My euro 320i/B6 3.5 Alpina Tribute ( Now with turbo power)
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #706
    Originally posted by pandaboo911
    Yep my buddies 911 only ever sees cold starts every month or so just to run the engine. Granted it runs pretty rich on cold starts and backfires tons, but the plugs are very black despite the car running really well when it's warmed up.
    Welp.....
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • kronus
      • Apr 2008
      • 13000
      #707
      icky.
      I have a couple spare B34 heads if you need one.
      cars beep boop
      • totheredline
        • Jun 2013
        • 762
        #708
        Ouch. Man, your m30 hates you. Mine doesn't seem to give me problems.
        Sent from my XT1585 using Tapatalk
        = Heidi 1988 325 -> 335i. 7200rpm built M30
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #709
          Originally posted by kronus
          icky.
          I got a euro spec b34 head in my basement that i will rebuild. For now im doing bare minimum gonna pull head lay a straight edge on it. If its in spec i'll buff block and head put new gasket on and run it. Its half ass and not the right way to do it. But i need this bitch on the road and can fix it properly over the winter.
          It fucking hates me so much. This whole car does.
          • kronus
            • Apr 2008
            • 13000
            #710
            if your valves are bent, planing the head won't do shit. do some diagnostics first to figure out if it's top or bottom end.
            cars beep boop
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              #711
              My euro 320i/B6 3.5 Turbo Alpina Tribute Now in assembly
              Yea i plan on checking all that when head is out. Im gonna pull head inspect the valves and what not and make sure its true and not warped. If its good to go I'm just gonna run it. If not i will rebuild but not for a while so car would effectively be dead. What you mean figure out if its top or bottom end? Id think the head gasket is my problem.
              I pulled valve cover and nothing looked out of place. So until i pull head i wont know anything else. Im down to the point where no matter what the head needs to come off to find the issue.
              • bradnic
                • Jul 2012
                • 3550
                #712
                Listen to kronus. it's probably a bent valve. you're gonna drive yourself nuts and replace the valve anyway in the end.
                HOWTOs:
                DB vert plastic bumpers
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • totheredline
                  • Jun 2013
                  • 762
                  #713
                  Leak down test is your friend.
                  • kronus
                    • Apr 2008
                    • 13000
                    #714
                    if you pressurize the combustion chamber (like with a leakdown tester) you can usually do a much better job at pinpointing the source of low compression, i.e. if it is in the rings, the head gasket or the valve seats. with the head off, pressure testing it is harder and requires some jury rigging.
                    cars beep boop
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      #715
                      Like i said. I will inspect it all and see whats what. But i physically don't have the money to rebuild the head right now. Not in anyway shape or form so it will have to get running on bare minimum. I wont put a head on knowing it has a bent valve so if it se bent i will put a different head on. But as of right now i ordered a new head gasket so it's here just in case. So when head will be pulled inspected and i will go from there. So tomorrow night or Tuesday i'll know if i have a bent valve or just need a head gasket.
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        #716
                        Fuck man, bummer luck :(
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #717
                          Yea fuck this car haha. Gonna pull head today and blunt has new gaskets on the way
                          a guy in KC has a built m30 by mteric mechanic claims it makes 300hp and is rebuild never ran or turned over but has been sitting for 12 years on a stand wrapped up. he only wants 1000 i would have to sell my race car parts to get it
                          • Bimmer_man
                            • Jan 2013
                            • 1477
                            #718
                            Dude if an engine has been sitting that long you may have to rebuild it anyway. Cause more than likely the assembly lube may have dried up.
                            Float like a cadillac sting like a Bimmer!:)
                            • CorvallisBMW
                              • 13039
                              #719
                              It's worth checking out at the very least, considering MM motors are usually $3-5k
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #720
                                My euro 320i/B6 3.5 Turbo Alpina Tribute (Done but now with a blown HG)
                                Guy said someone was coming to look at it and would call if it didn't sell. I didn't get a call :(
                                Also i got my head pulled and there is not one visible sign of head gasket failure. Not sure if its normal does seem normal cause they are'nt the cyl that work together but cyl 2 has an intake valve open and cyl has an exhaust valve open but all other 10 valves are closed...
                                Gonna burn this fucker to the ground. Anyone that wants custom m10 pistons and the parts to build one badass motor let me know cause i got an m30 to rebuild now....
                                And yes those two head bolts are stuck in the head they aint goin anywhere
