Slow Suzie the Corner Crusher - AutoX / DD
  • robaticus56
    • Apr 2015
    • 11
    This is my first E30 and I've named her Slow Suzie. This is my first car I've done serious work on and I plan on doing most if not all of the work on her myself. I'm teaching myself how to work on her along with a few other people who help me out when I'm absolutely dead stuck. I'm building her up for Autocross and a DD. I got her some time around the middle of March and have done quite a bit of work since I've had her and I'm just now getting around to this build thread so hopefully I don't forget to much of the earlier stuff. So here she is.
    First thing to fix was the reverse switch and the seat belt receptacle on the driver's side. So I after a couple hours of screwing around on the transmission with that switch I got it off and the new one on. Yay reverse lights work now! I doused the seat belt receptacle in WD40 and it now works except I have to smack it to get it to lock, one day I'll find a junk car and pick that amongst many other things off. So I got the car inspected and she passed and after a cumulative 6 or so hours at the DMV she got plates!
    Next thing on the list was the non functional tach and mpg gauge. It turns out there were 3 blown fuses. Replaced them and the tach finally lifted off but the mpg gauge just kind of flys back and forth, oh well at least the tach works.
    The odometer wasn't working as well, go figure. So I ripped that bad boy out.
    New gears and cluster
    The part I really want
    Old gears and not in good shape
    Seems I've found the issue
    Band new gears!
    With the new gears installed I actually know how far I've gone now. Helps a bit with staying on track with maintenance. That's it for tonight there will be more to follow in the coming days.
    Originally posted by Gandhi
    Talk shit, get hit.
  • robaticus56
    • Apr 2015
    • 11
    Update #2
    Now I started really digging into the car, she had a rather rough idle and a sluggish throttle so I set to work on getting that fixed up. After some research and question asking I came to the conclusion it was probably something with the intake. Also the car stalled out while sitting in a parking spot after about 2 minutes so I pulled out the fuel injectors and sent them out to get cleaned and rebuilt.
    Nasty dirty injectors
    Shiny clean injectors
    While taking out the injectors I found this with dried electrical tape over missing areas on the valve cover hose. The hose was so brittle I could snap it with my hands.
    While she sat in an parking lot completely immobile my friend just happened to move into a house with a big garage and by some miracle he agreed to let me get funky with Suzie in there for a while.
    I cleaned out the trunk of a bunch of crap and accidentally threw out my intake manifold gaskets like a genius. I went dumpster diving as soon as I realized what happened about 2 days later but they were gone... I went off the order new ones.
    Shortly after the injectors were back I got her into the freshly inhabited house, but not before I realized some was awry with the ignition system. It was rainy one morning and Suzie decided she didn't want to start. Having run into this exact issue before on my old '95 Jetta I was pretty sure the the issue was something was between the coil and the spark plugs but decided to get her into the shelter of a garage before taking any action. Once she was in the garage I shifted my focus to the intake system.
    I redid the manifold gaskets, throttle body gasket, intake boot which had a sweet rip in it, crank case breather tube o-rings, valve cover breather hose. While removing the intake manifold I found that the T shaped coolant hose going to the heater core from the thermostat was torn and swollen at the connection to the thermostat housing. It was also right in front of one of the manifold bolts and had to go. So I had to drain the coolant and gave me a perfect excuse to do the timing belt and the other things on the front of the engine.
    Throttle body is off
    Intake manifold is gone
    Gotta clean the mating surface
    Not sure where the beer came from but I'll drink it
    I replaced the timing belt, water pump, thermostat, power steering belt, alternator belt, distributor cap and rotor.
    Hello timing belt
    TDC before
    TDC after 2 rotations of the crankshaft
    Getting the timing belt on was a PITA because it kept slipping of the crank sprocket and I had to have my friend hold the whole bottom on while I slipped it over the cam sprocket, fun times.
    The contact points on the distibutor cap were pretty bad, thank god I got a new one in there.
    Looks alright to me
    Ok nevermind that's done
    Not to fear we have a new one here
    Here is the coolant hose that had to go
    Old H2O pump
    New H2O pump
    Talk shit, get hit.
    • robaticus56
      • Apr 2015
      • 11
      Update #3
      I knew the AC was bad so when I had the radiator out I thought for all of 2 seconds about keeping it. I come the conclusion that it needed to go because isn't that why I have a windows and a sun roof? The condenser sure as hell put up a fight and didn't want to go but in the end I won. Now Suzie is about 30 pounds lighter in the front.
      All the AC bits
      Look at all that room
      Even more room
      Looks like you could fit nice air cooling device in the front of the engine bay now perhaps attached to a turbine of some sort. Well either way I don't have the funds for a project of that magnitude yet, maybe later.
      When I went to fill the engine with coolant again this happened
      I stripped the coolant bleeder screw and had to use vise grips to get it off. So that's another part I had to order.
      Sometime later this weekend I will post the fiasco that was and is the suspension or at least as far as I am at this point in time.
      Talk shit, get hit.
      • Nick_S
        • Apr 2011
        • 3658
        Great start! Looks like a rough one but you seem to be heading in the right direction!
        91 318is M50 swapped
        05 Honda Pilot
        24V swap thread
        • robaticus56
          • Apr 2015
          • 11
          All I had the intention of changing with the suspension was the struts/shocks and springs. I got Koni SA and H&R Race springs for the car and was under the impression it was going to be a couple hour job. That was 2 weeks ago and she's still on jack stands.
