Thanks rturbo 930 and Raul. I think the important thing here is that I shouldn't be off more than an 1/8" or so anywhere. But an 1/8" plus another 1/8" and then things can get wonky. I will do the best that I can and measure a lot.
89 325i Cirrusblau Metallic m30 Project - Round 2
Si vis pacem, para bellum.
New Hawtness: 1995 540i/6 Claptrap
Defunct too: Cirrusblau m30 Project
Defunct (sold): Alta Vista
79 Bronco SHTF Build
I just stripped down the intake manifold for cleaning. Every single hose was brittle as hell. I am surprised anyone goes to a junk yard, pulls a motor and just swaps them in. I can't imagine that they run right afterwards.
The plan is to have the bare intake chem-dipped for cleaning. Clean the other parts as best as I can. Disassemble the fuel rail for cleaning and set the injectors aside and send out for cleaning about 30 days before first fire.
As far as welding on the car. I have decided that I need to learn TIG so I am slowly accumulating the pieces necessary to practice. I already have a couple of 300 cu ft tanks (one about 1/3 full and the other empty), the torch, tungsten and regulator to use with my Everlast PowerArc 140ST. Just waiting on the .040 collets to arrive and I can begin practicing.
What caused me to abandon stick for TIG? Well, warnings from folks on here that if I let any slag into the weld on a structural piece and it fails...well, its my ass.Si vis pacem, para bellum.
Tried my hand at tig today. .040 sharpened ceriated tungsten. 30 amps and 15 cfh argon flow and a #4 cup. No filler added at all. Just wanted to see how hard it was to start the arc and see if I could shove some steel around. It works. But I am not thrilled with the gas coverage. It is awfully windy around where I live in the afternoons so when I would arc up, it would work great, then the wind would blow the gas coverage. And obviously I don't have a steady hand at all because I kept dipping the tungsten into the work, soaking up metal. Then the arc was just wild and pointless.
But I can see what all the fuss is about with TIG. The control is amazing when it is working right. It is super easy to lift start an arc and I only had problems when the gas isn't covering well and the tungsten is all covered in crap. Obviously I am a novice...but wow. It is going to be fun!
Edit: I think the .040 is too small of a tungsten even for 20 gauge. It is hard to sharpen mainly. I am going to get some 1/16" stuff.Si vis pacem, para bellum.
friggin cool that you're trying this out.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Thanks man! This is a journey for sure.Si vis pacem, para bellum.
Originally posted by CorvallisBMW View PostUp your amps a bit, try a #6 cup and bump the gas to 20-25CFH. You'll get better penetration without blowing through, and better gas coverage.Si vis pacem, para bellum.
I am, imagine this, questioning moving forward on the project. With my arthritis (waffles) every little bit of work I do on it becomes 3 days of recovery. I guess it doesn't help that I am strapped for cash too.
/pity partySi vis pacem, para bellum.
Fuck man. I'm just starting to get arthritis in my thumbs. I don't know how advanced yours is, but if I take a pre-emptive Advil or two before a specially difficult day of grabbiness, it largely stops the ensuing inflammation. You can doit!!Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"
Originally posted by Ether-D View PostFuck man. I'm just starting to get arthritis in my thumbs. I don't know how advanced yours is, but if I take a pre-emptive Advil or two before a specially difficult day of grabbiness, it largely stops the ensuing inflammation. You can doit!!
It's life and those are the cards I have been dealt so I am not complaining. But it makes me question my commitment level to massive project like this.
I am going to try and look at an e28 535i today. We'll see.Si vis pacem, para bellum.
If you ever wondered how stiff the e30 is, let this pic convince you. The whole car is on stands and this is the front of the car. It's been this way for 2 months or so.Si vis pacem, para bellum.
Originally posted by 864E30 View PostFollowed this through. Progress? Looks like a good build thus far
At any rate, everything is for sale for the car. Not that this is an official for sale thread, but eventually, it will all go.
But, not all is lost. A good friend Josh1254 is selling me a 91 318i Sedan for a good price so I can just daily drive it. I will start a separate thread on that one when I finally take possession. The reason for getting the m42 car as a daily driver is to get me off my motorcycle while still getting over 30 mpg fuel mileage. I was very close to getting killed a couple of times and I have had a bad time with cops lately too.
I may keep the m30 part of the swap just in case I run into more money as well as get my arthritis managed better. You never know!Si vis pacem, para bellum.
Gone even farther away from the project. Everything is listed for sale.
And I am going for a nicer DD now. Looking at e46s. I know, I know.Si vis pacem, para bellum.
