 Engine Harness the other day. Only thing I have left to do is order my AutohausAZ order and a differential. Then drop in the engine and transmission.
Pretty sweet mounts, the clutch is a clutch lol.
Fitted the E30 M20 shroud onto the E28 Radiator. Will be putting a slim 16" Spal puller in there.
#AZE30
1991 318i
1989 325i
1989 335i
Originally posted by 1FINERIDER View PostVery nicely done (",
AWL I NEED IS MY MUSIC
Originally posted by Bearmw View PostI noticed you have a factory DOT R replacement trans. For some reason it was changed which may be a good sign that it could be lower mileage.
Originally posted by CorvallisBMW View Postsub'd, curious to see how the fan/cooling setup works!
#AZE30
1991 318i
1989 325i
1989 335i
Originally posted by LagunaSecaBlue View Post
This a picture that got posted to my local E30 group. Yes, I drove like that on the Freeway. I secured that thing so tight you could lift the car from the engine.my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
