e30 325ix-86: with a Finnish touch
  • jute91
    • Nov 2011
    • 581
    Made a new build thread where I reserved some space at beginning for my writings.
    So the story begins..
    I bought the car in february, 2008, from germany.
    the picture has been taken at the parking lot at hotel lübeck ;)
    Gave it full check and clean up when I got it home.
    those low offset mahle bbs were rubbin hard with meaty setup as 205/55
    so I got some 17's to get rid of rubbing
    Gave them paint and they were pretty decent, wasn't 100% sure for the way they looked
    Good day to install better sound system :P
    Got thirsty for getting more hp's and there the long journey starts.
    Shrick 288 from germany.
    new 731 head for the stroker build.
    got some m57 cranks with 88mm stroke for cheap. "failed swirl flaps"
    Also found on Facebook - Juuso Tero, Tampere
    https://www.facebook.com/JuusosGarage
  • jute91
    • Nov 2011
    • 581
    Got myself into Tampere University of Applied Sciences and started studying automotive and transportation.
    First touch into 3d modelling and printing and I started making Itb's for it.
    First 3d model printed for test fitting.
    Took the transfer case off because loose chain
    new chain on its place
    found little wear on the front output shaft
    Took classes in the evening in another school and studied myself another profession, CNC machinist
    designed front output shaft uppgrade with grease nipple and machined it out.
    welded it on on turning table
    ready for installation
    started planning 5-lug swap with brake uppgrade.
    googled and found out that e87 has pretty decend hub for my use.
    ix front - e87 - ix rear
    at the time I also started making coilover setup for it. used my dad's coilover setup for measuring
    rear setup coming along. stock ix vs e87 hub + e36 rotor
    required some spacer to bring it little outer to make clearance for the hand brake
    cleaned front control arms to meet new damper pipes.
    grinder tool in good use ;)
    pay n' spray time ;)
    first test with the coil. trying to find good spring rate
    rear bushing needed some spacer to fit with rwd urethane bushings
    rear brakes
    fronts
    for the front stabilizer
    first test drive
    time to go to winter safe
    • jute91
      • Nov 2011
      • 581
      So heating problems started to come on...
      started fitting electrical fan and bigger radiator.
      My first touch on tig welding :)
      time to swap manifold
      took part in car show with my friend. he had the datsun 280z
      Car continued overheating and I decided to leave it wait engine pulling out.
      • jute91
        • Nov 2011
        • 581
        So I started dropping the engine with transmission.
        new crank going in
        some used m54 rods and pistons for the test fit
        took measurement of the m54 piston and gave it a little modifications.
        • jute91
          • Nov 2011
          • 581
          So back to cylinder heads.
          I bought all the types of head: 200, 731 and 885.
          started running flowbench tests to see comparation between years.
          bigger valves to see if it helps
          42mm
          44mm
          40, 42 and 44 valves
          • jute91
            • Nov 2011
            • 581
            couple of 3d printed models I made to work out the clearance problem with the brake booster.
            Chop Chop MADAFAKAA!
            • jute91
              • Nov 2011
              • 581
              Right way to check manifold fitment ;)
              Made a tapered press tool from 35mm to 45mm ;)
              and finding a correct shape begins.
              Made a curved tapered one too ;)
              • jute91
                • Nov 2011
                • 581
                so I started making flanges for the dellorto/weber carburetors ;)
                measuring the outer diameter.
                close enough. I'll take it.
                yeah purrfect
                time for little turning
                le bling!
                enlarged the inner diameter to 44,8mm. will finish it upto 45mm by hand.
                Oops! better clean up too!
                Centering into mill for starting drilling bolt pattern
                So the flanges came out nicely. started fitting into my custom manifold
                welded it up
                stock 731 head without manifold
                with the manifold
                plus the carburetor
                plus the trumbet.
                oh yeah!
                • jute91
                  • Nov 2011
                  • 581
                  So yesterday I started porting practises with the cracked 731 head.
                  valve seat for 42mm intake and took the edge off.
                  guide reshaping
                  still needs finishing :)
                  So I got my 3D model ready. going to use weber/dellorto bolt pattern if I will ever go back to 80's and start playing with carbs ;)
                  So here is the final model
                  started fabricating parts
                  • litu
                    • 849
                    Niiiiice :)
                    Wating next updates
                    https://www.facebook.com/Cry_77_IX-110483784967661
                    https://www.instagram.com/cry_77_ix/
                    • Thujalvi
                      • Oct 2012
                      • 72
                      Nice work! Also I'm going to need you to tell me all about that Mk.2 Escort.
                      '93 Daytonaviolett Touring Design Edition
                      • jute91
                        • Nov 2011
                        • 581
                        Bought it and resprayed it.
                        Still needs engine rebuilt. last engine gave 214hp from 2.0 ohc
                        • litu
                          • 849
                          That body looks nice..
                          • JJe30
                            • 2044
                            Nice work
                            • kristov
                              • 222
                              How do you manage to get the incredible MIG-welds?
