Hot Chocolate Superleggera!
  • CoreyZ
    • 384
    #31
    SEVERAL HOURS LATER
    • 2mAn
      Señior Mod
      • 20825
      #32
      this thread needs updates
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      -2006 Volkswagen Jetta TDI
      Make R3V Great Again -2020
      • CoreyZ
        • 384
        #33
        I'm a bad person who doesn't post
        • CoreyZ
          • 384
          #34
          • CoreyZ
            • 384
            #35
            • MyE30
              • Sep 2013
              • 326
              #36
              is this the thing?
              • CoreyZ
                • 384
                #37
                A front brake thing. Gotta get these fucking asshole wheel bearings out to start on the rears.
                • CoreyZ
                  • 384
                  #38
                  • CoreyZ
                    • 384
                    #39
                    • CoreyZ
                      • 384
                      #40
                      Walking for my graduation this coming Saturday, getting an award for my contributions to the university. Got to do some great research for the Navy and made a lot of great contacts along the way. Soon I'll be able to actually call myself an engineer :D
                      1900x1080 or get out
                      Made some progress on the brown car, FINALLY.
                      M50b25tu pistons (just a vanos M50) in an M52b28 with b28 rods and crank.
                      Rough measurement of piston to deck of stock M52b28 pistons
                      Same with M50b25tu pistons
                      e: Better CR calcs
                      You can use deck height, piston compression height, head gasket thickness, and cylinder head volume to calculate compression, but I can't find decent measurements. The height of the piston at top of stroke should be 209.55mm, but the deck height for an M52b28 block I saw was 208.XXmm. Not the case as you can see.
                      Compression ratio = 10.2:1 = swept volume + (Cyl. head volume, HG volume, clearance volume, ect) : (Cyl. head volume, HG volume, clearance volume, ect)
                      10.2 = (465.5cc + X ) / ( X ) where X is the sum of those hard to measure volumes.
                      9.2*X = 465.5cc. X ~= 50.598cc.
                      If those compression heights are accurate (seems reasonable) the reduction in volume is 4.045cc.
                      50.598-4.045 = 46.552cc
                      (465.5cc + 46.552cc) / ( 46.552cc ) = 10.99 CR
                      I didn't measure CH and we're going by BMW's CR, so there still could be issues. Still pretty decent for very little $$ spent!
                      My brother brought home Thor's Hammer so I could finally bust the crank pulley nut off. Took the rest of the block apart.
                      Not too bad...
                      :barf:
                      Chem-dip to the rescue.
                      • 2mAn
                        Señior Mod
                        • 20825
                        #41
                        Bring this car to LA when you move out.
                        Simon
                        Current Cars:
                        -1966 Lotus Elan
                        -1986 German Car
                        • CoreyZ
                          • 384
                          #42
                          That's the plan, if I end up out there. Things are still prone to change :D
                          • CoreyZ
                            • 384
                            #43
                            lol
                            • 2mAn
                              Señior Mod
                              • 20825
                              #44
                              I'm on tapatalk but that looks like it says 275!?!?
                              Simon
                              Current Cars:
                              -1966 Lotus Elan
                              -1986 German Car
                              • CoreyZ
                                • 384
                                #45
                                Yep! Z4 hubs on stock e30 TAs. +5mm effectively I think?
                                There's still room inboard for more tire lol.
