3MPowered's Euro S50 E30
  • King Mufasa
    • Sep 2012
    • 530
    #61
    I like:D:D:D
    • 3MPowered
      • Nov 2014
      • 58
      #62
      Originally posted by stanhayward
      Beautiful exhaust! I live in Victoria now and will be coming over to the mainland the 30th, if you're down I always like meeting people in person and seeing their cars.
      Sure thing! Float me a PM when you're in town and we can meet up for a cruise if you like.
      Avusblau 1994 M3 - DEAD
      Lagunagrün 1991 331iS --> Journal Here
      • allmotorguy
        • Dec 2013
        • 17
        #63
        Awesome car, and S50 Euro engine=dream. :))
        Do you have some video?
        I want so badly to hear and see how your beast accelarates and goes.
        • 2mAn
          Señior Mod
          • 21088
          #64
          What radiator are you using? With a late model, many people will use the E36 radiator options, including the MZ3 which seems to be the best of them all.... I wouldnt know because I use a M42 radiator and live in the traffic infested Los Angeles area. With a Spal puller fan operating independently of everything else, it never lets my temps go over halfway. It works pretty hard though at times. Not ideal, but my '84 has a slightly different radiator mounting setup so I cant really use the bigger radiators.
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • Eric
            • 5142
            #65
            Try a new overflow cap too!
            • burkey001
              • Feb 2011
              • 608
              #66
              awesome work, all you need now is a carbon airbox that will clear the booster!
              if only someone had one for sale..... ;)
              88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
              90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
              • 3MPowered
                • Nov 2014
                • 58
                #67
                I'm using an all aluminum E36 radiator a friend gave me. He wasn't sure if it held water, but I tried it out anyways. It may be the culprit, but it will be the second-to-last thing I change if nothing else works (the last thing being the water pump).
                I still have the M42 radiator at my disposal, so I could always try that first if nothing else prevails.
                I would figure as long as the reservoir is pressurized after a long drive then it's working. Is that not correct?
                A CF airbox would be awesome! I ended up ditching the brake booster in favour of manual brakes. No airbox modification necessary. The pedal stiffness is an acquired taste but it is possible to acclimatize to it.
                I'll try and get a video of it driving while the weather cooperates. It's bloody loud...
                • 3MPowered
                  • Nov 2014
                  • 58
                  #68
                  A couple recent shots
                  • 3MPowered
                    • Nov 2014
                    • 58
                    #69
                    Update: March 26, 2016
                    Just a quick update on the E30:
                    We recently moved house, which meant time for the E30 dropped off to zero. In light of this, I thought I'd take the car into to a local shop that knows this engine (and mine in particular since it was rebuilt there a few years ago) to have the remaining issues sorted out. Work performed included:
                    - Fixing the overcooling/overheating issue
                    - Replacing rear subframe and trailing arm bushings with poly-bushes
                    - Fix overfilling issue at all engine temps
                    - Run a fault code diagnostic
                    After all was said and done, the car runs beautifully. It pulls much harder throughout the rev range and has a rock solid idle that doesn't burp, splutter, or chortle. It's an absolute blast to drive and I can't wait for the first road trips of the year!
                    I've also got a new set of wheels coming that will require a bit of a refurb and will allow me to finally fit the BBK I've been sitting on since I started the engine swap.
                    A couple of recent shots to prove the car still exists:
                    The Rabbit has also been providing some daily enjoyment. It's amazing what 30HP can feel like when hustled:
                    Cheeky shot next to this behemoth:
                    • goarmy
                      • Nov 2011
                      • 622
                      #70
                      Do you know if the Euro section 1 exhaust fits in the e30?
                      • 3MPowered
                        • Nov 2014
                        • 58
                        #71
                        It will, but would still require substantial reworking of the headers.
                        • dhithim
                          • Mar 2016
                          • 48
                          #72
                          Excellent build sir.
                          IG: Dhithim
                          2015 Subaru BRZ 380whp
                          My '87 Project
                          http://www.r3vlimited.com/board/showthread.php?t=382462
                          • frantic
                            • Mar 2008
                            • 62
                            #73
                            Nice build. What are the specs on the wheels and what spacers? I have a BBK too, and want to go back to a weave wheel but want to limit how much spacer I use.
                            • Eric
                              • 5142
                              #74
                              What muffler & tips are those? They look neat!
                              • Sh3rpak!ng
                                • Jan 2014
                                • 2667
                                #75
                                excellent build! I remember drooling over your e36m3 a while back when I was e36 obsessed on bimmerforums. Sorry to see it got wrecked, but I am very glad to see its essence has been preserved in the e30!
                                Shadetree30
