Northern's Sterlingsilber M52 Turbo 325is
  • Northern
    • 5072
    Quick links:
    2010-2012 - Post 2
    2013-2014 - Post 3
    2015 - Post 23 - Mid Engine Swap
    2016 - Post 145 - Mid Turbo install
    2017 - Post 259 - Ramblings of a student continue thru 2019
    2020 - Post 321 - Vband/charge pipe/downpipe/EBC/Injector/BOV re-do
    2021 - Post 346 - Will update this text once something happens...
    Quick build List:
    Chassis
    1990 325iS 2 door Canadian Spec, Production 11-02-89.
    Exterior: Sterlingsilber - 244
    Interior: Schwarz Leder - 0203
    Factory Options
    209 Limited Slip Differential (25%) Sperrdifferential 25%
    226 Sports Suspension Settings Sportliche Fahrwerksabstimmung
    281 Lt/aly Wheels Round Spoke Styling,chrome Lm Raeder/rundspeiche Verchromt
    324 Lt/aly Wheels Ellopsoid Sp.107/mixed Tyr Lm Raeder Ellipsoidsp. 107/mischb.
    401 Sliding/vent Roof, Electric Schiebe-hebedach, Elektrisch
    410 Window Lifts, Electric At Front Fensterheber, Elektrisch Vorn
    464 Skibag Skisack
    481 Sport Seats F Driver/front Passenger Sportsitze Fuer Fahrer/beifahrer
    494 Seat Heating F Driver/front Passenger Sitzheizung Fuer Fahrer/beifahrer
    530 Air Conditioning Klimaanlage
    540 Cruise Control Geschwindigkeitsregelung
    551 Bordcomputer Ii Mit Fernbedienung
    562 . Auxiliary Headlights Zusatzscheinwerfer
    675 Sound System
    708 M Sportlenkrad Leder
    835 (Maybe "US Tourist Version"?)
    838 Canadian Version Kanada-ausfuehrung
    841 Option Code Package Pseudo-code-no. Sa-paket-pseudo-schl.-nr.
    940 Special Request Equipment Sonderwunsch Ausstattung
    Interior
    Black Leather/Heated Sport Interior
    Mtech II wheel
    Momo leather shift knob
    E36 ebrake handle + Leather boot
    Exterior
    iS front/rear lip/spoiler
    Depo Smileys + LED low beams + Light smoke laminx
    Euro Trim
    Euro Grilles
    Abrahams Motorsport smoked turn signal lenses
    Antenna delete plug
    Euro rear plate filler
    Engine
    1999 M52B28 from an E36 328ic off Texas Copart
    Unopened longblock, all other gaskets replaced, block drilled for turbo oil return
    Deleted: SAP, Post Cat O2, Second bank O2, Running losses valve + harness thinned
    N5x exhaust studs
    M50 Intake Manifold + TB
    Maximum PSI Intake boot + ICV Hoses
    TheArcAsylum rear sump 24v oil pan, tubular subframe, oil pickup
    Tacked Oil pump nut
    Management
    Siemens MS41.1 Hardware (stock NA spec M52B28 ECU)
    Custom MS41.3 firmware by mrf582 (in closed beta test)
    PMAS HPX MAF (Blow Thru)
    GM LS3 MAP - logging with ECU thru Bank 1 Rear O2
    Innovate LC-1 Wideband O2 (logging with ECU thru Bank 2 O2, also for GFB GForce III lean cut)
    Single channel Narrowband O2 for stock ECU STFT
    540cc Bosch 0280158117 EV14 Injectors
    M50 Fuel Rail w/ Injector Hats
    TRE walbro 255 knockoff fuel pump
    Tuning/Logging
    INPA K+DCAN cable
    OBD2 port wired into harness by ECU
    Bench flashing harness from spare engine harness
    MS41 Quickflash
    Romraider ECU Editor, Logger
    Romraider Definitions downloaded from MS41 ECU Portal by mrf452
    Megalogviewer HD
    Future:
    ALDL Droid for logging/gauges via android, made possible by Murray (ba114).
    Currently RAM address for Load is different/unknown for the MS41.3 flash.
