OBD1 M54B30, E36 Rack, Interior Dye, Bay respray and rear end refreshing
  • BMWerke
    • 893
    Car started off as a bone stock 1990 325is when I picked it up in 2010, did a 5 speed swap and the head gasket since it was going along with spring and an interior swap. But I need 24v in my life. I had a low mileage M50B30 I was building but midway through the build I realized I didnt want that extra weight added on the nose so I built this. (see sig for old build)
    Spare Black panels (May '13)
    After alot of degreasing
    My Back seats
    The Rear fiasco (August '13)
    Also sprayed the whole rear end with another layer of bondo under coating.
    All bolts torqued.
    And the engine build.
    Low mileage M54B25 block I got for free.
    Freshly decked
    New Front Seal
    New Seal
    Tranny output seal
    The last wash and the work began.
    $20 E36 rack
    CLEANING, CLEANING and more CLEANING....... Then paint lol.
    Sanding and primer
    Paint then clear coat.
    wet sand and another layer of clear.
    resurfaced and 5mm taken off the back
    6 puck F1 clutch I got for $180 and they accidentally sent an extra friction disc. Good for around 350hp
    E34 throttle cable
    new vacuum lines
    $50 '88 735i brake booster from junkyard and Im using a e46 330I master cly
    difference in length between 735i clevis and new E30 IX one in my hand
    replaced oem rubber and metal clutch line with a single an3 stainless line. $12 for the 22inch line and $5 for each m10x1 to an3 fitting
    I bought 3 feet of 1inch and 3/4inch Flexfab heater hose and cut it to length
    E36 rack
    frech belt 56.1 inch no power steering since 2010 so Im used to it.
    M50 crankcase valve ground down to fit M54 valve cover.
    long E30 318is shift carrier cut in half and bolted together. the bottom of the "I" beam is ground down so that once its bolted together it sits at an angle to correct the angle issue with the G260. No bull no problem.
    centered
    got some old parts in the mail. Using individual Oem BMW motorcycle BREMBO brake reservoirs instead of the 2002 one. And the stock level sensor fits in the reservoir perfectly.
    new rubber lines
    As of today, please excuse the connectors.
    '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
    '86 325e- Donor car for swap/parts car
    '00 323i- BBS 197s Totalted
    '89 740 turbo Volvo- Donated
  • ikonwun
    • Apr 2012
    • 374
    I wish I would have kept my m54 swap and just gone obd1.
    Looks good. Maybe I missed it what did you do for pick up tube and pan?
    • Mr. Tasty
      • Jul 2011
      • 3421
      what did you use on the seats and interior pieces?
      2014 Alpine White 335i MSport
      (Daily Driver)
      Full Mperformance Aero
      KW V2 Coilovers
      VRSF Catless Downpipes
      • E30NJ
        • Aug 2013
        • 921
        ^magic. I'd like to know too, how did you make those seats look so good?
        • BMWerke
          • 893
          Countless hours of degreasing and prep work. Then many cans of burgundy duplicolor vinyl dye.
          • MT325is
            • May 2012
            • 1103
            This is INSANE! Love the color change, and the whole project!
            1989 BMW 325is (SOLD)
            1992 BMW 325IC (SOLD)
            1991 BMW 318IS (STOLEN!)
            2017 BMW M2 (WEEKEND WARRIOR)
            1989 BMW 325IC (PROJECT(
            2002 FORD ESCAPE (DAILY)
            • BMWerke
              • 893
              Thanks guys
              • moatilliatta
                • 6151
                How’s the ride coming along?
                @Zakspeed_US
