ST1G's s52 OBDII Calypsorot
  • Zreberlcoe
    • 1555
    #556
    The conversations that happen in this thread are ridiculous haha^^^
    1991 325i Calypso Coupe
    Like Grandfather, Like Father, Like Son
    BMW
    • lambo
      Captain Scene Points
      • 10953
      #557
      St1g you make me proud.
      If you're proud of St1ggy and St1ggy approves of me [Source]... does that mean you're proud of me?
      • ST1G
        • Oct 2012
        • 6690
        #558
        I'd pull the head to see what the bottom end looks like
        I decided not to, a little carbon never hurt anyone and it's a rabbit hold pulling the head. I'd end up spending another $1500 refreshing the motor. It ran when it was pulled and everything else looks pretty good.
        Maybe if you remove the "m60" bit this sentence will work better.
        I want to make you more than proud. I welded my sunroof closed so I could have a slick top like you.
        Yep, it's the Transitive Property of R3v.
        • ST1G
          • Oct 2012
          • 6690
          #559
          Discovered that my center support bearing is destroyed. Thanks to Ida30 for the temp replacement. I'm going to put that in with the LSD from the e28 here this week. I won't get the swap done till thanks giving break in all likely hood. I will be too busy the rest of this month and don't have the cash flow this month to get everything I need to purchase for it purchased.
          Went to some kind of 'car show'. I was the only e30. I hung out with my VW 'friends'.
          Got my iS skirt installed on the driver side. I don't have enough clips for the passenger side install yet. I'm liking the new house I live in, much bigger garage. Ignore neglected e21.
          My brother is mucho excited about his car. Obligatory pic of seeing it for the first time (he knew we were going to buy it, but I picked it up early) I'll have him join and make a thread, or make one on it's progress. He will have a small budget, but we should be able to do it up right.
          Cleaned it and put in my old sport hounds tooth seats, put in some green mtech style door cars I've had hanging around.
          Sprayed the rocker panels, added IS weaves I had sitting around, replaced radiator with one that didn't leak. Put on a i lip that Adam sent me ages ago to replace my volvo lip. Removed the roof rack, it was a little loose so it was raping the gutters. Purchased alpine white II paint from the Auto Body supply store today to touch up a different white fender a mate gave me.
          • phreshkid
            • 4655
            #560
            This pleases me. Good on you for getting your brother into this weird cult.
            I'm keeping all my brothers away from e30s though. If they want mad honeys, they need 02s.
            • ST1G
              • Oct 2012
              • 6690
              #561
              I want mad honeys. Is there any other way?
              • lambo
                • 10953
                #562
                Your brother has a 4 door therefore he is cooler than you.
                Sorry.
                • 2mAn
                  Señior Mod
                  • 21085
                  #563
                  did you get a "new" driverside fender???
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • ST1G
                    • Oct 2012
                    • 6690
                    #564
                    Sorry.
                    I owned a 4 door. It was ok. My brother keeps telling me it's better. meh.
                    I got a 'new one' and then I painted it with BASF two stage paint put into rattle cans. It turned out okay. I could do better if I did it again.
                    I got sand blasted finder for my brothers car. It will get premiered and painted soon.
                    • phreshkid
                      • 4655
                      #565
                      I'm a firm believer in studying and reciting poetry
                      • TeXJ
                        • 1914
                        #566
                        post a link to your brother's build thread when ya get a chance.
                        1990 325is
                        m52b28
                        3.73lsd
                        g260 (1987 325is 5spd tranny)
                        • ST1G
                          • Oct 2012
                          • 6690
                          #567
                          Well, some fun stuff happened. I got my center support bearing changed. Although the cheap ÜRO bearing a mate gave me didn't come with the new fittings that go on each side of the bearing, so I just skipped it. I figured I wouldn't be running the m20 too much longer. I was going to put in my LSD but I couldn't get the drive shaft removed from the diff, I stripped the bolts. I won't need either for the swap, so I just put the open diff back in.
                          Need to remove the cat, I'll do that before the motor swap.
                          Went on a drive with some friends to a distant mountain town, my engine started making funny sounds. I have no clue what's wrong. I think maybe a valve is way out of adjustment, or a cam lobe is grown down.
                          This my VW friend Pat looking at the engine giving me the advice of the waitress inside; "Add some oil to that car and it will probably stop sounding so bad".
                          How do my plugs look?
                          This is the car after 50 miles of twists, and some burn outs.
                          • eduTechnic
                            • Dec 2012
                            • 400
                            #568
                            Sucky dude! That sounds just like the m20 I just pulled with awful rod knock but who knows. The oil drain plug was jammed with metal shavings. Could check that as well. It was super loud.
                            Turbo M50 4 Door Build thread here 4 Sale thread
                            • ST1G
                              • Oct 2012
                              • 6690
                              #569
                              I will check that. The car is super loud but it sounds like it's in the top end. I am going to adjust the valves just for kicks and if that doesn't do it I'm going to pull the head before I pull the motor.
                              • ST1G
                                • Oct 2012
                                • 6690
                                #570
                                Pulled the head last night. I adjusted the valves first, but they were pretty much in spec. The bottom end will come out this week. I'm going to open it up out of curiosity.