    Logger.S by Sorek for standalone logging to SD and Bluetooth broadcast to ALDL Droid, with 4 analog inputs, ++.
    Cooling
    Z3 M Coupe Aluminum Radiator
    Stock 88degC Thermostat
    Aluminum Thermostat Housing
    Deleted TB Heater circuit - Coolant Pipe port crushed/welded, Head port used for e30 cluster sensor
    Spal 16" slim pusher fan
    82deg Aux Fan switch Mercedes PN: 61-31-1-364-272-82
    Turbo
    Borg Warner S257 SX-E Turbo + 90 degree bend on compressor outlet
    AGP Turbo T3-to-Vband 0.82 A/R Turbine Housing + ebay turbo blanket
    Rapidspool E30 24v Manifold - Ceramic coated black
    Tial MVR 44mm Wastegate (7.25lb spring) + Screamer pipe
    Knockoff HKS SSQV
    GoFastBits G-Force III Electronic Boost Controller with AFR input
    Exhaust
    3" 304 Stainless
    MIG'd w/ 308L Wire or Tig with 308L filler
    AGPTurbo Turbine Housing Vband + Clamp
    2x Vibrant 1491 3" 304 Vband assy - end of downpipe, and pre-muffler
    Yonaka 3" 304 Flex Section
    Vibrant 1047 Streetpower 3" Muffler
    Vibrant 1142 Ultra Quiet 3" Resonator
    Custom hangers to ZF Trans mount, Rear subframe, Left Rear frame rail.
    Driveline
    ZF320 from same donor as engine
    Full shift detent service, input seal, selector seal & joint.
    FX Racing Stage 3 Chromoly flywheel+Clutch
    New OEM TOB & pivot pin
    New 328i slave cylinder
    Ireland Engineering SS clutch line
    Full shifter overhaul, solid shift carrier bushings, shoddy ebay short shifter
    New E30 CSB
    2.93 4-clutch LSD - RacingDiffs 4 clutch upgrade + Billet carrier cap. SKF Carrier bearings/races.
    Brakes
    E30 325iX booster + master + reservoir. Spacer removed, rod shortened & threaded
    Stock Girling Calipers
    Pagid OE Pads
    Brembo/cheapo blank rotors
    New Ebrake hardware/shoes/cables
    BMA Stainless "DOT Approved" lines
    Suspension/Steering
    German Engineering group buy coilover conversion (Hyperco springs, aluminum adjusters) 450lb/in Front, 650lb/in Rear.
    Koni 8610-1437RACE in 1" shortened housings+spacers under insert
    Koni 8041-1026 Sport Rear Shocks (Top Adjustable)
    Ground Control Race camber/caster plates front
    Ground Control Race adjustable spherical RSMs (12mm ⌀ for top adjustable shocks)
    Added front swaybar tabs to strut (not currently used)
    Ireland Engineering 25mm hollow front swaybar
    THR Eyeball CABs
    Garagistic delrin subframe riser bushings
    AKG delrin diff mount
    Revshift 95a RTABs
    Front Subframe Arc Asylum 24v Rear Sump, Flipped sway bar, reinforced.
    Rear Subframe Reinforced at diff mounting bolts.
    E36 328i 3.2 LTL Steering rack swap w/ solid steering guibo
    Wheels/Tires
    ESM 007 "CCW Reps": 16x8 ET20 Front (ET8 with 12mm spacer), 16x9 ET15 Rear
    Hubcentric Rings
    225/45R16 Toyo T1R Front
    245/45R16 Toyo T1R Rear
    Motorsport Hardware Stud conversion
    Motorsport Hardware Aluminum tuner nuts
    Originally posted by priapism
    Originally posted by shameson
  • Northern
    • 5072
    October 2010:
    Well I suppose its about time I posted this. I had been looking for a late model 325is 5-speed E30 with black sport seats in good condition for almost a year now. Around the beginning of October I finally caved and picked up this gem. Its been my faithful DD ever since...
    246k on the clock, with all original parts or oem replacements except shift knob and head unit/amp. All maintenance was done 10k before I bought it(with receipts and records), including a replacement water pump and the owner had a reputation of treating his cars extremely well.
