New here. E21.
  • Gkwan
    • Sep 2015
    • 82
    #91
    Build looks good! Keep it up and eventually, there won't be anything left to replace.
    I think the E21 has a cool look, very close to the 2002, which I love. It probably has to do with the angled front end from the hood down.
    • efficient
      • Feb 2012
      • 3312
      #92
      Cool car. In for more pics.
      • mk3f.t.w.
        • Apr 2014
        • 106
        #93
        Thanks! Yeah I still have some drivability issues. I need to look into the 318i tps since I'm not sure the ecu is seeing the throttle move.
        But yeah the shark nose ISO favorite part.
        • mk3f.t.w.
          • Apr 2014
          • 106
          #94
          I shall keep you posted 😉
          • mk3f.t.w.
            • Apr 2014
            • 106
            #95
            New here. E21.
            Sorry, we couldn’t find that page
            I got my tach working. I wasn't working when I did the e30 318 swap so I'm glad to get it functioning again
            • mk3f.t.w.
              • Apr 2014
              • 106
              #96
              So I finally figured out my dme was bad causing the last drivability concerns left in my swap. I took it apart to see if it was something simple like a cracked solder. Nothing visible. I found a good dme for $50 shipped on r3v. Not too bad! The car is driving much better
              • mk3f.t.w.
                • Apr 2014
                • 106
                #97
                • 2mAn
                  SeƱior Mod
                  • 21001
                  #98
                  Glad its running solid! It actually looks pretty nice as it sits now
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • mk3f.t.w.
                    • Apr 2014
                    • 106
                    #99
                    thanks!
                    • mk3f.t.w.
                      • Apr 2014
                      • 106
                      #100
                      Another project I'm working on is upgrading the lights. Does the e30 bucket fit the best? I believe I have 5 series or 7 series buckets. Does anyone have any pics of how you installed the buckets and what exactly had to be trimmed? I have found a few good threads but the bucket install is a lil vague.
                      • mk3f.t.w.
                        • Apr 2014
                        • 106
                        #101
                        The guibo and trans mount were killed from some old trans leaks. I resealed the trans a bit ago but didn't have the funds to replace these until recently. New guibo, IE trans mount, sway bar end link upgrade for the engine damper. Since I have a newer e21 but older steel motor mount arm, I had to do some grinding to get the damper mount and steel motor mount arm to work together
                        • mk3f.t.w.
                          • Apr 2014
                          • 106
                          #102
                          the rides
                          • mk3f.t.w.
                            • Apr 2014
                            • 106
                            #103
                            the car drove grear this weekend. went for a spirited cruise, then went to SF cars n coffee. I also learned why e21 is called tail happy ;) very fun.
                            • 2mAn
                              SeƱior Mod
                              • 21001
                              #104
                              Im liking how this thing is coming along! Moving the battery to the trunk would help settle that tail down a little.
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • mk3f.t.w.
                                • Apr 2014
                                • 106
                                #105
                                the battery is in the trunk ;)
