Porsche smorche - I have a car habbit
  • Ether-D
    • Sep 2011
    • 2838
    #46
    I thought about it. It would fit. I measured them and they be the same length block…
    Originally posted by Andy.B
    I was born on 3/25…
    • whitebulat22
      • Apr 2014
      • 330
      #47
      Porsche guys have successfully rebored alusil stuff. Sunnen sells a paste for $50 that you rub on a certain way (not normal honing but with a certain pad over the hone). There are success stories on pelican parts and rennlist I think. You just dab it on until it has a specific dullish finish according to someone I read on there, I'll find my bookmark if y'all want.
      • Ether-D
        • Sep 2011
        • 2838
        #48
        ^Nah, I'm not gonna mess with it. It's just a tiny scratch. Thanks for the info though.
        I was born on 3/25…
        • Ether-D
          • Sep 2011
          • 2838
          #49
          I pressure washed the motor this morning. It was so greasy that your fingernails would turn black just looking at it. It's not completely clean, but it's a helluva lot better.
          before:
          after:
          I pulled the balance shaft end caps and resealed and cleaned them. After that I replaced the oil pump main seal and o-ring. Then I painted the intake manifold and a metal coolant pipe that runs above the exhaust manifold.
          The head is at the machine shop getting it's going over. I reckon I'll get to some heavy reassembly around mid week.
          I was born on 3/25…
          • agent
            Vice Grand Pubaa
            • 7960
            #50
            Hard deadline: 9/25/2015
            Originally posted by kronus
            • Ether-D
              • Sep 2011
              • 2838
              #51
              I feel like it's possible brah. It's gonna be a good week for progress I think.
              Now for an opinion question. Which one looks nicer and won't look weird in a green engine bay?
              This one?
              or this one?
              I'm leaning toward the classic black.
              I was born on 3/25…
              • LJ851
                • 7919
                #52
                The one with the turbo, obviously.
                ... with a black valve cover. Or gold valve cover.
                Lorin
                The M30 is God's engine.
                • Ether-D
                  • Sep 2011
                  • 2838
                  #53
                  I'm thinking black. But minus the turbo. And what's it doing over on that side anyway?
                  I was born on 3/25…
                  • agent
                    Vice Grand Pubaa
                    • 7960
                    #54
                    potstir
                    • Ether-D
                      • Sep 2011
                      • 2838
                      #55
                      Rebuilt and resealed cam tower. I gave it the classic treatment.
                      I was born on 3/25…
                      • Ether-D
                        • Sep 2011
                        • 2838
                        #56
                        I finally finagled the oil pan out. That was… irritating… to say it nicely. Pressure washed it and wire-wheeled it. So much better. I don't mind my own grease, but someone else's grease gives me the creeps. Anyway, that allowed me to remove the oil pump and clean and reseal it. I know it's sacrilegious, but I used some Versachem type 2 sealant to seal the oil pump to the block. I promise to let you know if it works, but if kittens and little girl babies start dying all over, you'll know it was because I didn't buy the $50 special sealant. Now, the pan is back in and hanging from it's bolts because I need to look up the tightening sequence.
                        Pics for posterity:
                        I was born on 3/25…
                        • jeenyus
                          • Aug 2011
                          • 2064
                          #57
                          Awesome! Cool to see someone working on this. I was so close to buying one of these at one point in my life, but my mechanic said it was a "bush" to work on so I avoided it b
                          • Ether-D
                            • Sep 2011
                            • 2838
                            #58
                            I can see it being a bit of a pain if it was your only car. But as a project on the side, it's fun. No pressure to "finish today or I can't make it to work tomorrow" kinda thing. If I lose patience with it, I can just walk away for a minute.
                            I was born on 3/25…
                            • Ether-D
                              • Sep 2011
                              • 2838
                              #59
                              Pan is all torqued down in the proper sequence.
                              I wire-wheeled the exhaust manifolds and wiped them down with some grease and wax remover (aka gasoline). Then I put a nice coat of VHT 2000º header paint and baked it on for durability during installation. Anywho, I'm hoping to get the head back tomorrow so I can put this thing back together. If he doesn't end up finishing it this week, I guess I can go on to cleaning out the fuel lines and tank. Which sounds a little boring. I guess it can't all be subframes and oil pans… 8-)
                              I was born on 3/25…
                              • jameskkkd
                                • Jul 2015
                                • 1
                                #60
                                hi
                                welcome to this site
                                abcd