    I believe he originally bought the car for weekend track use, but it mostly sat in his garage for the past 3-5 years.
    "Major" issues are:
    Two rust holes at the back(see pics)
    Obliterated differential mount
    Broken rear defrost
    AC needs rebuild or charge
    Old/cracked tires
    I guess that's enough yapping, on to the pics!
    Interior: Black heated sport seats, with M-Tech II steering wheel
    After a wash:
    Aaaaaand the ugly:
    So far, I've painted all of the fading black plastic bits and bumper strips back to a Matte black, smoked the side markers and front turn signals, installed the mandatory europlate, and installed some euro smiley headlights and wired the city lights. "is" lip and rear euro plate filler in the mail.
    More recent pics to come soon...
    At the time, my future plans for the car...
    Thinking about lots of things. It needs a few maintenance items and I need a new job for the short term. Lots of ideas for the long term though
    E36/z3 steering rack swap
    5-lug swap for better brakes, and more wheel selection
    Billy sports and H&R sport/race springs maybe with drop hats (with skidplate since I already scrape pan on speedbumps now)
    Wiiiide wheels after 5-lug swap (Think BBS RS, RX, RGS, or almost whatever comes up in a size I want)
    Boost with a 2.8 m20 budget stroker or some sort of mild swap.
    Paint (same colour)
    I'm also going to be looking next year for either a cheap e30 IX for a winter car, or an e34/e39 5-series touring as more of a highway/parts hauler.
    All of this has changed in one way or another...
    April 2011
    spring update:
    Lots of little changes since fall...
    This is how it spent most of the winter
    Today $200 worth of parts are now in:
    Radiator fan clutch
    Fuel Filter
    Hood shock
    Exhaust hanger
    z3 M-Coupe re-enforced differential mount
    As she sits, with the proper new "is" lip and euro plate filler from blunttech on:
    Goals for the E30 summer:
    Fix the big rust spots, cut + new metal + POR-15 the hell out of them
    Fix broken things/maintenance
    Moar low. FK HT 60/40 / front 10mm drop hats
    Fab and install skidplate
    Rear spacers.
    Replace Hawk HP+ brakes, because they drive me insane.
    Big wrench for the fan clutch. It is the size of my GF's arm...
    September 2011 - Note that I'm ashamed of the following bodywork. It is bad, and I still feel bad.
    First update since may... about four months ago.
    Started assessing rust in the rear drivers wheelwell... it was pretty bad.
    rotten section cut out:
    "New" section from Roy's parts car goes on:
    Halfway through some body work:
    After that, safety inspection, and some paint, I picked up some used Thule bars, feet, and bike rails:
    Also ordered some H&R Race springs from Blunttech.
    Comparison to stock 325is sport springs:
    Height before:
    In progress:
    Height just after install:
    No pics of suspension settled, but here are some bonus shots:
    March 2012
    First update in forever. Once winter hit I picked up some studded 195/70/14s to replace the bald 195/60/14 potenzas that were on the car. Rolled the lips and they still catch and scrape. I absolutely hate how they make the car feel like a truck, so I'm just trying to motivate myself to do some work so I can get into summer mode.
    First of winter pic:
    Up until mid march I hadn't really done anything on the car other than receive a few parts, Throw in new alu/poly motor mounts and after a few changes to them, they worked out well. (previously dented the hood with the motor/too tall/pain in the ass to install, etc) Also threw in some HIDs in my fogs.
    Over march break I decided I would finally change my subframe bushings, Trailing arm bushings, and differential mount. This is probably one of the biggest jobs that normally needs to be done to the car aside from a motor swap so I was pretty apprehensive to start it more or less alone. I'll keep the talking brief, and let the pics tell the story...
    Detaching everything associated with the subframe/trailing arms/diff:
    Ebrake cable removed from rear hub. I've never seen a picture of this, and descriptions I've heard are severely lacking, not saying that the cable liner is press fit into the hub or that it is supposed to be removed with the cable.
    Differential removed. Heavy as hell.
    Subframe and Trailing Arms finally off after dealing with aluminum sleeves corroded onto steel chassis...
    Vacant.
