E30 Street/TimeAttack (+ E36 V8 Turbo Touring)
  • LoneWolf
    • 402
    #226
    Got it. Thanks. I was having trouble connecting the dots.
    • CubbyChowder
      • Mar 2012
      • 1488
      #227
      I love this thread.
      --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
      --Golden Boy E30 Build Thread-- (sold)
      • Miuge
        • Feb 2015
        • 201
        #228
        Clutch setup arrived, probably not going to use twin mass flywheel :o
        Now that I also got silicone hoses I continued welding, first mounted a throttle body:
        Then the other side, that's the only place where I was able to mount blow off valve:
        Some coolant pipes and new mounts for the power steering pump:
        Facebook - MRT Engineering
        eBay - MRT Engineering
        Instagram - mrtengineering
        YouTube - miugemrt
        • Miuge
          • Feb 2015
          • 201
          #229
          I had some struggle machining the oil pump back plate manually, I did two versions which didn't turn out too good. I also tried a shortcut welding a sleeve into the orginal cast cover.. Because of the high Mg content welds won't hold even if they would look good, here's the result of light hammering, crispy:
          It was time to start over, I did some changes to model and discarded the idea of a water jet cut blank because of it's ridiculous price. I happened to find a company which would machine the part for me very cheap with their 5-axis machine. I just confirmed it fits by 3D printing a mockup:
          The final part (made of AW-7075) should arrive in three weeks :)
          YouTube - miugemrt
          • sgtskid
            • 763
            #230
            Originally posted by Miuge
            One day I scanned the oil pump back plate and made a 3D model, a blank will be most likely water jet cut, then machined:
            What kind of scanner are you using? A 3d printer is an amazing tool to have access too and has saved my hind end on many occasions.
            Your build is epic and is motivation for future plans with my car.
            Current: '91 DS M3, '03 TS M3 (6MT)
            '06 Chevy 2500 Duramax - Race car hauler, '90 Corvette - Weekend toy
            Past: '88 AW M3, '87 RB M6, '98 CS M3, '88 DS M3, '88 Zinno M3, '88 AW SETA (facelift),
            1988 Super E (Bronzit - grey wrap)- RIP, 1986 353, 1986 VW Jetta (vr6) - Racecar
            IG: RDE_Fabrications
            Check us out
            Or YouTube --> HERE;
            • Miuge
              • Feb 2015
              • 201
              #231
              I only needed bolt pattern and outlines then used the scanned picture as a base of the sketch :) I haven't yet acquired a 3D scanner, that's something I have to study later..
              Thanks for the compliments!
              YouTube - miugemrt
              • Miuge
                • Feb 2015
                • 201
                #232
                ...Not again
                Reason? I managed to change the engine position after modifying steering rack mounts, so when I renewed engine mounts I positioned it as low as possible and even further back. Besides the welds looked terrible now that I've learned to TIG somehow Upcoming version will be looking quite different.
                Now that I got the taste of cutting I cut the comp housing outlet too:
                To change it to this:
                Few Finnish fellows were inquiring M20/M30 cam sensor covers from us as we had made some 3D printed prototypes earlier (in co-operation with Juuso's Garage), these anodized aluminum versions are about to arrive soon:
                YouTube - miugemrt
                • sgtskid
                  • 763
                  #233
                  Ha ha, that works. Keep it simple. I was thinking you had a 3d scanner.
                  Check us out
                  • Miuge
                    • Feb 2015
                    • 201
                    #234
                    Oil pan project:
                    Front sump is only to clear oil pump:
                    Long welds:
                    Oil pan baffle with trapdoors, screws are only temporary, those will be replaced with rivets:
                    Assembly taking shape:
                    YouTube - miugemrt
                    • Miuge
                      • Feb 2015
                      • 201
                      #235
                      Stainless steel oil intake screen, not yet welded, custom made of course:
                      Aluminum fuel rail, not yet anodized, custom made of course:
                      YouTube - miugemrt
                      • ThatM20Guy
                        • Aug 2014
                        • 600
                        #236
                        Damn. Is there anything on this car that's not custom? Awesome build :)
                        89' 325ix Diamantschwarz/Black rattle can...
                        Insta: r_moose_w
                        Originally posted by flyboyx
                        I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
                        • Miuge
                          • Feb 2015
                          • 201
                          #237
                          Lol, very little indeed.. I guess :)
                          YouTube - miugemrt
                          • Miuge
                            • Feb 2015
                            • 201
                            #238
                            Here's even more, coolant reservoir and oil catch can with crankcase and cyl head ventilation:
                            YouTube - miugemrt
                            • fight4life28
                              • Apr 2014
                              • 821
                              #239
                              So much fab work involved. Coming out great
                              • Miuge
                                • Feb 2015
                                • 201
                                #240
                                One more aluminum tank.. Fuel surge tank that has been in progress for a loong time. It needed a baffle inside, end cap and AN fittings for fuel in and out, unfortunately AN6 fittings were out of stock at the local store so I wasn't able to completely finish it Underneath my FPR with AN10 in/outlets:
                                Finally got this part I've been waiting for, shiny aluminum bit from Italy:
                                YouTube - miugemrt
