#BecauseRaceCar Story and Build - M60 6-spd
  • 2mAn
    SeƱior Mod
    • 20217
    #46
    thanks. now fix the car and get back on the track!!
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • ncrmtrsprtsE30
      • May 2015
      • 204
      #47
      Next thing I am going to try is the CPS sensor, going to replace that.. and if that doesnt work then im done with this motor.. lol
      The "Because Race Car" M60 V8 Build Thread
      On Instagram Straight Flexin' #BecauseRaceCar
      • ncrmtrsprtsE30
        • May 2015
        • 204
        #48
        Did a little work on the demon tonight and this is what I came up with...
        What I started with = NO SPARK, YES FUEL.
        COIL primary resistance is ZERO ohms.. (should be .5 ohms)(poss shorted primary coil, POSS DAMAGING ECU)
        COIL secondary is 5,750 ohms (5k-6k is spec = OK)
        COIL POSITIVE POST has ZERO voltage with KOEO (key on, engine off) (SHOULD have +12V)(possible broken wire between IGN switch and COIL POS+ wire)
        I hooked up a IGN switched 12v source to the COIL POS+ POST and now I have spark!
        Engine should fire - nope - still no start - possible fuel problem now, since i know i have spark and compression - only thing missing is fuel - could possibly be damaged ECU.
        • ncrmtrsprtsE30
          • May 2015
          • 204
          #49
          Debating a 2.7i conversion. swap the head and electronics over to 1.3 motronic any suggestions?
          • 2mAn
            SeƱior Mod
            • 20217
            #50
            do it
            Simon
            Current Cars:
            -1966 Lotus Elan
            -1986 German Car
            • ncrmtrsprtsE30
              • May 2015
              • 204
              #51
              I think I may have found my problem...
              I went through the ECU pinout for the ETA connector testing the harness.
              every single pinout was good, except for the TPS (throttle position switches)
              Pin 2 (closed throttle) - has NO continuity
              Partial open throttle - NO continuity
              Pin 3 (WOT) - has NO continuity
              pretty much no matter what position the throttle was in, it had no continuity..
              checked the TPS and its soaked in oil, disconnected the connector and its dripping oil. I havent removed the tps from the throttle body yet.. but im guessing its messed up from the amount of oil I see..
              will have an update on sunday.
              • ncrmtrsprtsE30
                • May 2015
                • 204
                #52
                well idk whats going on with my car.. now its not getting injectors or spark.. maybe a bad ecu?
                • ncrmtrsprtsE30
                  • May 2015
                  • 204
                  #53
                  update.
                  now have spark, but its still not running, the injectors are not firing..
                  checked reference and speed sensors in the trans bellhousing and both are producing signal wave all the way to the DME.
                  also cps sensor is working because i am getting spark.
                  spark issue fixed:
                  in the C101 connector, apparently there was a burnt wire and the GRN wire was completely destroyed. PO replaced the wire with a yellow one and switched the wire locations in the C101. The pins male and female in the connector, one was being pushed up into the rubber cover when connected, but when disconnected appeared to be fine.
                  • Eric
                    • 5139
                    #54
                    Dope thread! How did you go off on turn 9 at Laguna?
                    • ncrmtrsprtsE30
                      • May 2015
                      • 204
                      #55
                      tried taking the corner a little bit faster, BFG Rivals broke loose, and i over corrected, because i didnt want to go into the wall. lol
                      • ncrmtrsprtsE30
                        • May 2015
                        • 204
                        #56
                        UPDATE:
                        She's running, and better than ever.
                        I go to check my fuel today..
                        I have fuel pump going, injector are getting pulsing.. so i pull a fuel line and to my suprise there is no fuel pressure in the line..
                        i jump the FP relay terminals and I test the pressure and flow.. it has flow but very low pressure.. and after i turn it off it doesnt even hold pressure, within a couple seconds its zero pressure...
                        So i get into the fuel tank and while running the pump look inside through the level sender hole.. and there is a lot of fuel moving around in there.. so I remove the whole fuel unit and...
                        what do you know, I guess the hose i used could not handle being in the fuel.. replaced it with one that is specifically for fuel only.. and put it back in the tank.. a couple cranks and she fires up running smoothly.. let it warm up and go take it for a spin, and it has more power and throttle response than before.. i was getting sideways in 2nd gear! (prob because I cleaned the AFM and adjusted the TPS and cleaned out the throttle body..lol)
                        Video of her back from the dead
                        So now look forward to more Race Car updates!
                        • kts
                          • Jun 2010
                          • 753
                          #57
                          Yay! An awesome update, glad to hear it's running again!
                          • bullywagon
                            • Jul 2014
                            • 38
                            #58
                            That's great. Sounds nice in the vid.
                            • ian e30 318is
                              • Mar 2007
                              • 1806
                              #59
                              Awesome! Nice find!
                              1991 LS1 Swapped 318is
                              Instagram:
                              https://instagram.com/saltybeast/
                              LS Build Thread:
                              https://www.r3vlimited.com/board/for...s-e30-ls1-swap
                              • RustyEuro
                                • May 2014
                                • 110
                                #60
                                I'm glad you got the car up and running again, I expect to see more updates!
                                89' 325i DD/project
                                86 325e rust bucket/future race car
                                "Just because you go fast in a straight line doesn't mean you go fast in corners"
