E30 Street/TimeAttack (+ E36 V8 Turbo Touring)
  • Miuge
    • Feb 2015
    • 201
    #181
    Here's more comprehensive update of what's done and what not:
    S369 turbo seems to fill up the space effectively, in fact my earlier S467 was equipped with a rare small comp cover which is smaller in diameter...
    I got my injectors and made couple of weld bungs which turned out too short after drilling the holes
    Pile of ignition coils:
    I was thinking to order a laser cutted rack for coils, so I made a "coarse" 3D mockup one evening:
    Primarily I focused on drivetrain, gearbox adapter plate needed a few holes, apparently I had cutted my cardboard mockup along the wrong line and there was not enough material for one hole, but it was easily fixed with a welder:
    Before I was able to make a cross member I hung gearbox from the inside, also I've forgot to take pictures of the cross member and mounts in the chassis:
    The gear shifter episode:
    Got to start from somewhere, this is what felt a good location:
    And how it turned out:
    Facebook - MRT Engineering
    eBay - MRT Engineering
    Instagram - mrtengineering
    YouTube - miugemrt
    • Anthony B
      • Nov 2012
      • 308
      #182
      The mock up for the coil packs, would you consider putting it into production or looking as a more one off part?
      From the look of the rendering mounted to the valve cover correct? Are you utilising the afm mounts on the cover?
      • squidmaster
        • Aug 2011
        • 2666
        #183
        can't wait until this is finished!
        idk might just be me but I wouldn't have drilled/shaved/cut anything on the runners with my head right there, now there are shavings all inside it! haha
        • Miuge
          • Feb 2015
          • 201
          #184
          Sure if you need one, I'll just measure valve cover AFM mounts and make a sketch. In fact I was thinking to tilt coil mounts from horizontal to vertical which might simplify things.. :)
          squidmaster: It's easy to put parts in the washing machine and they'll be clean and shiny again ;D
          YouTube - miugemrt
          • squidmaster
            • Aug 2011
            • 2666
            #185
            I knowww! But there's always a chance it wont get everything, just one more thing to worry about! Haha
            • Miuge
              • Feb 2015
              • 201
              #186
              Anthony:
              Another revision utilizing M30 valve cover AFM and harness mountings:
              YouTube - miugemrt
              • litu
                • 848
                #187
                sub
                https://www.facebook.com/Cry_77_IX-110483784967661
                https://www.instagram.com/cry_77_ix/
                • Anthony B
                  • Nov 2012
                  • 308
                  #188
                  Originally posted by Miuge
                  Anthony:
                  Can't wait to see this fab'd up, I'll be interested to see how they sit on the valve cover. I've been looking at similar firewall mounted ones
                  • george graves
                    • 20003
                    #189
                    Space was limited but the volume will be near 9 liters when finished. I think there's no ultimate formula for calculating ideal volume, but 2-3 times the engine displacement should do when seeking at maximum power.
                    Interesting. I assume there is minimum(just for the sake of flow) - but I wonder if there is an practical upper limit that you begin to loose performance.
                    Originally posted by Matt-B
                    • squidmaster
                      • Aug 2011
                      • 2666
                      #190
                      Space and weight affect that "maximum" I imagine. I mean, unless someone wants to install a fuel-cell style tank of oil in their trunk?
                      • Miuge
                        • Feb 2015
                        • 201
                        #191
                        AnthonyB:
                        One thing I wasn't thinking about earlier is that my engine is located "underneath the windshield" and the height of the coil pack with vertical mounting is around 95mm, my engine is tilted +10deg more upright.. Not too much space available there neither Need to measure..
                        George:
                        Volume of the plenum (as well as runner length and diameter) is always a compromise, unless it's some kind of a complicated variable type. Smaller volume gives a better response, but bigger will allow the best peak power.
                        About the upper limit, I think you can't make "too big" and lose peak performance, but you'll sure notice more lag and weakened throttle response.
                        I wish free valve system would become more common in near future.. Hmm, a free valve M30 ;D Check out Koenigsegg talking about their system on Youtube.
                        YouTube - miugemrt
                        • Miuge
                          • Feb 2015
                          • 201
                          #192
                          I got my new longer injector weld bungs and welded the plenum chamber together. Injectors are Bosch 210lb with 15mm extensions with filters.
                          I also got 2x 380LPH fuel pumps which will feed E85 through the 7micron inline filter.
                          One day I scanned the oil pump back plate and made a 3D model, a blank will be most likely water jet cut, then machined:
                          YouTube - miugemrt
                          • Miuge
                            • Feb 2015
                            • 201
                            #193
                            Holidays... Good time for the project!
                            Apparently it was time to finish the new engine mounts, now with delrin bushing:
                            You might remember I just did one gearbox cross member, but surprisingly I wasn't happy with the outcome so I did a new one:
                            E60 M5 driveshaft needed to be shortened 400mm, I hope my welds will hold:
                            While fabricating the drivetrain I wanted to revise rear axle carrier mounting one more time. I machined a couple of delrin bushings and formed some sheet metal pieces to get this appearance:
                            Prototype of a M30 ignition coil rack was finished too:
                            YouTube - miugemrt
                            • Jaker
                              • Oct 2013
                              • 234
                              #194
                              All this fab looks fantastic. I love it!
                              • sampayne
                                • Apr 2014
                                • 396
                                #195
                                Wow, very nice job on those engine mounts. Surprised you aren't using a gas lens on your torch setup.
                                Originally posted by 2mAn
                                The BMW V6 is the best
