Tina the '88 325ix
  • 6A LDY
    • Jul 2014
    • 318
    #46
    thanks for all the help bob!
    1988 325iX - sold but not forgotten
    1984 MTech1 323i
    • stonea
      • 2892
      #47
      +1 on the ZHP knob, I've heard good things about condor, but I'd rather rock a ZHP
      My Garage
      Feedback
      Instagram: Stone.Hopkins
      • 6A LDY
        • Jul 2014
        • 318
        #48
        I'm moving to upstate NY on saturday and the car is staying in north central MA about 3 hours away. Tomorrow is my last day working on the car for a little bit so I'm going to try to get it back on her wheels.
        I re-installed the rear subframe today pretty easily and connected the brake lines and the abs sensor. Now all I have to do are put together the parking brakes and re install the calipers. Also swapped out the front rubber lines for stainless steel lines. Once I bleed the brakes and reinstall the exhaust, she should be god to go for a quick drive!
        Hopefully I can wrap it up tomorrow and get everything packed for NY
        1984 MTech1 323i
        • 6A LDY
          • Jul 2014
          • 318
          #49
          Subframe is back in with the new springs and koni single adjustables, it went in surprisingly easy
          Here's more or less how it sits for now until it settles out
          I was going to take it for a spin, but I undid the collar nut on the driveshaft too far and now its stuck in the u-joint side spline housing. Next mission will be fixing that or replacing the drive shaft and then the front suspension. Already have the struts and springs, but I need to buy some new strut mounts and maybe some CABs while im at it.
          1984 MTech1 323i
          • 6A LDY
            • Jul 2014
            • 318
            #50
            Haven't updated this in a long time, but I've been busy
            Installed:
            m3 solid offset CABs,
            H&R front springs
            Koni sport SA struts
            Gates racing belt
            New water pump and thermostat
            New FPR and fuel vacuum line
            The right front strut housing threads were completely gone so I cut off the threaded section from a non-ix strut and welded it onto mine and its good as new.
            Bled the brakes, and got her running again. I didn't try to drive it, just gave it some throttle from the throttle body
            She's running a little rough right now, wandering idle and the throttle takes about a second to respond when I blip it. I think part of it is the fact that I've had the battery unplugged for so long, but I think there's something else up. Next up is checking fuel pressure and looking for vacuum leaks
            1984 MTech1 323i
            • FreedomM3
              • Aug 2015
              • 191
              #51
              When you get that idle fixed let me know what you did. I currently have the same situation, maybe not as bad. I replaced the cap, rotor and plugs. I need to adjust the valves.
              Love the ix, wish I had the budget to do one now too. Maybe once I get my current bronzit where I want it.
              There's a coupe for sale locally that seems like a good project. Keep up the good work!
              Our RestoMod Diary!
              El Mustache De La Resistance!
              • audiquattrot
                • May 2008
                • 3836
                #52
                Wandering idle for my ix was icv and afm. Had to replace icv w a new one bc cleaning it made no difference. Couple months later the afm went haywire, and replaced it w a known used good one. Idles perfectly now. Check for vac leaks too
                www.instagram.com/snwmble
                #snwmble
                Current:
                '05 BMW M3 - Silver Grey/Imola Red
                '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
                '15 Mini Countryman - Blazing Red/Carbon Black
                Past:
                '01 Audi Allroad - Light Silver/Platinum Saber Black
                '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
                '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
                '90 BMW 325i - Schwarz/Tan sport *Sold*
                '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
                • stonea
                  • 2892
                  #53
                  Mine was afm too
                  Sent from my SM-G920V using Tapatalk
                  My Garage
                  Feedback
                  • 6A LDY
                    • Jul 2014
                    • 318
                    #54
                    Yeah I have cleaned the ICV out and tested it and it seems like it's working. Im betting it's a combo of fuel pressure, vacuum leaks, and the am being on the way out based on the way the throttle responds.
                    I also spent last night rebuilding my drivers side door lock so the key actually works and I was surprised how easy it was to just figure out which tumblers to use without having the right ones already
                    The real problem for me is that the car is located 3 hours away from me so I really only get to work on every 2 weeks for a few days. It makes it hard to stay with one thing.
                    1984 MTech1 323i
                    • 6A LDY
                      • Jul 2014
                      • 318
                      #55
                      So this week I was able to come home and spend my birthday working on sorting out the rough idle. I found the culprit, it was a couple of loose aluminum elbows that connect the ICV and brake booster to the intake manifold. Sealed them up with some gasket maker and presto good as almost new. Car runs pretty smooth now and after letting it run for 30+ minutes the idle has settled out. I even took it for a little test drive and its running pretty well.
                      Also got the drivers door adjusted and seated properly. It's obviously not the door that came with the car, but it fits properly now and closes without having to jimmy it around. It's in good shape too, so I'm going to repaint it.
                      Next on the docket:
                      Rust repair in the battery box, rear floor pan, and drivers rear wheel well, a couple of touch ups
                      Cleaning and painting the rear lip spoiler, door, bumpers, and front lip
                      Plastic bumper swap
                      Freshening up and fixing the sunroof situation and blowing out the drains
                      Installing the mudflaps I got, went with the XL basic rally armor flaps
                      Figuring out why the tach and speedo dont work
                      I'm pretty confident in the drivetrain and engine now, it's time to start doing the cosmetic work and little touches to make this beast ready just in time for winter to be over
                      1984 MTech1 323i
                      • 6A LDY
                        • Jul 2014
                        • 318
                        #56
                        Here she is as of today
                        1984 MTech1 323i
