Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    #406
    I've been working on cleaning up the core support to get it ready to swap and bolt in. It's been getting pretty cold at night (though not nearly as cold as some of you guys deal with) so I decided to give this propane heater a try. It's great! My garage tent is not insulated whatsoever and not really sealed either, but I'd say this heater on low brought the temp up a good 10-15 degrees in an hour which is plenty to take the edge off the temperature. It was ~45 degrees
    Also picked up a welding cart from HF for $40. So much better having it all on a cart. I'll probably replace the casters and wheels and ad a brace on the bottom to make it a little sturdier.
    Shadetree30
    • bangn
      • Sep 2011
      • 760
      #407
      that sucks about the headliner... front and rear screen out job im afraid :( could always use a square bit of cotton tape on the back and try stretch it back to where it needs to be so it doesnt look poo
      Boris - 89 E30 325i
      84- E30 323i
      • Sh3rpak!ng
        • Jan 2014
        • 2667
        #408
        Yea, I looked up a DIY later and saw the process. Doesn't sound too bad actually but I just don't have any interest to do that right now. It's at the bottom of the list.
        Shadetree30
        • Sh3rpak!ng
          • Jan 2014
          • 2667
          #409
          So I decided that I wasn't finished modding the front subframe and I did this
          I can't take my exhaust merge section right after the headers off unless I pull the headers due to the tight space down there, so I clearanced the subframe to hopefully help. Time will tell if I cut enough in the right places. I was eyeballign it since it's off the car.
          Other side for comparison
          Shadetree30
          • Toodaloo
            • Sep 2014
            • 872
            #410
            The smiley's are depo's correct? I'm thinking about picking up a set myself
            Check out my Alpine's DEAD build thread http://www.r3vlimited.com/board/showthread.php?t=348571
            E36 M3 Build thread http://www.m3forum.net/m3forum/showthread.php?t=597637
            • Sh3rpak!ng
              • Jan 2014
              • 2667
              #411
              correct
              Shadetree30
              • Sh3rpak!ng
                • Jan 2014
                • 2667
                #412
                Got some more parts. AN fittings and hose to make an extension/remote drain for the coolant drain on the side of the block. This has been on my mind for literally years. I'll do it for both my cars and never deal with that stupid mess again.
                I've also been messing with the radiator core support. Since I have a spare in case I screw things up, I decided to try something different. I'm going to trim all of the excess metal at all of the edges, seam weld, and see what happens. Also I'll be making it removable.
                Started at the top edge
                Shadetree30
                • Sh3rpak!ng
                  • Jan 2014
                  • 2667
                  #413
                  finished a small section just to see how it would turn out. Only had like 30 minutes to work on it. I think it'll look pretty neat when it's finished
                  Shadetree30
                  • jpod999
                    • Dec 2015
                    • 1401
                    #414
                    Picture isn't working for me!
                    OBDI M62B44/6 swap
                    Transaction feedback
                    - jpod999
                    • Sh3rpak!ng
                      • Jan 2014
                      • 2667
                      #415
                      fixed! I forgot to move the photo to a public folder before I linked it
                      Shadetree30
                      • jpod999
                        • Dec 2015
                        • 1401
                        #416
                        What's your end game with that rad support?
                        OBDI M62B44/6 swap
                        - jpod999
                        • Sh3rpak!ng
                          • Jan 2014
                          • 2667
                          #417
                          Honestly I'm not really sure. I've been kinda procrastinating pulling the front end off the car by finding anything to do but that. I guess the "goal" is just to make it look cleaner. It's a pretty ugly piece and since I plan to tuck, shave, and paint my bay I figured I might as well. Also It's fun to play with the welder.
                          Shadetree30
                          • jpod999
                            • Dec 2015
                            • 1401
                            #418
                            I like it, excited to see what you come up with!
                            OBDI M62B44/6 swap
                            - jpod999
                            • Sh3rpak!ng
                              • Jan 2014
                              • 2667
                              #419
                              thanks man! me too
                              Shadetree30
                              • Toodaloo
                                • Sep 2014
                                • 872
                                #420
                                Why didn't I think of the remote drain for the block drain bolt any sooner!? Genius idea! You could totally put a kit together and sell it on r3v! Gah, wish I came up with that earlier!