    New bushings in:
    I have to make a note about this. I ordered these bushings from Lencas on r3vlimited who makes bushing kits of 75a poly, 90a poly, or a solid material ertalon. After I ordered these bushings, there were multiple issues reported with fitment of the 75a bushings as they don't machine well because of how soft they are, and the solid ertalon ones tend to crack and fail over short periods of time. I ordered a 90a kit of all bushings and mounts other than steering flex disc and driveshaft flex disc, and after I installed his motor mounts I was pretty scared to try the rest. The Diff mount went in without a hitch, and seems to be staying in place so far, and the subframe bushings fit with the use of a BFH, but the trailing arm bushings were not very consistent in their size at all and I had to go at them with a caliper and olfa knife to even them out and get the sizing close enough that I could bash them in place with the BFH.
    Cliffs: Don't buy this trash.
    Raising the subframe up and lining up the holes just perfect proved to be a nightmare, but with a lot of adjustment, shimming, a long punch and a BFH it eventually came together.
    Subframe bolted on and torqued to 103 ft-lb
    At this point the pics end because I had to call Roy and get help to reinstall the diff. Weight was the biggest factor, but alignment between the 4 holes from the subframe and the body mount proved to be difficult as hell. Eventually it went back on, we wired everything back up, bled the brakes and we were good to go.
    Mid way through the week, I received some not so gently used 15x7 et20 BBS RZ wheels which I've been working on. (not my pic)
    Also received these:
    Installed the rears, they feel great. stockers that came out had no rebound at all.
    Will install the fronts as soon as I can install the camber plates, which happens to be when the new wheels with summer tires go on.
    Around this time, I also installed some euro bumper trim...
    May 2012 - M52 #1
    Little update/pics/teaser...
    Went down to truro yesterday to grab something...
    Then snapped a few pics:
    Threw in my offset Poly control arm bushings on saturday, then the front billy sports + camber plates on sunday night, and it feels like a different car now. no more terrible bumps or pulling to the side when braking.
    Trying to figure out how many spring pads I need to keep before I take pics, but I'll figure it out tonight/tomorrow.
    Ireland Engineering hinge-less front strut bar on order, along with some 24v maintenance parts.
    Still need bigger swaybars, and maybe change to a better designed camber plate (Ground Control or Vorshlag)
    I think my mod list for the m52 is pretty close to being finalized(incoming jargon):
    M50 intake manifold
    3.5"HFM
    Ricer cone or equivalent
    software - tune + EWSII delete, post-cat O2 delete, secondary air injection delete, ASC-T delete etc.
    Crank scraper
    VAC e34 oil pan baffle
    S52 Cams
    underdrive pulleys
    supersprint rep headers + 2.5" catless exhaust 1 resonator, 1 muffler
    I'll try to dig up some info on this setup as there is nothing out of the ordinary with any of this stuff. I've seen dynos from anywhere between 225-250 hp with relatively similar setups.
    End of embarassing excerpt from a previous build thread. M52 swap was aborted at some point, and eventually gave then engine and E34 pan to roy when his M50 seized. It never ran right and now sits at the back of the garage at his place.
    Where the car stood at the end of 2012:
    Stock M20
    90a "Lencas" offset CABs, RTABS, subframe/diff/engine mounts - Garbage.
    IE RSMs
    Billy Sports
    H&R Race
    Ebay "Poland" camber plates - Garbage. Spring bind if the strut nut is tight, bearings wear out monthly, don't fit spring perch, etc.
    Ebay short shifter
    Euro trim
    Depo smileys
    Ebay H3 HID kit for fogs (ugh)
    Faux Staggered BBS RZ320/378 painted too dark and very bent.
    Probably some stuff I missed
    • Northern
      • 5072
      2012-October 2014
      I really don't remember 2013 very well, but here goes:
      Did a cruise with the local VW guys...
      Picked up a grey market '87 iX and a Mazda 3 Sport at one point when money was pretty loose, but I'll save that for another time other than this pic:
      Used "Trim Brite" to shadowline the windows, and while it didn't do the worst job, I'd probably buy OEM shadowline trim next time. It wrinkles pretty easily, and the roofracks don't like it. Also installed some MHW turn signal lenses with orange bulbs from Abrahams motorsport around this time.
