E30 Street/TimeAttack (+ E36 V8 Turbo Touring)
  • Miuge
    • Feb 2015
    • 201
    #211
    I'm afraid multi-rib needs a separate tensioner.
    It would utilize those non-countersunk holes, the hub would have three non-threaded holes too and the trigger wheel would be threaded (or countersunk bolts from the other direction with threaded hub, which would make tightening afterwards quite hard though) :)
    Facebook - MRT Engineering
    eBay - MRT Engineering
    Instagram - mrtengineering
    YouTube - miugemrt
    • RAVISH
      • Jan 2017
      • 1
      #212
      Awesome!!
      Originally posted by Miuge
      Hello everybody! My name is Mikko, I live in Finland and I've been building my E30 for years slowly with love and emotion.. Car is pretty much pure track build with a bunch of my designed and fabricated custom parts. Some of you might have seen my project pictures at r3vlimited facebook group, now I finally got myself registered here :)
      So where should I start then... I have LOTS of pictures and also as much story to tell, but I'll just offer you a short list of the modifications I've done or what I'm going to do:
      Engine:
      -M30B35 twincharged with Eaton M112 and maybe a PT6766 or similar
      -Water to air intercooler (pic)
      Drivetrain:
      -ZF GS6-53DZ gearbox (pic)
      -E60 M5 differential (pic)
      -E60 M5 driveshaft (pic)
      -E34 output shafts
      Suspension:
      -K-sport Track coilovers (pic)
      -E36 M3 spindles front (pic)
      -Modified E34 M5 rear axle (pic)
      -DTM style adjustment in every corner (pic)
      Brakes:
      -Porsche Cayenne Brembos 6- and 4-pot (pic)
      -E46 M3 discs front (pic)
      -E34 M5 discs rear
      -Pedalbox (pic)
      Steering:
      -E46 steering rack (pic)
      -Electric power steering pump
      Wheels:
      -17" 5x120
      -275/40 front, 315/35 rear
      Chassis:
      -FIA rollcage
      -lots of fiberglass
      Pictures in my Photobucket:
      A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
      Don't forget to like our Facebook page, we might have some cool stuff there
      MRT Engineering, Ylöjärvi. 7,491 likes · 1 talking about this · 15 were here. Performance parts and accessories CNC machining TIG welding
      Thanks,
      Miuge
      hostgator coupon
      hostgator coupon code
      hostgator promo code
      hostgator coupons
      hostgator discount
      • Ryan335
        • Jul 2015
        • 45
        #213
        Ah well, lots of choices for tensioners out there ;)
        Your solution was as I suspected. Sounds like the ring would need to be installed before the hub so you could do counter sunk bolts from behind and potentially get more thread engagement in the hub. Although I do not know the material or dimensions you're working with so that may not even be a concern.
        Keep it up!
        • Miuge
          • Feb 2015
          • 201
          #214
          Yes it needs to be installed first to keep the design simple. There's still plenty of room behind the trigger so I could add nuts behind it or weld threaded sleeves to the wheel for more engagement.
          YouTube - miugemrt
          • Anthony B
            • Nov 2012
            • 308
            #215
            Nice working point with the damper, ppm sells one for the m30/s38's but after the delay with my valves I'd be hesitant to buy one.
            Get top-quality crankshafts, connecting rods, and forged pistons at PPM Racing. Our cutting-edge technology, including CNC machining and computer-aided solid modelling, ensures maximum strength and weight savings. Choose from 2618 or 4032 grade aluminium alloy, with hand de-burred pistons and precision-milled ring grooves for low-drag, lightweight performance. Experience the best in design and manufacturing with PPM Racing.
            • Miuge
              • Feb 2015
              • 201
              #216
              Yeah I know they have a product available, but for me it's no use since I'm not going to use v-belt or need a direct bolt-on part.
              Someone looking for a cheaper solution with skills to carry out multi-rib belt conversion could get the ATI damper shell assembly for $350 (2-ring variation even cheaper) and our complete custom hub + trigger wheel will probably be less than $300 total (how much less depends do we get any interest in this). :)
              YouTube - miugemrt
              • Miuge
                • Feb 2015
                • 201
                #217
                I made two more flanges, one for water in and another for water out, I'll weld 40mm bends to both flanges. No more need for that big thermostat housing because EWP ;D
                Earlier I acquired boxful of silicone hoses for coolant and charge pipes from size range 16mm to 100mm:
                YouTube - miugemrt
                • Anthony B
                  • Nov 2012
                  • 308
                  #218
                  This just gets cooler & cooler.
                  I need to figure out a multi v alternator, & water pump pulley to make use of the ATI option
                  • Miuge
                    • Feb 2015
                    • 201
                    #219
                    Quick update of the ATI damper :) I'm currently printing 1/3 of the trigger wheel.. why didn't I buy a bigger printer...
                    YouTube - miugemrt
                    • semaj4712
                      • Mar 2012
                      • 3069
                      #220
                      This thread is too epic...damn
                      29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
                      72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
                      Gewerkschaft der Polizei Sticker/Clings For Sale $8
                      • Miuge
                        • Feb 2015
                        • 201
                        #221
                        I think I should start doing something more concrete soon
                        But here's the finished prototype!
                        YouTube - miugemrt
                        • LoneWolf
                          • 402
                          #222
                          Is your electric water pump remote? Where will you connect the feed and return on the engine?
                          • Miuge
                            • Feb 2015
                            • 201
                            #223
                            It's remote Davies Craig EWP150, feed goes to that big flange where the orginal pump supposed to be and return is in cylinder head front corner + back of the head.
                            YouTube - miugemrt
                            • LoneWolf
                              • 402
                              #224
                              Where will the radiator connect? I'm missing something obvious in the electric water pump set ups.
                              • Miuge
                                • Feb 2015
                                • 201
                                #225
                                Radiator connects between the return line and pump, pump is on the cold side pushing coolant to the block. Thermostat and engine's internal circulation is replaced with variable pump rpm in ewp applications.
                                YouTube - miugemrt
