Northern's Sterlingsilber M52 Turbo 325is
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    #151
    Originally posted by Northern
    A mini project I've though about ever since I snapped my timing belt last year and realized how useless the stock toolkit is. I couldn't even pull the valve cover with the open ended wrench in the kit.
    I bought an E34(?) Full size tool kit, and gutted the molded inside for some foam. I'll grab some wrenches, sockets, pliers, screwdriver, etc and shadow them into the foam.
    I did the same a while ago out of the same frustration. This was the "prototype" and I also have the big e34 tray that I'll do the same to when I have some spare time. Was planning on holding a full set of open ended wrenches, full set of 1/4 and 3/4 sockets and ratchets, a breaker bar, various screw drivers, a pair of one or two pliers and a flashlight.
    Shadetree30
    • Northern
      • 5179
      #152
      ^ Going to try to fit common wrenches, screwdriver, 1/4" and 3/8" sockets, torx, allen bits or keys, tire plugs/tool, and a few spares of screws/bolts/nuts for like fenders and stuff. I haven't cut anything out yet, but I've been buying a few things for it as they go on sale.
      @Josh
      Same here with the welds. Especially recently, I'm worse than when I first started somehow lol. I'm hoping the liner in my mig is messed up, or I'm screwing myself with the extension cord I'm using.
      Surprise surprise, somehow the charge piping fits around the rad support/ABS on the iX, but it's not even close on this car. I need to make a question mark shape out of pie cuts to wrap from the IC, around the rad support, and then back again after it clears the ABS unit. It's not going to stay steel forever, but for this year I think that's how it will stay.
      Somehow my hacksaw sprouted legs and vanished, so I'm stalled for the moment...
      Originally posted by priapism
      Originally posted by shameson
      • ncrmtrsprtsE30
        • May 2015
        • 204
        #153
        nice manifold
        The "Because Race Car" M60 V8 Build Thread
        On Instagram Straight Flexin' #BecauseRaceCar
        • 328ijunkie
          • May 2007
          • 3961
          #154
          So pretty
          Check Us out on Facebook
          Full Product Line Tuning
          • Northern
            • 5179
            #155
            Originally posted by 328ijunkie
            So pretty
            No, you.
            Calling around to get it ceramic coated this week. That leaves me with no more reason to procrastinate.
            • Northern
              • 5179
              #156
              So now I'm thinking about ceramic coating my manifold myself. Doesn't seem too hard...
              Some parts showed up:
              2" thick 16" Spal pusher, flex pipe, and some silicone couplers:
              Impulse purchase, a slightly larger lincoln mig. Sold my Mig Pak 10 to offset some of the cost.
              Still haven't used it. Probably running a new 20A 120V circuit tonight for this, since I have some room on my panel - and the workshop currently only has a single 15A circuit with a million things on it, plus some sub panel that's 80A 240V intended for god knows what.
              I actually worked on the car a little... Washer fluid res bracket was rotten, and there were a few rust spots from where it had been rubbing. It got cut off, primed and painted. Didn't even bother to try to smooth it out, but even so it came out nice enough.
              While I was doing this, I was sanding down bits of the front valence. Lots of rust at the fender/bumper mount, and the lower fender liner screw tab. Not going to run those anymore (interference issues) so I just ground the rotten brackets off.
              Then I started to clearance the valence for the FMIC/piping:
              upper brackets notched
              Didn't clear end tanks... and the sharpie is where it still doesn't clear...
              but wait, there's more:
              RIP upper valence brackets. Should've cut them off in the first place, they didn't fit around the end tanks at all. It's actually still surprisingly sturdy. I don't really notice a difference even with all that cut off it.
              No point in all those fancy holes if air can't get to it:
              Hoping that gets some air to the FMIC, but is still invisible from outside the car.
              • Northern
                • 5179
                #157
                And for laughs, this is what happens when you buy the cheapest of the cheap brake rotors/pads for your daily (ULTRA 8 parts on a Mazda 3)
                Yeah.
                • Northern
                  • 5179
                  #158
                  Oh and here's some random IG pics of FMIC brackets:
                  And you can see the slim spal pusher in there.
                  • efficient
                    • Feb 2012
                    • 3312
                    #159
                    Can't wait to see more updates
                    • 328ijunkie
                      • May 2007
                      • 3961
                      #160
                      Love the progress
                      • Northern
                        • 5179
                        #161
                        Love the progress
                        Your post reminds me that I need to get at you with some tune questions/info soon.