      Sometime in here I picked up an IE catback to replace the straight pipes I ran for the month between my muffler finally rotting out and the new one arriving. Picked up a new exhaust hanger kit as well, but one of those has already snapped off.
      Pic of my two, with Roysneon's M5x swapped, E30m3 5-lugged, Staggered forged Msystems wearing RHD Touring.
      Picked up some GE coils and some Bilstein iX HD's (these went in the iX)
      Did some AutoX for the first time, had loads of fun.
      Bought a house Oct 2013. Lost the garage from the apartment, but the basement/sizable shed, and partially paved back yard make up for it for now...
      After a night of heavy drinking with Roy, I bought a set of ESM 007 16x8/9 staggered wheels, and picked up some 225/45R16 Falken FK452s through Roy's hookups.
      Then picked up some MH Nuts for the studs I was hiding under the centrecaps
      Random Pic:
      Bought a set of GC race plates and RSMs after seeing a set in person, and installed some Konis as well. Feels way better than the bilsteins ever did.
      Did an intake gasket refresh at the beginning of this year + new M50 injectors, VC gasket, vac/fuel lines, and coolant temp sensor to try to combat a rough idle the car has always suffered from:
      Did some more AutoX this year, and was given some 14" R888s that I threw on my old weaves
      Swapped in a 60% lockup diff that I bought off a local guy who was parting his Euro S50 swapped car. Feels really good under power through corners, but makes a lot more noise on tight, slow turns. It came with an AKG 75D diff bushing, and I added some studs and spacers to try to compensate for the lencas bushings being unintentional ~5mm subframe risers. While I was in there, I ran new wires and connector from inside the car down to the diff. The OEM setup had rotted off the car and I was using butt connectors as female pins for ~2 years now.
      Random Pic:
      Thought I had a bent control arm, so I bought some THR Eyeballs to get rid of the lencas CABs, new lemforder control arms, tie rods, lock plates, e36 rack from the E36 in the last post, and shortened the steering knuckle with a solid steering giubo. Also decided to re-hose the low pressure lines in since they leaked badly, and install the e36 reservoir.
      Hit 300k(KM):
      Trolled r3v facebook:
      Then all hell breaks loose one friday leaving work:
      The car felt down on power after making a loud "Ping" noise. All the spark plugs were in(I've seen many people post about them unthreading and shooting out, describing similar noises) but it didn't seem to want to turn over.
      After I turned it over a few times, we figured out that the bottom end was spinning (fan clutch would spin) but there was no compression.
      At that point it was pretty obvious:
      Head was garbage, so I pulled the head off a parts engine. Briefly thought about a 3.1L MM-non interference pistoned stroker with a schrick 288, ITBs, etc, but I'm not made of money, plus the parts head had oiling issues, so cam, and all rocker arms are pretty much garbage, cam journal is worn and gouged, valve guides were trash, and the head is like 0.020" from flat (estimating by eye on a precision granite.)
      Lots of stuff changed between the ideas in the previous post and reality:
      M52 swap was canned after I couldn't decide on mods, or why not S52, S54, V8, K20 lol. Eventually Roy's car had that M52 for a brief time, and now it sits.
      5 Lug has been off the table for a while, but something along the lines of an IE or Massive BBK may happen in the distant future.
      I no longer believe in POR15.
      Rear rust and front jacking points are still in need of serious love.
      Z3M diff mount is in my basement still.
      Broken rear defrost is staying broken because I don't care.
      AC is probably going to be uninstalled and blanked off at the firewall since I haven't had it in so long that I don't care right now.
      Car needs paint more now than ever before.
      Hawk HP+ are loud brake pads, but they bite like crazy. Hawk HPS are quiet, but have no bite at all.
      I need new subframe bushings and RTABS. Thinking Condor subframe risers to match the solid diff mount, and OEM RTABs because there is no reason to go poly there.
      I need shorter Konis up front to cut my housings.
