I did bend them. I did it by hand only, and ONLY far enough to slide the rack out. Even then, the rack just barely squeezed out. I then tapped them back up once the rack was back in place and used the 15mm bolt to draw it back up rather than to hammer it back in place.
Top is an EZ-On top. I found it on eBay but called the seller and ordered it custom with the tinted rear window. I can't remember the vendor.
I paid between $1200-1300, shipped. I think $1235-1250, to narrow it down further.
It is VERY steady- more steady than my 6000# TD6MR felt, and that was never unsafe. Think of it this way- the lift structures are wider than a jackstand and are connected in "pairs" to the other quasi-jackstand on the same side. While they are taller than a jackstand, it isn't crazy tall.
I was torquing up over 100 ft./lb. on some of the PS line bolts, I used an impact on it...it never moved. I was out from under it for the brake work but all of the steering rack stuff was under the car.
There are safety "legs" under the frame that have a 1/4" gap between the safety bar and the safety stop. After 4 days holding the car up in the air the safety bars still have the gap, meaning that the hydraulic portion that lifts/holds the car has not had any loss of pressure over 4+ days, and even if it did the safety bars are there for that contingency. So far I am happy with the results- now that I got the defective accessory parts replaced.
