Building my self a E30 truck
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #31
    So cool I really hope you finish it. cause it will be so cool when its done
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • White325is
      • Oct 2006
      • 5947
      #32
      looks like the older s10 window setup worked well for you. I used the generation after that for my build..
      A few photos of mine. I like the extended version of yours though.
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        #33
        ^ you got a build thread for that?
        • TheRealE30kidd
          • Jul 2010
          • 496
          #34
          Just figured out the missfiring problem and she's alive. Needs a valve adjustment but alive.
          The Current Army
          -(UnderConstruction) 1991 330iS 24v S52 build thread
          -1992 325iC
          -1987 E30 Truck
          -1991 332iS (BecauseRacecar)
          -1988 Dinan M3
          -1988 325iX Tribute car
          -1989 320i Touring (S52/6spd)
          • TheRealE30kidd
            • Jul 2010
            • 496
            #35
            So I got the truck running but the top end was knocking super loud. With farther investigation it looks like the cam lob is completely worn down at least a 1/8 of a inch. So later in the week ill pull the head and replace the cam and address the lack of oil in the top end.
            On anther note I picked up a rear roll bar. It will add alot of structural support that was cut out. It actually fits perfect.
            I also removed the god awful wheels and put some basket weaves back on.
            The Current Army
            -1992 325iC
            -1987 E30 Truck
            -1988 Dinan M3
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              #36
              Just keeps getting better
              • econti
                • May 2014
                • 1148
                #37
                this really is something special
                • TheRealE30kidd
                  • Jul 2010
                  • 496
                  #38
                  So ive made a bit of progress. I have both bed sides welded in and I added a support tubes that run from the b pillar to the back of of the car adds alot of needed support.
                  Today ill be going around doing a million spot welds.
                  The Current Army
                  -1992 325iC
                  -1987 E30 Truck
                  -1988 Dinan M3
                  • Andy.B
                    • Sep 2011
                    • 1650
                    #39
                    Looks awesome. I can't wait to see this get finished.
                    • lambo
                      Captain Scene Points
                      • 10953
                      #40
                      planning to move the battery to the front?
                      • rzerob
                        • Jun 2013
                        • 2315
                        #41
                        Updates?
                        • TheRealE30kidd
                          • Jul 2010
                          • 496
                          #42
                          Yes actually, Just replaced the Head with a proper I head and she is on the road and running. The previous owner put a E cam and valve springs in a I casting. Thats why the top end wasnt getting oil. I have the rear bed almost all sealed up. I can take pics tomorrow.
                          I have a big problem with the rear lighting.
                          When I was cutting up the truck bed I cut the the tail light loom of wires. I wired them back last night and I still have no lights to the rear. There was one wire left over it was a Green wire with red. 1987 325i 4 door and my rear tail lights, brake lights and turn signals aren't working checked all fuses and they are fine. Not sure whats going on.
                          The Current Army
                          -1992 325iC
                          -1987 E30 Truck
                          -1988 Dinan M3
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #43
                            Originally posted by rzerob
                            Updates?
                            Right I wanna see MOAARRRR
                            • TheRealE30kidd
                              • Jul 2010
                              • 496
                              #44
                              The current state. shes coming along.
                              The Current Army
                              -1992 325iC
                              -1987 E30 Truck
                              -1988 Dinan M3
                              • Andy.B
                                • Sep 2011
                                • 1650
                                #45
                                Any progress?
