It pushes you into the back seat when you step on it, holy hell. How does the balance feel? Noticeable looser in the rear end with no power input through the corners?
					#BecauseRaceCar Story and Build - M60 6-spd
Awesome update.How to remove, install or convert to pop out windows
Could be better, could be worse.Comment
Yeah the rear end is all over the place, If i step on it coming out of a corner it breaks loose even with my 225 Toyo RR slicks. with no power input too much weight on the front end. im going to have to redo my whole suspension. Stay Tuned
My car sounded different than another other V8 out there on the track, people knew i had a V8 but couldnt figure out what kind haha and yes the sound is proper. so smooth and beautiful sounding.Comment
You're doing the world good by displaying an M60 E30. Treating the car well too, making it look easy to drive it smoothly. Speaking of which, is it scary at all, or does the chassis still overpower the engine?Comment
:eeek::eeek::eeek::eeek::eeek:
yeah thunderhill is definitely a miata track. that guy was catching air over the bypass.. that is insane.. my fastest time out there was a 2:14, that guy did it well under 2 minutes..Comment
The chassis can definitely handle the power.. but as mine is right now, I am going to have to retune everything else on the car to dial it in. That means larger brakes, better suspension.Comment
What does your sister think of her "old" car?Holy shit did you even read this post before you posted?
http://www.r3vlimited.com/board/announcement.php?f=156
This thread sure sucked last night. It just plain sucked. I've seen threads suck before but this is the suckiest bunch of sucks that ever sucked.Comment
What's your current suspension setup? I can't remember, having read through this thread a few months ago.Comment
she misses it and says why do I keep messing with it. lol
ground control. its garbage. lolComment
That is honestly a downgrade. Not hating. Do more research, talk to more people at the track, there are guys on this forum with lots of setup and track experience... not one of them will tell you to go that route. If you are looking to get better and learn about setting up your car, cheap shocks won't get you anywhere- '88 m54 coupe
<3Comment
ive done a bit research and seen that most people are assuming CAtuned coilovers are the same as BC Racing's.That is honestly a downgrade. Not hating. Do more research, talk to more people at the track, there are guys on this forum with lots of setup and track experience... not one of them will tell you to go that route. If you are looking to get better and learn about setting up your car, cheap shocks won't get you anywhere
