Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    #1096
    Alright. Its been decided. I really didnt want to deal with the hassle anyway. And I think itll look good with the contrast. Working on the carpet swap tonight. No sleep until its done!
    Sent from my SM-G920T using Tapatalk
    Shadetree30
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      #1097
      Got another two items off the "to do" list.
      Here's the first: rogue engineering steering wheel quick disconnect + slim NRG adapter. The whole combo added another inch to the steering wheel position which was exactly what I was looking for. I opted for a quick disconnect because I also spaced the steering wheel down a bit more and now it's a little tight getting in and out of the seat. Seating position with regards to the steering wheel and shifter are now spot on! It felt phenomenal crushing some canyons over the past weekend.
      The rogue QD is an excellent piece. It allows horn function and fit/finish are perfect. The NRG hub was a little disappointing though. It does not have provisions to allow the steering wheel to lock with key out (I see this as good), but it also does not have the brass contact ring for the horn to function properly (really irritating). It seems like a really simple function to add so I will see if I can cannibalize the part off my oem steering wheel to make it work.
      Second item off the list: install the gray carpet. I am very excited to finally have this done. Totally transformed the look of the interior. It looks like the car came with it from the factory. The color perfectly complements the rest of the interior. I was also glad to see the condition of the floor under the carpet is excellent. No rust.
      Will post some more completed interior pictures when I have the chance to take them.
      Now just hoping to sell some parts so I can buy tires and get to an autox asap! Also have all my rear brake parts ready to install when I have a free day. All in all I am very happy with the state of the car. Feels like just a small project away from reaching a good "completed" stage to plateau at for a while and concentrate on driving it and washing it.
      Lastly, had a "small" visitor scurry across the entrance to the garage. Thought it was a mouse or other small rodent out of the corner of my eye... thing was the size of my hand.
      Shadetree30
      • The_Lope7
        • Jan 2015
        • 303
        #1098
        The carpet looks awesome, way better than tan. Just curious, are you planning to keep the tan door handles and pockets or switch to black? Seems to me like that's the last piece to tie it all together.
        ▲ 1991 318is ▲ | Feedback Thread
        • Sh3rpak!ng
          • Jan 2014
          • 2667
          #1099
          The handles are actually gray. Light gray. You're right though, from the picture it does look kinda tan. Ill get som photos in daylight that should show it better.
          Shadetree30
          • The_Lope7
            • Jan 2015
            • 303
            #1100
            Oh gotcha! In that case it makes more sense
            • Digitalwave
              is a poseur
              • 6299
              #1101
              I believe I've seen people transfer over the contact ring for the horn onto the NRG slim hub. I'm using a Momo and essentially the same quick release, as I am 99% sure that Rogue piece is a rebranded NRG quick release. They are nice pieces.
              RISING EDGE
              • Sh3rpak!ng
                • Jan 2014
                • 2667
                #1102
                Yea, I've seen some posts of that too. Just need to get to my storage unit and find my old steering wheel. Glad I kept it. Looking at pictures of the NRG QRs, looks like you may be right. All the parts look near identical. The "assembly" instructions were entirely in japanese/chinese lol.
                Shadetree30
                • glnr13
                  • 1334
                  #1103
                  Yup, pop out the old contact ring and put it into the NRG hub. Also, add a little extension to the signal canceller, like an inch.
                  • Sh3rpak!ng
                    • Jan 2014
                    • 2667
                    #1104
                    I just came across an old thread a few years back where you posted some pictures. Thanks ill do that. Just annoying they dont include it seeing how easy it would be.
                    Shadetree30
                    • itskingsteelo
                      • Jul 2013
                      • 1340
                      #1105
                      time to set the whole house on fire.
                      Originally posted by dvck
                      • TeXJ
                        • 1914
                        #1106
                        Hey did you by chance start with an airbag steering wheel? Wanting to get mine swapped to a momo wheel
                        1990 325is
                        m52b28
                        3.73lsd
                        g260 (1987 325is 5spd tranny)
                        • Digitalwave
                          is a poseur
                          • 6299
                          #1107
                          The process is the same, you just have to have another stack of washers on the other side of the hub as well because the steering column is longer on an airbag car.
                          On all of the cars there is a pretty thick washer BEFORE the stock wheel, or before your aftermarket hub. You need another one of those, or something suitably similar, AFTER the hub. Otherwise the nut bottoms out on the splines before the hub is tight. I hope this makes sense.
                          RISING EDGE
                          • pandaboo911
                            • 2070
                            #1108
                            Yup, easiest way is to grab a 2nd BMW spacer and use it as a washer. You can buy them new and they are fairly cheap.
                            Btw, how did you go about lowering the steering column? Was it difficult?
                            • Sh3rpak!ng
                              • Jan 2014
                              • 2667
                              #1109
                              Hahaha I've had plenty of visitors over the years. I only worry if I see scorpions or black widows in the garage.
                              started with non-airbag
                              It's fairly easy. There are two rivets that bolt the column in place with a bracket. You can see them if you remove the covers. You just drill out the rivets and replace with bolts + spacer of your preference. You may have to clearance the inside of your steering knuckle on the rack side of the column depending on how much you change the angle of the column. If you drop it a lot you might bind the joint. I clearanced the joint already ages ago when iI swapped racks.
                              Shadetree30
                              • TeXJ
                                • 1914
                                #1110
                                Thanks yall!
                                1990 325is
                                m52b28
                                3.73lsd
