Still under construction...
![](http://www.strainers.com/images/under-const_yellowguytype.gif)
03-23-2015 Update
TEMP sensors:
We are planning to support VDO temp. sensors only with max temperature 150°C (300 °F). There is a whole range of available types with different threads - any of them is OK, as long as the max temp is 150°C.
Attachment 1.
PRESSURE sensors:
We are planning to support VDO pressure sensors only with max pressure 145 PSI (10 bar). There is a whole range of available types with different threads - any of them is OK, as long as the max pressure is 10 bar.
Attachment 2.
Here is what we got so far: :nice:
![](http://www.r3vlimited.com/board/picture.php?albumid=2046&pictureid=13983)
09-17-2014
This project is hazard switch digital multigauge. It is capable of measuring five different things plus voltage. The most common setup would be:
- Oil Pressure
- Oil Temperature
- Coolant Temperature
- AFR
- Fuel pressure
- Voltage
It fits into a hazard switch, with a LED display cover made of plexi glass that is shaped like original hazard switch dark red plastic. The whole thing will work as a switch, when you press it it will toggle to another measurement with text displayed...let pics do the talking...
BTW, chars are evenly illuminated, pics can be misleading.
![](http://www.r3vlimited.com/board/picture.php?albumid=2046&pictureid=13399)
![](http://www.r3vlimited.com/board/picture.php?albumid=2046&pictureid=13400)
![](http://www.r3vlimited.com/board/picture.php?albumid=2046&pictureid=13401)
![](http://www.r3vlimited.com/board/picture.php?albumid=2046&pictureid=13402)
03-23-2015 Update
TEMP sensors:
Attachment 1.
PRESSURE sensors:
Attachment 2.
09-17-2014
- Oil Pressure
- Oil Temperature
- AFR
- Fuel pressure
- Voltage
