Slammin's circle jerk....it's dyno'd!!
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #61
    Looks like it's getting shaved and tucked haha
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • slammin.e28
      שמע ישראל
      • 12054
      #62
      Should totally slam a 6 pack carb setup on the M60 for ultimate shaved.
      • ST1G
        • Oct 2012
        • 6689
        #63
        I just love it looking simple, and clean.
        ...but then I'm more of a all go, adequate show....
        ...but then this is a 'vert, so a lot of it is just for show....
        Shave bay, or lose my respect. Those are the only two options.
        • slammin.e28
          שמע ישראל
          • 12054
          #64
          Lets do this.....
          • slammin.e28
            שמע ישראל
            • 12054
            #65
            Got the non-airbag column swapped over.
            ...and my modified e46 column "in" enough to turn the car to move it around. I'll have to put a notch in the splines of the upper column for the set bolt.
            Also....FUCK those shear bolts.
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              #66
              Slammin's 'vert....round deux....
              Going with a e36 rack? I would since your in there
              • rzerob
                • Jun 2013
                • 2315
                #67
                Why swap the steering column? What are the benefits? I ask because I am about to scrap my parts car and it has a non air bag steering column. And my one E30 is an air bag car so it might behoove me to do this swap.
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  #68
                  I think it gives more room for the m60 swap.
                  2014 Alpine White 335i MSport
                  (Daily Driver)
                  Full Mperformance Aero
                  KW V2 Coilovers
                  VRSF Catless Downpipes
                  • dirty30
                    • 3100
                    #69
                    The wilwood pedal box won't clear that big upper bracket that the airbag column has.
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      #70
                      Going to go with Z4 rack and notch the pan. For now I'll be able to roll the car around, but still install the pedals.
                      I'd keep the non-airbag column. Sell it to someone doing the Wilwood pedals on an airbag car.
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        #71
                        Booster out. PS res out. Charcoal can out. God this bay is dirty.
                        Pedal switch on the bracket. Will probably take it off and paint it, but I'm doing this in my limited time after work, max of 1hr a day.
                        Marked the bracket for trimming for the throttle cable. Now, do I merely shave some off, or cut the entire 9mm part out? Figure I'll see when I install and go from there.
                        ...and this morning I marked the throttle bracket for cutting.
                        Small victories. Small victories.
                        • ST1G
                          • Oct 2012
                          • 6689
                          #72
                          Nice dad jeans.
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            #73
                            Originally posted by ST1G
                            Nice dad jeans.
                            Hey man, if the jeans fit!
                            I just wish I could drive my car and take cool pictures like you.
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              #74
                              Whelp.....rear window cracked....bit time.
                              FUCK
                              #vertproblems.
                              With cold weather on the way, and more rain.....to buy a new top or not? I have a spare frame, so the car wouldn't be totally unprotected while it get's replaced.....but it would setback the whole getting it running for burnouts thing....
                              For now I did the packing tape fix. Fuuuuuu.
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #75
                                That blows how'd that happen? Personally I'd buy a new top just cause I can't shit like that. If It can sit indoors then get it doing but outs first.