      16x8 and 16x9 staggered sucks. I wish I went 16x9 square, because the tires look weird front to back. (Couldn't find 205/50 and 225/45 in the same tire, which also further reinforces that 16's on an e30 sucks to find tires for)
      M20 rebuild is tentatively off the table, and I'm going to look at another cheap M52 tomorrow.
      • Northern
        • 5072
        reserved3
        • Northern
          • 5072
          Reserved4
          • G FORCE
            • Mar 2014
            • 157
            Looks great! Sub'd! Keep up the good work!
            Gabe
            '91 318is
            • phreshkid
              • 4655
              Still my all time favorite color on an e30.
              Thank you for saving her. She will repay you with many accidental children.
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                I'm liking it good car dude
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                • ttrousdell
                  • Nov 2009
                  • 1770
                  I love everything about this car. looks good from the pics. I just went through trying to get tires for 16s. pain in the balls.
                  The Build:
                  • TimKninja
                    • 2131
                    Never did the timing belt?
                    I really like this build thread tho, I need to do that same rust treatment to my battery box. Did you not seam Seal it or anything afterwords?
                    1985 325e M50TU(Sold)
                    1991 318is Slicktop (Sold)
                    1990 325is Brilliantrot S50/5 Lug Swapped.
                    1992 525i Manual shitbox Winter Beater
                    • Cabriolet
                      • 9620
                      Northern, only use rubber engine mounts on your street car. it protects the engine from harsh bumps. engines dont like hitting pot holes, there arent pot holes, man hole covers on tracks and that is why sold engine/trans mounts are made for.
                      Much wow
                      I hate 4 doors
                      • efficient
                        • Feb 2012
                        • 3312
                        lol i always thought the guy in your avatar was you.
                        clean car
                        • Northern
                          • 5072
                          Thanks for the kind words guys, and no, I'm not Earl :p
                          The records show the timing belt was done the summer that I bought the car by a reputable (but very expensive) independent shop, but I stupidly lost track of how long it had been. When it finally snapped, I think I was less than a year over the 4-year interval, with only ~65k(km) on it.
                          I didn't seam seal it, but I covered everything in POR15 and thought (wrongly) that that would be enough at the time. Sometime in the next 3 years it should be getting some serious love body-wise.
                          When the M52 goes in, I'm seriously considering the condor swap mounts. I haven't been in swapped cars with anything else, but those and AKG seem to be the only mounts that don't have tearing/failure issues.
                          Since the Condor mounts are half the price, are available through blunt, and I know what they'll feel like, I'm going to take the chance.
                          Speaking of M52's, here's what I scored last weekend:
                          M52b28+ZF320 out of a 1998 e36 vert. This engine was for sale on the tiny local BMW facebook group for a month or more, and in the Ad's pictures it looked terrible.
                          Eventually, Roy and I went to look at it I noticed that it was in amazing shape (rust wise) and eventually figured out it was pulled from a wrecked texas car that I almost purchased for $800 last year.
                          $250 and some brute force & ignorance, and it was in the "Truck". The jack on the hoist was dead, so to get it out I went to Princess Auto (Canadian equivalent of Harbour Freight) and exchanged it for a new jack.
                          Rough Draft Plans for the present are:
                          1: Quick, but through refresh for the M52 + most swap parts order through Blunt
                          2: Oil Pan...
                          3: Find a late e32 booster + 25mm master (preferably, but I'll take what I can get)
                          4: Maybe ZF320 detent pins/seals/FX racing single mass flywheel/clutch, but I'll probably hold off for now and deal with pulling the trans again in the future.
                          5: DIY EWS delete once it is all together. I have the EWS parts to keep it in the meantime.
                          • efficient
                            • Feb 2012
                            • 3312
                            i don't even know who that guy is until i googled him
                            • Northern
                              • 5072
                              Late last week, I accidentally bought an E32 or iX booster off ebay (not sure which it is, but the capped off reservoir and vacuum port spot look like an E32, so here's hoping.
                              I found a spare M52 oilpan in my shed (surprise) and stole the subframe off one of Roy's project cars this weekend. Chopped up the subframe for some reason...
                              I have to place a decent order through blunt soon, I'm just too lazy to make a real spreadsheet to send him at this point.
