Beautiful!
E30 Street/TimeAttack (+ E36 V8 Turbo Touring)
Thanks!
It's mild steel P235, thickness 2,6mm. It's very common material for the manifolds, cheaper and not so prone to cracking as stainless steel.
I've glass blasted the manifold before welding it completely, that's the reason for colour.Comment
Subscribed. AMAZING!How to remove, install or convert to pop out windows
Could be better, could be worse.Comment
Thank you!
Recently I've machined and bought some new stuff.
Current engine mounts were kind of temporary, never welded them complete, because turbo and supercharger locations were only approximate.
I wanted a lower design to clear the turbo intake pipe.
The design, steel sleeve with delrin bushing:
This was something I could machine by myself :nice:
Obviously I had to mockup alternator location before making intake/charge air piping, but the old one had seen it's best days. Instead of refurbishing and machining new pulleys for the old one I bought a new, smaller, modern alternator:
This spring and summer will probably be busy time with the project, more parts is already on the way ;DComment
That turbo manifold is a work of art.Comment
This will be a frustrating and time-consuming job :drink: 1 out of 4 corners in progress, after spraying a paint layer I noticed one spot needed to be cut open and hammered down.
Finally got all the parts for the control arms, roll-center/bump steer -adapter fits perfectly ;D
Also few lengths of aluminium tubing appeared this week, need to build up something of those
Sub'd:DYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
If you have bought items from me, please leave feedback below.
If you are a BUYER, Check My Feedback.:up:
http://www.r3vlimited.com/board/showthread.php?t=183860
Check out my Euro Build Thread
http://www.r3vlimited.com/board/showthread.php?t=215557Comment
Good to see some new subscribers! :up:
Earlier this week I bought few liters of paint, should be plenty for mock-ups and molds. I picked the same hue which might be the final color, we'll see...
At this point the fender starts to look like something, but still a lot to do. A couple of bigger dents showed up after the first gray paint layer.
But... this will probably do, picture taken this evening. I'm afraid something goes wrong when I start to mess up with fiberglass :D
I think I should take the camera more often with me, mobile pics look crap besides these..Comment
