IIRC the b34 and b35 blocks are different, so I doubt it.
M30 OEM Turbo project
Yea mine does. Kronus I believe you mean driver? Cause if garagistics m30 mounts look nothing like qbangs b34 mounts.Comment
Got some things done today.
Mounted a 10lb CO2 Insurance Policy in my spare tire well
Then I fit my new K&N air filter in its home. I needed an additional 90* elbow to make it work, but it seems to be fitting well. The filter itself is 3.5" in diameter and 6" long (looks much smaller in the picture because of the angle). I also have a 3.5x10" filter but it's just too big to fit. Hopefully this one flows enough because it's literally the biggest I can fit in this space.
Of course the Intercooler and intake piping sit pretty high, which means the hood couldn't close with the stock insulation. So out it came
Unfortunately that leaves this super ugly residue to stare at, so I'm going to buy a new set of the OEM 3-piece foam to stick there, and then cut out where I need the full amount of clearance
The silicone hoses are literally touching the hood when it's closed. It actually is messing up the alignment a bit. Not a huge deal, but I'll see if it can make it a little better.
so close now... can you get some pics of the whole engine bay?I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts.Comment
Nice tight!!! I thought I had a tight fit with my project. I also would to see a complete engine bay shot.Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
DSC04926 by Raul Salinas, on Flickr
DSC03413 by Raul Salinas, on Flickr
Yep I think I'll be doing a regular intercooler setup How does one change spark plugs? so crampedComment
