Classic Daily E46 M3 cammed LS3 Swap
  • jakeb
    • 1909
    This project is actually running and driving now but I will post the build over a few posts and get it up to date.
    Here is the victim. Already has stoptech brakes, coil overs, ground control sways, te37 wheels, super sprint exhaust etc etc
    On a lift coming apart
    This is getting a 0 mile 525hp GM Perforamance Parts LS3 with a built t56 magnum from D&D Performance.
    lightweight flywheel
    Engine in (using vorshlag headers)
    More to come soon
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • Dylanhat
    • May 2013
    • 557
    Holy moly
    Neue Motorsports: http://www.neuemotorsports.com/
    Instagram: https://instagram.com/neuemotorsports/
    • TimeMachinE30
      • Jun 2014
      • 3749
      Original engine fail?
      And the new engine you chose how? Had it laying around?
      Cool stuff.
      ACS S3 Build / Dinan 5 E34
      • M-technik-3
        • 18946
        Wow S54 performance just wasn't enough huh. Wonder what weight distribution will be with two less cylinders in front of the axle but add two extra pistons.
        • jakeb
          • 1909
          Cool stuff.
          Nope original engine was fine...it's actually going into an e21. New engine was bought for the project. I build these sort of cars for others.
          It will be a track car for the customer and before this he had a 600whp Dodge. But he wanted something a bit lighter and track worthy. I am VERY interested to see how the weight distribution is as well. There is a TON of room between the front of the engine and the radiator.
          It's actually already running....
          • TimeMachinE30
            • Jun 2014
            • 3749
            You're fast.
            • E30 Wagen
              • Jul 2005
              • 3428
              Hire me and teach me your ways. I want to quit my current job so bad.
              My Feedback
              • jakeb
                • 1909
                The e46 is know to have issue with the floors cracking or ripping out so it's best to add some reinforcements. We went with the plates from redish Motorsports out of the UK. These are nothing short of amazing. REALLY well designed.
                Start by cleaning all the undercoating off.
                The plates
                weld/bend/weld
                Smooth out and put etching bare metal prep on them.
                [img]
                POR and seem sealer
                Then undercoating
                Rear subframe also got new poly bushings
                subframe back in
                  • 37829
                  Wow that is bad ass! That sound...
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    This is awesome
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • Mlarsen
                      • 4082
                      Very awesome setup! Is there much wiggle room in the engine bay or is it pretty tight fitting?
                      • jakeb
                        • 1909
                        On the drivers side yes but other than that not really.
                        • DER E30
                          • Sep 2013
                          • 2349
                          Killer work! I want an LS3!
                          -Christian
                          • E30NJ
                            • Aug 2013
                            • 921
                            Tight setup!
                            • ngampleh
                              • Jul 2012
                              • 466
                              Awesome e46 setup !!!
                              [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
                              [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
                              Transaction Feedback
