Bumada's S5x Project E30
  • bumada
    • Apr 2015
    • 305
    Small update. I just got the windows tinted this weekend with 20% tint.
    Sent from my SM-G900V using Tapatalk
    1989 325i S50 swapped
    2007 4Runner Sport V8
    • mexocutioner
      • Apr 2015
      • 113
      Could you post a pic of your car looking straight at it, low from the back? Im looking at wheels the same size as yours, and im trying to see how they fit in. Plus im torn between 8 or 9 inch wide wheels so it would cool to see how yours look width wise. Did you need to do any fender rolling once lowered?
      • bumada
        • Apr 2015
        • 305
        Sure, I can do that when I get home today. I wish I also got the 16x9 for the fronts as well and then space out the rear a touch. I got the fenders rolled before I did anything to it. I can't say for sure that it was absolutely needed because there is quite a bit of space between the fender and tire, but I don't want to confirm that it'll be fine. It looks good if you aren't going for super aggressive wide wheels and definitely grabs attention.
        I did a lot of shopping trying to decide on tire sizes and decided a 215/45 to be the best option for these sizes. I didn't want to put a 205 on the rear but no tire model had a 205 and a 215 in the same tire.
        Edit to include wheel specs: 16x8 +20, 16x9 +15; 215/45/16 Kumho Ecsta XS
        • mexocutioner
          • Apr 2015
          • 113
          I didn't realize you had 9s on the rear! Will they fit in the front easily too though?
          Do you know what the ideal offset for 8 and 9 inch wheels are?
          • bumada
            • Apr 2015
            • 305
            Here's some pics. I think k they'll fit pretty easily in the front with a fender roll. So much room.
            I think I could fit a 10mm spacer in the rear and probably another 5 mm spacer in the front if you put the 9" wheel up front.
            • mexocutioner
              • Apr 2015
              • 113
              oh sweet! ill probably just go with 9s all around then! that's good to know! thanks that was a big help, now to just grind away for some money to get on with the wheels and lowering already lol
              • bumada
                • Apr 2015
                • 305
                Just be careful with the fronts with a 9" wheel. You'll need a lower offset so it doesn't hit the strut. Ask mystikal about fitment in the wheel and tire section.
                • bumada
                  • Apr 2015
                  • 305
                  Finally found a motor. My buddy got an extremely good deal on an e36 with an s50 in it. Also had quite a bit of other goodies on it. I told him I'll buy the motor if he ended up getting the car. Motor runs good and strong, 70k miles, chipped, and intake. This project should really take off now.
                  • bumada
                    • Apr 2015
                    • 305
                    I finally started with the motor swap. I spent Friday-monday removing the old m20 out of my car, removing the s50 out of the other car, and prepping everything for the swap itself. I need to buy a lot more parts but I made a lot of progress this weekend.
                    • spiDmang
                      • 3941
                      you'll love the S50! good luck
                      91' 318iS - S54/6MT Swapped
                      08' E90 M3 6MT - Daily
                      Originally posted by IronJoe
                      Originally posted by 2mAn
                      • PimpinWalrus
                        • Oct 2013
                        • 170
                        Love the wheels, gonna be mean as hell
                        Sent from my SM-N920V using Tapatalk
                        '86 Delphin 335i turbo -
                        '88 Schwarz 325i -
                        '94 w124 e420 -
                        Turbo m30b35 Build Thread
                        • unloadedak
                          • 1197
                          love those wheels and love the m3 :)
                          2003.5 Imolarot M3: daily
                          1995 Alpinweiß M3: hpde
                          • WestCoastEta
                            • May 2015
                            • 475
                            Nice project! The early photos of your car remind me of my first e30. What's the paint code? BMW's light blue colors all look similar to me. Mine was balticblau.
                            • bumada
                              • Apr 2015
                              • 305
                              So I pretty much suck at taking pictures while working on my car. I told myself I'd document everything and then when I'm under the car, hands dirty, rushing to get things finished, I no longer want to take time for pictures.
                              I've gotten the s50 mounted up with the condor motor mounts. Porsche 944 brake booster is installed and e36 m3 steering rack is in. We had to remake the rear brake hardlines that bolt to the T-junction. I had the whole rear subframe out for new trailing arm and subframe bushings. Installed the stainless steel brake lines and new sway bar bushings. Also went with the condor ssk package which includes the z3 1.9 shifter.
                              Still need to put the diff back in but found a leak in the brake lines we made. Also bought the bimmerworld track control arms so the header will clear. My friend is making my exhaust for me with a vibrant muffler and spun cat. I just need to plug up everything in the wiring harness, put the intake manifold on, and hope it runs well before finishing it up.
                              Sent from my SM-G935V using Tapatalk
                              • bumada
                                • Apr 2015
                                • 305
                                E36 steering rack and Porsche brake booster
                                Power washing the engine bay
                                Rear subframe out
