Best guess is 1-2 weeks. Some of the parts they had to order from The Fatherland, so that pushed out completion by a bit.
M30 OEM Turbo project
I bet I could put together an adapter for you. I do have access to lots of equipment (4k watt laser, CNC mills, etc...). Got pics of an adapter someone else has made?Comment
Sadly no, so far all I've come up with is that CAD drawing that shows the dimensions of the OEM valve and mounting plate. The tricky parts to figure out are 1) can any of the aftermarket WGs be separated, i.e. remove the elbow from the spring/diaphragm/valve assembly? and 2) How long is the valve stem and what is it's movement range from open to closed? Machining an adapter isn't too hard, but the other part involves me buying a $350 WG and then proceeding to tear it apart and possibly destroy it...Comment
Just buy something like this and save a few bucks.
http://m.ebay.com/itm/tial-38mm-turb...%257Ciid%253A4
I have a 44mm that just laying around for parts but will be to big for your applicationComment
My EBC setup arrived from DIYAutoTune yesterday. The setup is super easy. Since I still don't have the Tial adapter, I'm going to have to put the stock WG back on for now, hence the single-port configuration:
The kit comes with 1/8" barbed fittings, but my lines are 3/16", so I had to get a couple of new fittings
All installed, along with a plug for the unused port.
And mounted on the old airbag sensor bracket in a vibration-resistant clamp.
There are only 2 wires to connect. One goes to a switched 12V source, the other to the COM port on the back of the ECU. Easy!Comment
that is seriously sweet looking. built to last.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts.Comment
all balanced? how were the parts marked?I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
You can see the red paint on the compressor wheel. I have some more photos of the complete, assembled unit with all the balancing marks, but photobucket is being a little bitch right now and I can't seem to upload them.
Interestingly, they applied ceramic coating to the exhaust housing even though I'd already had that done. So now there's two layers of coating on the housing, plus a turbo blanket. If this doesn't keep down the underhood temps, nothing will! Add in the coating on the CHRA, the new heatshields, exhaust coating, and exhaust wrap, and this thing should be as insulated as humanly possible :up:Comment
beautiful man. my favorite turbo build. nothing comes close.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Have you gone to a front mount intercooler?Comment