                        • Northern
                          • 5179
                          #162
                          Long time, no update.
                          Going heavier on the pictures, light on the words. Starting sometime in March:
                          Looking at downpipe clearance...
                          Coil wiring probably not going to last long like that.
                          Front. Rusty washer res bracket and rusty seam at front base of tower dealt with and painted. Rotated the horns a bit to clear the wheelwells more, cleaned a few things up.
                          Start pulling coil harness apart... This doesn't look great, but apparently they all look like this.
                          Can it be re-routed?
                          Looks like it can
                          Everything is tight, wrapping to hopefully prevent chafe
                          Have to move the harness side of the connector as well...
                          Notching the lip in the valve cover to reroute the coil harness
                          Laying in the notch
                          Notching beauty cover as well
                          Done:
                          • Northern
                            • 5179
                            #163
                            Intake Manifold comes off to move/swap the CCV, plus add turbo oil feed/ pressure sender. - Side note: I was going to remove the oil filter housing and tap the side for an oil temp sender, but I would need to drain the coolant/remove the FMIC+fan+rad to get at the idler pulley bolt, etc. I want an S54 housing eventually anyway, so I'm leaving everything together and running without oil temp (or maybe running it in the pan oil drain, IDK)
                            Random engine bay shot:
                            Roy's touring was down from a dead fuel pump (fucking called it :p ), so out mine comes:
                            May as well replace this crusty thing while the pump is out:
                            Where it starts to go wrong... TRE-341 pump in the bracket...
                            Hose clamps don't fit, so Plan B: Zip ties.
                            Pump was on the wrong orientation, sock hit the fuel bowl and wouldn't go in the tank all the way... Plan C... Involves adding some more wire and other bullshit now, but it fits.
                            New Arrivals: PMAS HPX MAF + 3" housing. Supposed to be good for at least 600HP (way more than current goals) and some Ceramic "powder" from Powder365.
                            Last minute before heading to a friend's place to blast my manifold, I decide to blast the turbine housing as well... Removing that reveals this:
                            It looks like someone failed at removing the housing, had it on an angle, and tried to beat it the rest of the way off. Fuck.
                            The compressor wheel was never the prettiest thing anyway, there's a tiny bend in one of the fins, and it's pretty sandblasted.
                            I thought this was a huge wrench in my plans. I considered buying another HX35, or buying some ebay GT35, or selling off a bunch of other shit and splurging for a PT6062. In the end, I ended up buying a new compressor wheel, turbine/shaft, and a rebuild kit to rebuild this HX35. All of that together came to ~$200, which was surprisingly cheap. HX35's are component balanced, so it shouldn't need to go out for balancing afterward.
                            • ba114
                              • Sep 2015
                              • 364
                              #164
                              interesting routing of the coil wiring. I've been contemplating the same thing as i have the essentially the same setup as you (manifold, engine etc).
                              RHD OBD2 M50b25 turbo build thread:
                              http://www.r3vlimited.com/board/showthread.php?t=384800
                              • Northern
                                • 5179
                                #165
                                Last of this update:
                                Manifold masked off, ready to blast:
                                Blasted Manifold and turbine housing:
                                Sprayed
                                Brought them to work the next day to bake. I think that was a one time thing, but it worked. I'll have to invest in a free oven for this if I do it again.
                                Turbo rebuild, Old turbine/shaft and compressor removed:
                                baby snap rings for the journal bearings are a bitch to work with, but it worked out in the end
                                New Vs Old comparisons and balance marks:
                                Another pic of the bent fin on the old compressor wheel:
                                Starting to come together. Thrust bearing:
                                CHRA together...
                                Now I should mention that once I had it all together, I realized it wouldn't rotate. I took it back apart 4-5 times to remove more carbon buildup/rust off the oil/heat shield under the turbine wheel and swapped out some internal splash plate I bent for the old one, and it spins pretty nicely now.
                                All done:
                                New Orings and filters for the injectors. I bought a rebuild pack for 8, figuring I'd screw at least one up, but they send one extra anyway so I guess it was a bit of a waste.
                                Last but not least, no more hideous car tent:
                                This brings us up to sometime mid-April. Haven't done a whole lot since then, more work on the upstairs bathroom and cleaning up the back yard than anything car related.
