Tomorrow then?
Phoenix e30 -1987 Royalblau 4 door 24v project
Car is almost completely buttoned up. Put DS up and torqued guibo bolts to spec. Attached front CAs and tie rods. Attached front brakes. Worked on putting emergency brake crap back together. Put one of the axles in (need a new clamp for other one. Bolted up the diff bolts and diff mount. Bolted down some random shit and took out the trunk lining to clean it. Also attached the rear struts finally. Ran it again tonight and it started right up, if I jumped the fuel pump relay lol. Going to get a new relay tomorrow, finish bolting up brakes and rear suspension, tighten down a few things, and bleed all the fluids!Last edited by brshelton; 01-31-2015, 12:48 AM.Comment
starter wires were loose lawl. ordered early model csb last night and bought a coolant return hose and ordered a new oem radiator cap. gotta sort this stupid z3 shifter crap out and throw csb on and put the 200 dollars in fluids i bought in (motul gear 300 for lsd, motul multi atf for trans, ate 200 for flush, bmw coolant). its so close i can taste it. at my wits end tho just want it done. paying PimpinWalrus to finish up some of it for me... im a sell out i know.Comment
Come swap my suspension. I know you're pretty good at it. Lawl!starter wires were loose lawl. ordered early model csb last night and bought a coolant return hose and ordered a new oem radiator cap. gotta sort this stupid z3 shifter crap out and throw csb on and put the 200 dollars in fluids i bought in (motul gear 300 for lsd, motul multi atf for trans, ate 200 for flush, bmw coolant). its so close i can taste it. at my wits end tho just want it done. paying PimpinWalrus to finish up some of it for me... im a sell out i know.1974.5 Jensen Healey : 2003 330i/5Comment
