M20 B3x Naturally Aspirated Stroker build past, present and future
  • 95BMWIC
    • Apr 2012
    • 353
    #271
    Gorgeous!
    Glad you decided to fix it..
    • Bimmer_man
      • Jan 2013
      • 1477
      #272
      Hey digger any updates on that 3.3 bro?
      Float like a cadillac sting like a Bimmer!:)
      • clarkson
        • 231
        #273
        Hey mate, looking good. The dash is not that bad. I have done a couple. How's the new stroker build going?
        Pulling my hair out with all these friggin BMW's:
        2000 M5 Winter beater
        1984 318i Coupe 2.5 S14 going in the car below.
        1988 M3 Lachssilber: I'm the second owner, currently recommissioning.
        • digger
          • Nov 2005
          • 6016
          #274
          cheers, have to get a wear patch repaired in the carpet near clutch pedal and fix a few broken speakers while dash is out so not looking forward to it
          its coming along just a record slow pace (new job means less free time). contemplating making a new airbox and getting a new haltech E2000 ECU before engine goes in.
          • ercis
            • 3
            #275
            I'd like to give You a big respect for what you've done, the research, but most of all - that you've shared your knowledge and findings here! Thank you, good luck with the build, and I hope to see more!
            • Bimmer_man
              • Jan 2013
              • 1477
              #276
              I’m still dying to see if the 3.3 crank will fit in the m20.
              • digger
                • Nov 2005
                • 6016
                #277
                fits no problem, just need a modified intermediate shaft. im getting a custom one as the stock one gets weak when you machine too much off the depth so not looking to risk it
                • Bimmer_man
                  • Jan 2013
                  • 1477
                  #278
                  Epic. Good to know thanks
                  • lindskrot
                    • Aug 2016
                    • 13
                    #279
                    Impressive
                    Just looked through your build.
                    Deeply impressed with all your knowledge. And perfect for me to study.
                    I have a 1987 325is with m20b30 running E85 and RHD itb’s.
                    Bought it with the engine built, but the former owner was not able to finish it.
                    Working with the tune, fuel delivery and installing vacuum system and proper air box intake.
                    I will study this thread closely.
                    Unfortunately I live slightly farther away from Rama than you, since I am located in Sweden.
                    Possibly the only e30 running RHD itb in the country.
                    Keep up the amazing work!
                    • digger
                      • Nov 2005
                      • 6016
                      #280
                      thanks
                      what cam are you going to be running?
                      • skitzy777
                        • Jul 2016
                        • 57
                        #281
                        What pistons/cam combo are you using for the b33
                        -E30 323i 1983
                        -Honda CB250n 1980
                        • digger
                          • Nov 2005
                          • 6016
                          #282
                          I'll be ordering some custom Pistons shortly around 11.5:1 CR
                          Cam will be the RHD roller cam. 292 advertised duration 110 LSA 13mm lift
                          • 2mAn
                            SeƱior Mod
                            • 20339
                            #283
                            You're using a S52 crank (89.6mm Stroke) , correct ?
                            If thats true, what Bore is the 11.5:1 piston? Are you running thin on the cylinder walls yet?
                            Simon
                            Current Cars:
                            -1966 Lotus Elan
                            -1986 German Car
                            -2006 Volkswagen Jetta TDI
                            Make R3V Great Again -2020
                            • digger
                              • Nov 2005
                              • 6016
                              #284
                              The stroke is 93.80mm and bore is 86.00mm so its 3,269 cc (199 CI)
                              • skitzy777
                                • Jul 2016
                                • 57
                                #285
                                Is the 11.5CR pistons the highest compression you could go coupled with the 292 cams?
                                I've been in thought putting the pieces together for a 3L stroker (s50 86mm crank, s50 135mm rods, catcams 1300530 camshaft, CP 85mm 12:1 pistons, supporting valvetrain mods, ITB's down the road)
                                Not sure if the cams ive selected would be too big for my car being a daily.
                                Your build is coming along nice though. Cant wait to see how it turns out
                                -E30 323i 1983
                                -Honda CB250n 1980
