SI Shift Lights - by E30 Innovative Goods
  • E30 Innovative Goods
    • Jun 2014
    • 258
    Oct 14, 2016:
    If interested in the Shift Lights drop a line in the thread or on PM.
    Short video of Shift Lights installation and the Shift lights in action:
    Customer video of the Shift Lights in action:
    Jan 13, 2016:
    SI SHIFTLIGHTS batch SOLD OUT!
    Again, thank you all for buying.
    If interested drop a line in the thread...
    Jan. 4, 2016:
    SI SHIFTLIGHTS are now for sale!
    One set left.... go to the latest posts to grab it...
    Hi,
    I am a member of a team of E30 enthusiasts. We like to make things, gadgets that make our E30s more fun to drive. We named our product line E30 Innovative Goods - E30IG.
    First of our project is Service interval shiftlights. We wanted to keep the service interval functional so we had to investigate how the original board operates with LEDs. After a few trials and errors we got it.
    Then it was time to find a way to get rev reading. With a use of oscilloscope we monitored the signal to cluster and got an idea how to read it and display it as shiftlights.
    So the first breadboard version of shiflights was born.
    Then we designed first PCB, side by side with original SI LED board.
    Since there are a lot of things to think about, how to position parts on PCB that cluster can be assembled together, first PCB wasn't good, so we had to do another version, and another...
    All signals can be "picked up" on connector that connects SI board to main cluster board, but how on earth can we hijack them without soldering...a lot of thinking made it happen and after a lot of experimenting adapter was made.
    These aren't all versions...
    Final version on its place.
    Final version of PCB that does it all. Those LEDs are 9000mcd, put your welding mask on ;D
    So, what does it do?
    When you turn your key to Accy position LEDs show you service interval reading. With ignition on shiftlights are activated.
    Our goal wasn't making night rider cheesy look shiftlights that goes on with 800rpms but to make it as realistic and funcitonal as they should be.
    So we decided to take the rpms where engine torque starts to drop as a max, all seven LEDs starts to blink.
    Then with max-200rpm...5 green, yellow LED ligths on,
    with max-400rpm...all 5 green LEDs are on,
    with max-600rpm...4 green LEDs are on,
    with max-1200rpm...1 green LED is on.
    Below that no lightshow...
    To keep things more complicated as they already are, these tresholds are dependent of engine temperature.
    When engine is cold everything starts to happen earlier.
    As I mentioned before LEDs are realy bright, shiftlights are supposed to be so bright that you keep your focus on the road/track and know what your rpms are. But if someone wants to set the brightness it can be done.
    How can you set the brihtness with no potentiometer...I came up with a solution that may sound weird but it actually works.
    I studied the onnector that connects SI board to main cluster board and found out a way to use Fuse21 to help me :D
    Brightness setting procedure:
    0. open the hood of your E30
    1. locate the fuse box and open it
    2. remove Fuse21
    3. insert modified fuse with wires and button long enough to press/depress the button from your driverseat OR ask somebody, anybody or your buddy to help you
    4. startup your car
    5. press the button, Fuse21 "goes off" as a result tacho goes off too
    6. with revving your engine you are changing LED brightness, 100% at cca 1200rpms. When you get to the brightness which suits you just depress the button
    7. your favorit brightness is stored.
    Next project is hazard switch digital multi gauge. It is capable to measure four different things and voltage. For instance oil temp, oil pressure, fuel pressure, cooling temp.
    It fits into a hazard switch, with a LED display cover made of plexi glass that is shaped like original hazard switch dark red plastic. The whole thing will work as a switch, when youpress it it will toggle to another measurement with text displayed...let pics do the talking...
    BTW, chars are evenly illuminated, pics can be misleading.
    And another project...try to figure out what could it be.
    Comments, ideas and critics are welcome.
    Committed to excellence!
    If you don't know that there's a lot you don't know, you think you know everything.
    Our threads:
    E30 One-Touch windows
    E30 Intelligent wipers
    E30 Econo gauge - still R&D
    E30 SI Shift Lights
    E30 Hazard Switch Multigauge - still R&D
    Feedback thread:
    Our pages:
    http://www.e30ig.com
    https://www.facebook.com/InnovativeG
  • Wschnitz
    • 8089
    looks like george graves has some competition. Nice products.
    willschnitz
    • sam_
      • May 2014
      • 630
      Very interesting.
      1991 325i
      flickr
      @sambhaskins
      • Balleristic31
        • Aug 2009
        • 4198
        Is the shift light available for sale? Cool idea!!
        George is either already in on this or needs to continue to up his game :D
        -NICK
        • whodwho
          • Jun 2008
          • 1547
          Looks like wiper control... would be nice with vehicle speed sense 8^)
          My M20 Frankenbuild(s)
          4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • stonea
            • 2892
            Looks like some great products, you'll probably be getting a lot of my money in the future... :(
            My Garage
            Feedback
            Instagram: Stone.Hopkins
            • cabin
              • Dec 2006
              • 552
              Cool products! Any videos of that shift light in action?
              -Justin
              Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
                • Jun 2014
                • 258
                They will be available for sale sortly. I will anounce the first batch.
                Our threads:
                E30 SI Shift Lights
                Feedback thread:
                Our pages:
                  • Jun 2014
                  • 258
                  It is a programmable wiper interval control relay, it works like E36 wiper control with intensive wash function. Details will come later.
                  Our threads:
                  E30 SI Shift Lights
                  Feedback thread:
                  Our pages:
                    • Jun 2014
                    • 258
                    This is a video shot during development, notice that LEDs are not the ones used in the final version. Threshold was set to light the first green LED almost from idle.
                    Our threads:
                    E30 SI Shift Lights
                    Feedback thread:
                    Our pages:
                    • iwantspeed
                      • 3164
                      Badass^
                      Project
                      Parts for Sale
                      Feedback
                      YouTube Channel
                      • Nisse Järnet
                        • Aug 2013
                        • 1221
                        Cant see the pics :S
                        E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                        E30 M50 6 spd 764whp @ 24psi.
                        E30 M20 6 spd 675whp.
                          • Jun 2014
                          • 258
                          Domain maintenance
                          Our threads:
                          E30 SI Shift Lights
                          Feedback thread:
                          Our pages:
                          • sam_
                            • May 2014
                            • 630
                            Looks like George has some competition!
                            1991 325i
                            flickr
                            @sambhaskins
                            • Nisse Järnet
                              • Aug 2013
                              • 1221
                              Domain maintenance
                              Can see them now, nice work! Im interested.