          First thing that was wrong was that my friend marred up the control arm and tie rod and ball joints which in hindsight is probably a good thing as the boots were ripped apart and I wouldn't have even known to check that. So after some time on Google and Youtube I knew that getting new control arms and tie rod ends was needed anyway.
          Here are the ones he dicked up
          The rest were already messed up
          The next thing that was messed up was the control arm bushings. I was able to rip one apart one the right side of the car with relative ease, probably not good.
          The remnants of that
          Then I had to cut the rest of the bushings out with a hack saw
          Next on the list of busted things were the front sway bar end links
          Also not really sure what happened to the front bump stops on the struts but they weren't there at all which probably explains why they were blown out.
          I was hoping the rear would be fine, I'm not really sure why I didn't expect the same as the front. The rear was not fine however.
          First thing I noticed was the sway bar end links were shot
          Then the shock tower mounts were done as well
          Not sure if this is supposed to be out, but I'm banking on no
          So over the past 2 weeks I have been slowly ordering new parts for the suspension as I realize what needs replacing.
          It all started with this joyful delivery
          New FCAs
          New bushings for everybody!
          I'm not sure but I don't think that's a strut mount
          New front sway bar end link
          Today I finally have a strut assembly together
          In it goes
          Front suspension from the bottom
          The rest of the rear suspension should be in early this week and hopefully I can get her back on wheels by the weekend
          During this all this business my new wheels and tires came in. I got Kosei K1s and Durezza Z II Star Specs in 205/50r15
          I can't wait to get those bad boys on Suzie and take them for a spin.
          Talk shit, get hit.
          • DER E30
            • Sep 2013
            • 2349
            Nice progress!
            -Christian
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              You're not going to believe it's the same car when you drive it next haha
              Originally posted by priapism
              Originally posted by shameson
              • Codym42
                • Mar 2013
                • 611
                Nice work, I love Kosei k1's. Can't wait to see what else you do.
                '90 325i - 5 speed coupe
                '05 330ci 6MT ZHP
                • robaticus56
                  • Apr 2015
                  • 11
                  The rear suspension was not as bad as the front but there were some fun parts like getting the sway bar end links on. First thing was to lower the exhaust so I could in turn lower the diff.
                  Ran out of jack stands so boxes worked
                  Here is the diff lowered
                  New rear shock mounts
                  The H&R's are kinda small
                  Yellow goodness
                  While dropping the exhaust I found one of the hangars was a little broke
                  So I replaced it with a coat hanger for now
                  I got it all put together and the whole car back on the ground.
                  Talk shit, get hit.
                  • agent
                    Vice Grand Pubaa
                    • 7960
                    Good work so far!
                    Originally posted by kronus
                    • 95BMWIC
                      • Apr 2012
                      • 353
                      Subscribed!
                      Love the rims - Post a pic with them installed..
                      • F34R
                        sLaughter
                        • 12376
                        Looking good!
                        Instagram: @BWeissLeather
                        Current cars:
                        ~ '87 325 M30B35 swap
                        ~ '87 535
                        ~ 01 540 Msport 6spd
                        ~ '06 X5 4.8is
                        • robaticus56
                          • Apr 2015
                          • 11
                          Sometime during the suspension process I replaced the spark plugs with Bosch W8LCR+
                          Not sure but my Bentley never said these were supposed to be in there
                          Like a good little boy I followed the manual
                          Also I realized that this needed to happen
                          I'm not sure if its just me but I had a hell of a time with the coolant bleeder screw. I stripped the original one trying to get it out then I twisted the head off the second one and I finally got the third one right.
                          Screw #1 after removing with pliers
                          Remains of #2
                          The rest of #2
                          So I realized that's not supposed to do that
                          I got a new thermostat housing cover and bleeder screw and learned a valuable lesson about torque, don't over do it.
                          After the car was on the ground again I decided to vacuum the carpet
                          Before
                          After
                          I also decided it was a good place to take a nap after it was clean
                          Apparently I forgot how to real life at some point during this process
                          The chrome stripping around the windows wasn't on around the bend of driver's side door so I smacked it back on and the part near the hood popped out. Since I didn't have any glue handy I just used a bit of silicone and a clamp
                          I decorated my trunk lid with all my Rock Auto magnets but after I drove it in a light rain they started coming off but the American flag stays on, mostly for the irony
                          Also I figured I'd put a list of what I plan on doing to the car. It's mostly in the order it will be completed
                          Sound system install - hopefully my premium speakers still work
                          Finish suspension (rear bushings and sway bars)
                          Shifter Rebuild / short shifter (probably from an e36 328i)
                          Steering rack from a Z3
                          Brakes - braided steel lines and better pads
                          Interior - seats, carpet and misc trim pieces
                          Complete exhaust - I have to put a cat on the car again when I move back home because PA has some gay laws about the enviroment or whatever
                          Paint - Probably repaint Lachssilber Metallic or change the color to LeMans Blue (less likely due to the amount of work involved)
                          200+ WHP with M20 - not sure if I want to stroker or boost it, there are pros and cons to both but I think that's a decision for later down the line when I have money for that
                          I don't have any pics of the car with the new wheels yet, but I should be able to get some up tomorrow
                          Talk shit, get hit.
                          • robaticus56
                            • Apr 2015
                            • 11
                            Here are some pics of the car with the new wheels
                            I found this and had to get it
                            I'm hoping Suzie will learn a thing or two from her new companion
                            Talk shit, get hit.
